'64 Binks compressor - Free!
RivennHewn
PNW
Free is always good.
Wonder how much it's going to cost me.
R
RivennHewn
PNW
More pics
CNGsaves
KS and OK
Never had heard of Binks compressor before . . . what are the specs??
Looks like durable industrial compressor but tank is small. Is that 40 gallon??
WWIIjeep
Arizona
Definitely a great score. Binks compressors were top-notch back then. The pump is actually a Quincy.
I can't quite make out all of the model number in your photo. Looks like it might be 33-1016? If so, it's a 2-stage 1 HP, 140-175 PSI, rated at 5.8 CFM displacement and 4.0 CFM delivery If not that, post the model number and I can give you the specs.
Both Binks and Quincy are still in business, although they don't necessarily support all of their older products.
R
RivennHewn
PNW
it is a single phase dual voltage motor with 20/10 HP.
Model number 33-518
type 33-1019
Under the sawdust, greasy, oily coating, it almost looks like new.
The tank had a lot of water in it, which is concerning.
Where would I look to find someone to test the tank?
I'll have my electrician look at it on Monday.
If the tank checks out and motors good, I'll start looking into a rebuild
of the pump.
Should be a fun project!
zkling
Model number 33-518
type 33-1019
of the pump.
Free is always nice. Your comment of "How much is this going to cost me" made me laugh. So true, some of the most expensive projects are one that we aquire for nothing. :bounce:
Are you sure on the 10/20hp thing with the motor. That does not look like a 20hp motor or a 20hp compressor. Looks like ~ 40gal horizontal tank. Plus a motor that large would have multiple drive belts.
Post a better pic of the motor plate and compress plate. Looks like a nice unit for free. What is the background story on it?
I think this is a manual for it
http://www.sistemasparapintar.com.mx/boletines/binks/1767r-2.pdf
WWIIjeep
Arizona
Model number 33-518
type 33-1019
I think you might have the motor amps mixed up with the motor horsepower.
33-518 is a single-stage two-cylinder pressure-lubricated (Quincy) pump, rated for 1 or 1-1/2 HP and 100 PSI maximum pressure.
With a 1 HP motor, pump speed 510 RPM, displacement 5.8 CFM, actual air delivery 3.8 CFM @ 100 PSI.
With a 1-1/2 HP motor, pump speed 810 RPM, displacement 9.2 CFM, actual air delivery 6 CFM @ 100 PSI.
Ideally you should have it professionally inspected and hydrotested regardless of what anyone may suggest for do-it-yourself testing. Look for "hydrostatic testing services" in the yellow pages, ThomasNet.com or Google.
R
RivennHewn
PNW
zkling:
Thanks for the link.
Here is the plate:
Looks like I was reading it wrong
Yeah, I would want to get that tank 'scoped and pressure tested.
of the pump.
Clean it, change the oil and fire it up. If it is not making any knock sounds don't waste you time and money on a rebuild.
R
RivennHewn
PNW
The compressor was abandoned in an old 1920's building.
A developer bought the building, and the company I work for restored it.
The last tenant was a Hard Hat Supply, and before that it was a marine parts warehouse.
Who owned it, and what it was used for I don't know.
metaldad
nw indiana
Probably served the building, as the source of compressed air for a pneumatic temperature control system. There may be moisture removal components bolted to a wall or shelf somewheres.
CNGsaves
KS and OK
^ ^ ^ This. Clean her up, change oil, check belt tension, and see how she runs. Don't forget to also clean out the air cleaner.
Let us know how quick it fills once you fire it up, and whether it passes the leak down test.
Again . . . . . . YOU **** !!
theknurl
SoCal
my 40 gal 1946 dated tank rusted through.....at the drain bung....welding stress made it rust there faster
jacked it up, cleaned the area and MIG welded it back in...:thumbup:
that was 20 years ago
when tanks rust out.....they get a pin holes.....and leak BFD
R
RivennHewn
PNW
Got my electrician to rewire the compressor for 115V.
Plugged it in and it runs sooooo smooth and quiet.
Still need to get the tank looked at, but I'm loving it!
