Paint gun rack
OccupantRJ
Eastern North Carolina
I had bought a HF gravity fed paint gun a couple years ago to paint some of my flooded shop equipment as time would allow me, to refurbish some of it. Instead, I got it out last weekend and went at a home painting project in the works, painting 38 cabinet doors for my kitchen remodel. the gun worked better than I anticipated, so I decided to make a parking and refill stand for it.
3 inch pipe was sliced into short sections to make the rings, 3/32" X 3" steel strip was used for the base, and some 1018 steel, 1/4 X 1/2 was used for the structure, as this is what I had laying around. The steel rings were chucked in the lathe to receive a heavy chamfer where the paint cup and strainer would sit.
The milling machine was used with a 3/4" end mill to radius for the handle rest notch, then the angles were bent into the plate to match the vertical post and the handle angle on the gun. Mounting holes were also drilled into the base plate. The metal was cut on a vertical bandsaw, and bending was done using my shop built press brake attachment for the hydraulic press, presented in this link.
http://www.garagejournal.com/forum/showthread.php?t=64510 A beadblasting, along with some of my sail blue paint finished things off. Sure, I could have bought one for around $20, but what fun would THAT be? (see my sig)
chris fresh
savannah ga
i'm glad you posted this,i just recently got ahold of a top and bottom small craftsman box,the top box will become my sons first box and the bottom will be converted into a spray gun/body work box.the drawers will be used for tape and paper and such,but i was trying to think of a way to hang my h.f guns up top.
i'm thinking something very close to your set up and would hold 4 guns,thanks for the post and nice work on that holder.
O
OccupantRJ
hmm, 3" pipe, never thought of doing that instead of a rolled piece of flat stock or round bar.
Once you start slicing pipe in various directions and angles, the world of fabrication opens up in Creative and labor saving ways for you. I used to make stainless belt buckles by slicing pipe at a 45 degree angle, then cutting it in half on the diameter. Flip one piece, then put anoher square cut piece in the middle of them and tig weld to create an oval belt buckle where the middle circle holds a silver dollar, or other items. This guy makes a few.
http://stainlessbuckles.com/cata.html
O
OccupantRJ
Actually you can buy them for about $5...:D
But I would have had to drive for an hour and a half round trip to get it, burning gas, or pay shipping. I have less time and money in the one I made, hopefully inspired others to make things, and provided entertainment for YOU tonight. :bounce:
EOC_Jason
Bentonville, AR
Oh boy... here's the redneck in me showing through.... When I read the thread title, "paint gun rack"... I was thinking about someone painting their gun rack.... lol.... Yep, I'm from Texas...
Still, nice rack though.
O
OccupantRJ
Biggest reason that I made the stand was to have somewhere to park the gun between shooting cabinet doors, since I was painting one side of them at a time on a stand, then moving them to a drying rack in another building, to keep from tying up my shop space. I mounted it close to my spray area so I could just pick it up and put it down as often as needed with minimal effort. It worked great today.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Nice job. Those look way better than the cheapies that comes with guns. I may just have to steal that idea. :thumbup::thumbup:
buening
Decatur, IL
Excellent job! I need to get me one of these, its a challenge to hold a quart of paint in one hand, hold the strainer on the cup with the other, all while the gun is held between my knees :lol:
O
OccupantRJ
Since the gun was a $16 Horror Fright special, I originally considered it as disposable and clamped in a vise to refill. It shot way better than the suction guns I have used in the past, as the ability to see what I was painting was tremendously better, with the cup being on top. The weight of the hose seems to balance with the paint cup to give a little more neutral feel while twisting and turning to shoot certain objects. I am not a pro painter by any means, but for painting shop items and such, it was the bomb.
rharman
SoCal
Very nice. I'm thinking it may be easily replicated with PVC instead of black pipe.
