Wood storage
knedgr
GA
I'm looking for ideas to store extra lengths (various lengths) of wood in my woodshop. I know I'm looking for something wall mounted to get it off my floor. Shop is 10x20.
Please post up pictures of what you use. Thanks:rocker:
Jon
1949 caddyman
Arizona
I dont have pictures but I mounted 12" partical board shelving from HD using those gray metal bracket . Kept the lower one 50" above floor so I could have 4+8 sheets up aginst wall under the shelf. I then spaced two more above the first. Make them long enough for the length of lumber you expect to keep on them.
countrytech
West Michigan
It's not fancy, but here's what I did in my 12x16 shop. I just fastened 18 inch pieces of 2x4s to the wall studs at a 5-10(?) degree angle.
K
knedgr
GA
hmmm, slight back angle...hadn't thought of that. Thanks! I can't quite do it like you did since my shop is finished with drywall. But I think I can make some brackets no problem. Keep the ideas coming.
K
knedgr
GA
The old ladder looks to be a super easy solution! I have one that will work for that too. SWEET!
OldracerJones
Chico, Texas
I use the shelving under my workbenches.
They are 4 x 8 so std size lumber fits fine.
Sent from my iPad using Tapatalk HD
Shawn S
Brookings, SD
I have a fairly tall ceiling, so I dropped two 18" 2x4's from the rafters 24" apart, and put a four foot 2x4 on the bottom. I have two sets, 4' apart. I can put round things (pipe, closet rod, etc) in the center and it won't roll out, and lumber in the middle or on either side.
K
knedgr
GA
More great ideas. The Grizzley version looks to be very easy to do and will mount on the wall which I have plenty of wall space to use.
I would use the area under my bench, but it's already used for paint stuff storage.
Keep the ideas coming! All have been great so far.
FITO
East of KC
I think this was a Wood magazine project. I built this in an attempt to clean up my garage. It ended up taking a 44x56 pole barn to get my wifes car in there.
Currently its apart and waiting install inside a 16x24 wood room I'm building in the barn.
And yes I know the walls are a terrible color, It's on the "to do list".
K
knedgr
GA
Very cool the larger panel holder swings out to reveal pockets for even more storage between the studs. You just add over the top of your drywall?
FITO
East of KC
Yes, I lagged them to the wall studs and used a paddle bit to countersink the heads. Also used paddle bit at a slight angle to make holes for the black pipe. I'll try and find the link I copied the plans for.
FITO
East of KC
