DirtRoad
Had a 33 gallon craftsman oiless for 10 years. It worked great for what it was, never skipped a beat. It did most everything i needed it to do, just couldnt run die grinders, cutoff wheels, sanders or paint. Always had to go to my buddies place to do those things, not very convenient.
Got the chance to go get a 60 gallon single stage, i know its not much to some people but for me its amazing. 11.5cfms at 90psi is a thing of beauty, especially when your used to 5.9cfms at 90psi.
Decided on the Husky at Home depot, it was the cheapest 60 gallon single stage i could find. TSC had a CH for the same price but i just couldnt get past the ugly grey painted tank they use now.
They loaded it for me with a fork lift. Then i just slid it where i wanted it. I used deck screws and screwed the pallet right to the deck of my trailer. I bear hugged it and pushed and pulled it HARD, it wasnt going anywhere. Just for good measure though i used two ratchet straps over the pallet.
I didnt have much money left after buying it so i had to use what i had for the most part just to get it up and running. Already had the wire, breaker, 25ft hose, ball valve and hose real.
So i went to harbor freight and picked up their reg/filter combo. Little nervous at first but it works perfectly, no problem at all.
Just have to redo the drain valve like i did on my craftsman and im good to go i think, for now.
Anyone have any ideas on what i can do to plump it better?
The problem i have is that im going to be doing the walls this fall and i dont want to spend a ton of time and money plumbing it over to my hose reel and then have to take it all back down and then redo all of it.
Every wall will have a drop after i get the walls up, but in the meantime, what options do i have?
Im also nervous about water. The filter is collecting it great from what i can tell. You can watch water spit into the bowl when your running a tool. There is so much in fact that im nervous the filter isnt getting it all. I cant feel any water when i use my blow gun, but that dont mean anything.
Any suggestions?
Any suggestions?
