Captain's "Shed in a Year"
Captain
Adelaide Australia
I chose an all steel kit shed due to the lower cost and it was something I could put together myself.
I would have preferred going wider, but 5.4m/18' was the widest I could go with a single door span; and I didn't want a centre post getting in the way. It is 6m/20'deep.
Apart from pouring the extra concrete strip, I did everything myself, without help. I'm pretty proud about that.
The only tricks along the way were getting the levels right; the original driveway slab has fall to the front and to the side; and weather sealing around the bottom.
I sat the walls on galv angle above bitumised foam strips, and had to customise a new extension for the bottom of the roller door, (in hindsight I could've ordered this in manufacture, but nobody told me :headscrat).
The inside is almost complete awaiting a bench and shelving.
So here you have my shed build over the past year:
This is when I bought the property.
An extra concrete strip to allow for the width.
Down comes the carport. It was built like an aircraft hangar, but now I have some nice lengths for benches and frames.
Just like a big Mechanno set.
Put together the sidewall on the ground first, and stood that up against the side fence.
Made up raised pads to sit the baseplates on at the lowest points.
All looks good from here.
I sandwiched insulation panels between the frame and sheeting.
It has a polystyrene foam core with foil bonded on each side.
The foil is extremely thin, so handling it takes much care to avoid dents or rips!
The back wall and other side wall are shaded on the outside, so I only did the roof and hot-sun western wall.
Lock-up stage.
I added the roof ridge-vent to help ventilation and exhaust smoke and fumes.
And finally the current view.
Mini-me shed for the compressor, window behind the shade blind, and rainwater tanks slipped in the back.
Bib Overalls
Jonesboro, Arkansas
Looking good. A lot of very fine car projects have been completed in a garage/shop that size. Your old carport was kind of neat. To bad it had to go. But those steel beams will be useful.
ryanawesome
Wow that is a cool little shop. I would Be more than content with something like that right now.
Fueler
Urbana, IL
Please explain the reason and uses for the rain water tank. It's not something I have seen used before, at least in my area.
hudson48
Brisbane Australia
In Australia we have been in drought for several years.Many homes have now installed water tanks as using town water for watering gardens or washing the car is either restricted or banned.Our dam levels here even after recent rains are still below 40%
The cost of water here is going to keep going up in cost so the town water is for
essential use only eg drinking and showers etc.
In Brisbane(Qld Australia) a new home must have a tank of at least 3000 litres installed for
building approval.
You can also hook up the tanks to the toilets and laundry but they cannot be used for drinking or in showers or dishwashers.
Our new place has one tank at the top level under the carport of at least 10,000 litres and another underground tank near the main garage of around 15,000 litres.
Top one will be hooked into plumbing and the bottom for irrigation and cleaning cars.
http://www.garagejournal.com/forum/showthread.php?t=15015
C
Captain
Adelaide Australia
:+1:
Thanks Hudson for the accurate explanation.
Yes it's all about sustainability, and more so to hopefully be saving money in the future.
In my area water tanks on new homes aren't mandatory just yet, but it shouldn't be long. Don't know why they are taking so long as we're in one of the driest states! But most people are putting them in regardless.
The demand is pretty strong, I was quoted 5mths lead-time the other day, so I went elsewhere for my next tank which will only take 10wks :rolleyes2
Oh and thanks all for your kind praises.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
I like the blind. Is it Shade Cloth ? I am sure with the heat in the last few days your glad to have that over the window.
You call that a Tank ? I have two massive (5000 Gallon) tanks on my works as well as another two smaller on the house and yet a 3rd on my storage garage and the 3rd tank is just to wash the cars whilst it is so dry here.
C
Captain
Adelaide Australia
Yes it is. Just an off the shelf one that's a bit too long, but pulls down taught.
Also adds a bit of security against prying eyes.
C
Captain
Adelaide Australia
Bought off the shelf at Bunnings, lots of sizes available.
Means I can keep the window open for ventilation when the sun is directly on it too!
michael Mccoy
Athens,Ga
We here in the States are starting to get the message about water. Northern
Georgia has been in a drought and the city government is getting rain barrels for its residents for $20. Been washing my suv all winter with rain water.We also save the water in the showers {before the hot water comes}and use it to flush our toilets
CharlieBrown
Arkansas
would like to see some more pic's of the rainwater tank setup
my new garage..well..gonna be real costly to get water over to it
lotsa digging..hard rock..three concrete driveways and uphill to boot
gonna have a flush toilet..sink and shower
am thinking that would be a good fit for me
HOTFR8
Bunnings :shocking: :thumbup: thanks... I will have a look when next I am near the store.
Further on the water we have a Bio Cycle system here. All Grey water goes to an underground tank and then is pumped out to water the trees etc. round the property. 99% relain on rain water but do have a connection for the mains supply. Also have to keep a tank for Fire fighting purposes with a connection for the Fire Brigade. That is the same tank I use to wash the cars.
Sorry to Hijack the topic. Water is such an interesting Topic in Australia at the moment.
hudson48
Brisbane Australia
My friend in Dawsonville GA told me recently that Lake Lanier is at its lowest level ever and water is a real concern there.Fortunately he gets his from an underground supply(found by the water diviner) and he has unlimited supply.
In Australia the water authorities are looking at limiting peoples access to the water in the underground table.
C
Captain
Adelaide Australia
Sorry, what was that? . . . . What about the inside you ask?
Well alright then. :bounce:
(I've also posted these pics in the 2-car Garage thread, so apologize if I'm going over old ground, but it's pertinent to my project!)
From day one I said this would be a workshop, not for the drivers, so I have a couple of jobs lined up already!
The bikes are 1972 Yamaha L2G 100 Street.
The car is a 1962 Triumph Spitfire 4
I'll be starting the build of a 6' bench for across the back LHS this easter.
I'm also planning a small mobile welding bench.
Just a parts washer and sandblast cabinet and I'm set to go!
The floor is epoxy.
The shelving system (which is surprisingly strong and cheapish), the wooden boxes, and the drop lights, are all from that flat-pack Swedish company.
If I ever get keen I might line the walls, but that's way down the track.
Bazza
Caboolture,Australia.
Great shed mate, it is a credit to you:thumbup:
With that clear roof sheeting you would have got sun burnt the last few days in Adelaide with the heat wave.:):) Its been raining up here in QLD today.:):)
Bazza
C
Captain
Adelaide Australia
Yep, not shed weather at all, and it will continue for the next week. :eek:
But the insulation certainly is effective to keep out the direct sun heat.
Oh also, the clear roof sheeting is in fact tinted, so it's not all as bad as you would think.
I'll be interested to see how long the stuff lasts though, they claim the new plastics are pretty good.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
:wtf:I hope you never turn a hose loose in there:shocking: Garage looks great but why are the outlets on the floor? On the other hand, I really like how bright it is in there. Nice use of space. Even the vise mounted on the floor saves use of bench space. LOL!!!!Just kidding. I really like it.:thumbup:
Lofty_1
NSW country
Where did you get the insluation panels? Also what brand of shed?
Thanks
Plushy
Sulky , Victoria
The Shed looks great Captain :) I am curious how much the sheets of Foilboard were ? i need to insulate my 30x50foot shed .
cheers Plushy
bigjon
NSW Australia
Nice shed.
I've got a 1k L tank on mine plumbed to a sink inside for washing hands etc.
I also insulated with 'aircell' which is compulsory if you want to use it in summer.
Are those 'SP' tool drawers?
C
Captain
Adelaide Australia
I've looked around for the paper-work, but buggered if I can find it.:headscrat
I'd be guessing on the price, but as it comes in different lengths and thicknesses, it would be best if you gave them a call.
I got the 15mm sheets in 2.4m for the walls, and 2.7m for the roof.
I think they were just under the $30 mark each.
I found this info on-line (from a retailer) to give you an idea;
Price (each):
Standard 10, 10x2440x1200mm. $21.20
Standard 10, 10x2700x1200mm. $25.50
Super 15, 15x2440x1200mm. $26.95
Super 15, 15x2700x1200mm. $29.80
Ultra 20, 20x2440x1200mm. $32.30
Cathedral 25, 25x2440x1200mm. $38.20
Sorry I can't be of any more help.:dunno:
Yes they are.
I checked out quite a few before I decided on these. Very well made, smooth and strong drawer runners. Worth the cost.
