DirtRoad's pole barn soon to be shop
DirtRoad
Lowell, Mi
Well maybe not soon, this is going to take me forever, good thing im only 31 haha.
Me and the wife decided a year ago to sell our house and get out of the city. Me and the wife grew up in the country, dirt roads and all and we want our kids to grow up like we did.
So we sold the house, horrible experience to say the least. Terrible economy, we took a massive beating but better to take that beating while we are young i guess. We found the perfect house, perfect property, total seclusion it was exactly what we wanted.
I refused to buy a house without at least a pole barn or second garage. I ended up with a 20x40 pole barn. The original owners built this pole barn at the same time they built the house in 2001. The strange part is they never did anything with it, no electric, no work benches, no shelves.....absolutely nothing. Neighbors (if you can call them that) have told me that they have never seen anyone go into or out of the barn and the 16x8 door they never seen open.
First order of business was to get electric out there. Bought 1/0 AL direct bury from work, rented a trencher, bought a panel and all breakers i needed and got it done. Then i wired the barn and installed a **** ton of outlets and installed four 8ft T8 strip lights from home depot, i wired in pig tails from menards for them so that they would be easier to move around if i wanted to. I am going to add probably 6 more at some point.
Built an L shaped bench in what i would consider a wasted corner, its 16ft and then 8ft, pretty much the whole corner. Built just a single bench in the other corner. I have this thing about work benches, more the better, at some point the whole barn will have work benches all around it lol Built a few shelves and hung just one cupboard.
And now ive decided im not doing anything else to it until i get it insulated and finished.
Im kicking myself for not taking pics from day one.
Here is where i am now. Please excuse the clutter.
little d
NW Oklahoma
Nice job so far. Just keep puttin one foot in front of the other and next thing ya know, youll be done.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That's great that you got a new virgin building to work with. Too bad it's not deeper though. How do you plan to heat it?
D
DirtRoad
Lowell, Mi
I am definitely not happy with the size of it. The plan is to build a lean-to off back side and also build a separate shed, probably going to go 16x20 or so. If i can get all my lawn equipment and stuff of that nature out of it i would have plenty of room.
I have no idea how im going to heat it yet. Im just focused on insulating and finishing until its done and then figure out what i will do about heating it. I definitely want something that hangs from the ceiling or mounts to the wall, floor space is at a premium.
Bluepine
Grand Rapids Minnesota
Stupid question, are you sure its only 20 feet deep? Counting ribs on the end wall that appears to be 24 feet deep. The lawn mower is what made me question it, they are about 7 feet long on that model. But anyways I have a 26x45 and I like it.
D
DirtRoad
Lowell, Mi
Ya know i might be wrong, i have never actually measured it, i will report back.
Does the dog bite?
Oh man, dont get me started on that.
Basically since i have a pole barn and 4 secluded acres people start to think im running a storage unit. It *****. That damn dog is easy 150 pounds and it isnt even mine :lol:
The husq lawn tractor isnt even mine, but thanks to me it now runs now :thumbup:
NUTTSGT
Northern Central Ohio
I think you have a great place to start with. Just figure out which way you want to go with it, make a plan and do one thing at a time.
I'd think it might be a 24x40 too. If it was only 20' deep, that would make it an odd size and a little special on ordering trusses.
cbacres
SW Florida
I vote for 24' also, I was looking at the 8' lights, looks like you could almost stick three end too end.
Wish i "found" another 4' to my shop. Oh, never mind , its full alraedy.
NIce building to start with. A lean to addition will clear up a lot of storage area.
I would test the repaired mower for a couple of seasons. Seems fair.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
24' isn't too bad. When I built my garage though I went 28' as I had a fullsize extended cab truck with an 8' bed. It made a heck of a difference, You can always add on and turn some trusses the opposite way when you do instead of a lean to. Then you can gain some additional space behind or on front.
The only bad thing about a 24' depth is that if you have a larger vehicle, you can have a workbench up front.
NUTTSGT
I was thinking the same thing as Kevin, making a "T" addition rather than a lean to might give you more usable room.
D
DirtRoad
Lowell, Mi
As nice as it would be to add on to it i think the better option would be to build a large shed somewhere else on the property. It would look very nice plus it would keep everything out of my shop that does not absolutely need to be there.
I have another question, about lifts. My walls are only 10ft, do i have any hope of ever being able to put in a lift? I know that i will never be able to lift a vehicle so high that i can stand under it but if i could just get a vehicle high enough to be able to sit under it on my swivel seat would be enough to make me happy.
A problem i have with that "i think" is that my floors arent level at all, anywhere. There is two drains and the floors slope to those drains.
NUTTSGT
If you were to reconsider adding on the the front, keep the 10' walls and use scissor trusses, that might be give the room you need to put in a lift.
D
DirtRoad
Lowell, Mi
Compressor in, once i have walls i will hardline with drops
Tool area
Still need to get picks of my work bench setup, its a bit different now.
hippie2cams
Huffman,TX
looks like its going to be a great shop once finished. I am currently working on a 30x40 polebarn with 2x6 wall girts horizontally so I started on the walls first with r19 insulation and 5/8 plywood wall covering then insulated ceiling area with exposed trusses so I know what you are trying to accomplish. Keep up the good work and pictures coming. I lost all the pictures I took through a computer failure.
wheatley
I am dealing with this same situation. My wife and I just sold our house with a 24x36x12 barn I built in 2008 and along with it goes my rotary 2 post lift. Since our new home has a much smaller attached garage I started looking for lift options and came across the max jack by Danmar. There are also several scissor lifts from various manufacturers if that suits your needs to just get a vehicle in the air for oil changes and tire rotations.
D
DirtRoad
Lowell, Mi
Finally made some progress. Finished 3/4's of the back wall and put in a real air system.
Eventually the air system will wrap around the entire barn with many drops.
Bib Overalls
Jonesboro, Arkansas
Last year we built a 16" x 24" shed for our yard and pool stuff. Getting that miscellanea out of the shop made a big difference. Less dirt and less mess. It was an easy build and not as expensive as one of those ready made, stapled together jobbers they bring you on a flat bed truck.
D
DirtRoad
Lowell, Mi
Back wall is done, air lines are done, benches are done, shelves are done, central shop vac installed and my new shop ducks.
rixtrix1
Chandler, AZ (from west NE)
Nice start. Is there a reason why you have such a small diameter isolation hose on the compressor followed by another smaller run into you main air manifold. Seems to me there would be a lot of restriction there
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Dirt.....If in the future you do decide to add on, consider what Nutts said about adding to the front. Take the existing wide door you have now and just pull it straight out and leave the opening from one section to the other. You would not regret it.
D
DirtRoad
Lowell, Mi
I have found that restrictions arent a concern, no performance issues at all.
