Air compressor line at perimeter of shop?
5mall5nail5
Bucks County, PA
I am thinking of plumbing hard line around the perimeter of my shop when I get one. What sort of configuration works best? Steel/iron? Copper? Push-connect plastic? I am thinking of having a air port every 5 - 6 ft or so that way I don't need 50' hose. I do have a retractable hose reel which I will hang to bring out into the driveway, but I want to have a good system in the shop for various tools and tasks.
Thanks!
thightower
oklahoma
Steel works best, but a guy needs a threader install a system. Never seen copper. Never thought of push connect plastic, they do use that on road trucks. There is a company called garage pak, they have aluminum pipe and have thier own fittings. A little higher than others, but looks easier to install, they will help design the system.
Spareparts
Lansing Ks.
I put my compressor in the corner of my shop, came off it with a 3/4" Hyd Hose from there up the wall thru a Ball Valve to 3/4" hard copper tubing. "T" it off and ran the line around the shop, when I wanted a drop just put a "T" in pointing up with 2 street ells to help eliminate moisture. Came down the wall to a ball valve, a "T" for the quick coupling, and a 6" to 8" tube and another ball valve to drain any moisture out of the line. Mine is level all the way around and have not had a problem with moisture, but I do drain it down once a week.
djjsr
In the cornfields
There's LOTS of threads (and opinions) on this forum concerning air systems. Do a little searching. Seems like most guys like black pipe or copper with 3/4" main line and either 3/4" or 1/2" drops.
5 or 6 feet apart is really VERY close together.
Mine is copper, with 5 drops down the middle of the shop, 12 feet apart. If I had it to do over, I wouldn't change a thing.
Just my opinion.
5mall5nail5
Bucks County, PA
Just my opinion.
It seems like a lot but I have a lathe, welding table, TIG welder, eventually plasma, few work benches, bandsaw, drill press, etc., and like to be able to blow off the tool or need air to the tool, so I don't want to have lines draped from various places.
Shootingblanks
North Canton, Ohio
bobadame
I used a combination of 1/2" copper and 1/2" black iron pipe. Had some leaks in the iron pipe fittings. No leaks anywhere with the copper. Copper was easier to put together and instal.
GTOGreg
Fremont, CA
I used copper 3/4" coming off compressor and then created 1/2" drops where needed. Works great and has eliminated any moisture in the system. My drop legs look similar to shootingblanks, but I did a wall mount so needed to use some angle pieces to work around the main piping and do the drop. TP Tools has some great illustrations on their website, and will sell you the bits if you want to use iron pipe.
Though I can't complain against the performance of what I built, for ease of installation and to get more coverage, I might have used the new garagepak aluminum 3/4 system.
lilscorpion
Colorado
I've used copper and black iron. Learned the hard way that the moisture in the compressed air will cause the black iron to rust. An up hill air dryer will solve that (for the most part) but copper works well either way. The new garage got copper for that reason.
NitroShark
Greenville, SC
Use Black Pipe.. but,You will need a method of threading it. That's all I've ever used for many years.
Be sure to install the black pipe going down hill..
Shawn
kbs2244
Use at least ¾ if not 1 inch for less friction to the flow.
The big box stores sell black iron in 10 foot lengths and threaded at both ends.
Put a tee at the end of each piece.
Do the up, over and down the shooting blanks shows it.
Except, you want some slope to the horizontals going to a drop pipe that does not follow the up, over and down so that the water will drain into it.
A drop pipe every 10 feet means you only need a 5 or 6 foot hose to cover anyplace on the wall.
Tptools has a good layout PIC
http://www.tptools.com/pl/Images,metal_pipe_kits_L,74,2035_Modular-Metal-Piping-Kits.html
bullnerd
Jersey
"I've used copper and black iron. Learned the hard way that the moisture in the compressed air will cause the black iron to rust."-I second this.Worked in shops with pretty nice setups and the pipe still rusted.
Copper for me.Absolutely no PVC! IMO of course.
Falcon67
Merkel, TX
I have all that except the TIG and plasma - have a total of 4 drops and a 50' reel in 960 sq/ft. No problems with access. Yes, once in a while I pull a coiled vinyl hose out 10~12' or so. There's maybe one place I'd put another drop but I'm not "excited" enough about the need to hack into the middle of a 20' run and punch a hole in the wall for the drop. I did a plan based on were things landed in the shop and how I work and ran the minimum pipe necessary to supply the planned drops.
I put my compressor in a closet with a home brew "dryer". The runs branch out from the closet. Most are iron but the ones that run through the attic to hit a couple of locations are Goodyear black high pressure hose. Because I'm lazy and pipe fitting was way overkill.
A photo from back when the runs were partially completed:
NUTTSGT
Northern Central Ohio
You may not need a drop at every tool but in the middle of two would make it nice.
SeattleKent
Redmond, Washington
Mine looks just like the shooting blanks install. Based it off the TP Tools design. The up/over/down for each drop works really well. I have had zero water/mosture problems. That is a little surprising considering I'm in rainy Seattle.
Black iron was difficult to work with. If I were to do it over, I would try copper.
rslaback
Westcentral Wisconsin
Copper is the easiest to install and to cut into later if you want to change the system. Flexible systems are always droopy and look like ****.
Jere
I don't have any system but I have been thinking about just running black rubber hose around. Then cutting it where needed and using brass barbed to threaded fitting and hose clamps. That way it will be rust proof and cost less than a hose reel from HF. Maybe mount it with electrical pipe conduit brackets.
5957860501p
vjlobel
Greensburg, PA
At work we just installed this system, and I was pleased with it- It's from RapidAir.
http://www.northerntool.com/shop/tools/product_200367525_200367525
It works a lot like a pex system, super easy to run and route. It's usually around 100 bucks for enough to do a garage and three drops.
If you need more capacity, they have a system called Maxline (Also available at northern tool) that is 3/4 pipe and designed for industrial systems. Just be careful, because that is plastic with a metal core and much harder to straighten out. The thinner stuff is pretty easy to work with if you leave it in the sun for a few hours.
All of these systems also sell parts so you can add on to them, and can be easily removed and taken with you when done.
hughfree
Fayetteville, GA
I have decided to use type L copper. The additional cost of materials is offset by the ease of installation and ease of modification / repair....
mdale
Indiana
Is 1/2" or 3/4" pipe needed for 3hp 60gal compressor and about 50ft of main line with 5 drops?
oldmerc
Edmonton , Alberta
I used copper , it's fairly cheap ,easy to install ,no special tools and if you don't know how to solder here's a chance to learn .
lilscorpion
Colorado
It is a good skill to learn though now-a-days you can get by with shark/gator bite fittings is money is falling out if your pocket and the desire to learn isn't there.
akdiesel
Wasilla, AK
hughfree
The air lines look great. Nice clean straight work.
mdale
Its not so much the need for the air compressor but the need for the tool being used. If you can afford 3/4" than use that. Most tools in a residential garage only need 1/2" but as you grow and want things later in life the larger line will be in place and ready for what ever tool you get.
Coloshaver
Northern Colorado
I used black pipe. I ran about 70' of 3/4" around the perimeter and 1/2" drops where I planned to use air - over my bench, by the lift, on the back wall and a 100' hose reel by the garage door. I bought a HF threader which worked fine for the job and has some life left in it.
>>The only thing I would do differently is put a few unions in. After I got it all up, I checked for leaks. Fortunately, there were none. My compressor will go over 24 hours without cycling, but as I was studying my work, I realized that if I need to change my filter/regulator, I will have to unscrew every piece back to the regulator :eek: or cut the pipe and reassemble it with unions. In case you hadn't thought about it, you can't unscrew a piece of threaded pipe in the middle of a run. (Unscrewing on one end, tightens the other :shocking:)
Another step on my path to "Good judgement" (see my sig)
Sureshot
Bridge Creek, OK
That link is ok but the reasons for not using copper are:
Avoid copper tubing, as it is easily damaged; and soldered joints can come loose under pressure (Safety Hazard).
Seems like a very lame reason. I have had mine in for 12 yrs with employees and renters etc and never saw any damage and if your solder joints come loose well you need to learn to solder.
Takes away from their credibility IMHO and makes me less inclined to believe any other claims they have.
bluejeep
Pearland Texas
I just finished piping my 40x50 barn with black iron pipe. I used 3/4 inch line for the main lines and 1/2 inch for the drops. Use lots of unions.
Curtis_Peterson
East Bethel, MN
With the reciprocating compressors being the majority that I see here. The water pumped down line would push me towards copper. Black pipe will not last as long as copper. The chance of solder joints coming loose I would think is pretty slim. If you are doing the piping yourself, chances are you are handy enough to get the joints pretty decent. My choice would be between copper and aluminum piping IMO.
akdiesel
Wasilla, AK
bluejeep
Nice and clean set up.
Curtis_Peterson
Don't let water stop your choices. If you have that much water in your lines that you are worried about rust, then you really need to redirect your attention to stopping the water all together since it will ruin your tools much sooner then rust out your pipe.
If done correctly all three will provide a longevity of use that will more likely outlast you.
