My oiltank sandblast cabinet
NASTYZEN
St-Colomban,Que. Canada
I've been asked by many members about my blast cabinet.
Here are Scrapart's Questions.
How did you do the door seal and what did you use for the seal ?
What is the need for the vent on top?
How big is your viewing areas ?
What are you using for latches?
Gloves and how did you seal them?
Why does the sand flow to the center of the bottom?
How does the pickup work and why couldn't one just lay the hose on the bottom with a screen?
How did you seal the incoming lines ?
First off, make sure your tank is free of oil!!!!!!!!!
Mine was old n rusty. If your using a more recent one, have it steam cleaned first. Or you may end up in orbit.:(
In order to be able to seal the doors. I first cut the end caps off the tank leaving about an inch or so from the ends and then welded in a 0ne inch flange, both on the the doors and the tank. Using 1/8'' x 1.'' flat bar.
The seal itself is weather striping from the hardware store.
The hinges came some old doors and are welded in place with a gap for the weather striping.
I used lunchbox type latches from Spae-Naur. Hardware stores probably have them.
One thing I would change is to put a seal across the middle of the door instead of a deflector plate to keep the sand from getting in that part of the blaster.
I use a noisy shop vac to clear the finer particles out so you can see. I built this outlet with only the bottom open to try to only remove the finer stuff.
That's why you need an air inlet as far from the outlet as possible
A cyclone separator would be the best. Maybe some other member has made one and could show us how it's done?
The windows are 9'' X 24'' . I made some frames out of 3/4'' X 3/4'' X 1/8'' angle iron and made a matching opening in the tank. Then welded them in.
There is a thin weather strip between the glass and frame. The windows are held in place with 1/2'' square bar that has been drilled for 10/32 screws that thread in the frame.
I used regular light sockets and bx wire for lighting. Used 16G. sheet to make the lighting boxes and made some caps out of Alu. to house the switch and wiring on top.
I got the gloves and blast gun from the local automotive shop. I think the gun is a King brand.
To hold the gloves in place I made holes and welded in a ring or flange to be able to slip the glove over and tie it in with a hose clamp.
To be able to have the sand flow to the collection tube. I cut the bottom of the tank off and replaced it with a cone.
I built the collector with a 2 1/2 pipe ****** and cap to be able to remove it for maintenance and used a 3/4'' tube for the pickup.
In order for the siphon to work, there is a 3/ 16'' hole drilled ahead of where the hose ends inside the tube. Works just as a paint gun would.
Finally, The holes for the lines are really tight to the size of the hoses and make there own seal.
Hope this answers most of your questions.
:beer:
ADSR
That's just awesome right there! Very inventive!
Bar Ditch
Tacoma
Thanks NastyZen. I just got rid of my 6ft cabinet and decided to use my old oil tank for my blast cabinet. I have been looking for a good tutorial on a oil tank blast cabinet and this fit the bill.
Would you suggest glass or plexi for the window so it would be easily replaceable? Or is this not a concern with this setup?
N
NASTYZEN
I use plain 1/8 glass. About 20 bucks for both. Never had issues yet.
sberry
Brethren, Michigan
A quick fix would be to set the vac outside? The separator is the good solution, I have done that somewhere along the way.
I bought a little Cloarke cabnit but never rigged up a good way to clear it but rarely use anyway, just am not doing old rebuilding and on the occasion I go outside and whiz up a blaster. Tractor rim etc.
A blast cab was a tool I tried to rule out, hahaha
sberry
Brethren, Michigan
Your solution is good for your space constraints I would imagine. Seems I saw a big commercial version of this in a grain bin also. I have made a few things from those tanks over the years. I heat my shop with one, big ole door in front.
Rampy_au
Hmm, seems to be way tooooo much dust on the outside of your cabinet!! Sucking all that **** into your lungs can't be good.
69supercj
I changed my Dayton cabinet from a negative pressure cabinet to a positive pressure and I like it better. Much quieter and better visibility.
N
NASTYZEN
I don't use it all that much. The main problem is the shop vac itself. pos!
Pic's? Can I convert or adapt what I have?
I've been wanting a cyclone for it but just haven't gotten around to it yet.
To busy trying to keep up with all the equipment needing repairs around here lately.
N
NASTYZEN
I'm set up on the second floor. I wonder how a shop vac would fair here in Que. It was -30c this morning could be +5 in couple of weeks. The humidity...
It would need to be in a box. Insulated?
There has to be a better way.
69supercj
Don't have any pics but its very easy to do. All I did was mount a small squirrel cage fan onto the side of the cabinet at the inlet air hole and then connected a hose to what was the vac suction and ran it through the wall of the shop and put an elbow on it outside pointed down to keep rain/snow out of it. I had gone through two shop vacs and just didn't like the noise inside the shop. The squirrel cage fan is hardly noticeable when its running and I'm still on my first one. You will probably need to make sure your cabinet is sealed up good, I need to spruce my up a bit as I'm getting some dust and grit on the outside but I'm using 3 or 4 ot glass beads so they're very fine.
