Epoxying your floor when it's cold outside
bmwpower
As always, I've run out of nice warm weather. I have gas heat in my garage already which I was planning on running when doing the floor. I see no reason why I can't crack a couple windows, crank the heat up, turn the ceiling fans on, then epoxy the floor. I'm using Armorseal on the floor.
Anyone do this? Any thoughts?
Hammerdown
The Motor City
Which grade of Armorseal are you using? Be careful, some of these products are a solvent based flammable liquid and will emit flammable fumes. Bring the heat up prior to application and then extinguish any exposed flames or pilot lights. Do not turn on the fan because excessive air movement can cause epoxy to flash cure and the coating to wrinkle or bubble. Use exhaust ventilation only. The cooler it is the longer it will take the epoxy to cure, so have patience before use to avoid damage.
bmwpower
I'm using Armorseal 1000HS, which is solvent based. I'd like to keep the ceiling fans on since it helps in the heat movement from the ceiling down, otherwise the heat stays up at the ceiling. They're not pushing too much air, just enough to circulate the air. I'll have to test the heat with the fans off to see how high I'll have to turn up the thermostat to get heat at the floor.
How long does it take once the epoxy is down before the fumes subside?
I'm going to epoxy 2 courses of cinder block first, so depending on how well that goes, hopefully I will do the floor soon after.
logical
Northern fringe of the Motor City Suburbs
Be sure to get the actual floor temp up and not just the air temp. I would only attempt this if you can run the heat for several days before doing the floor and then get the heat back on it after applying for several more.
krooser
Waupaca, Wisconsin
The solvent odor diminished in my shop in about four hours...with the doors open. I would THINK you could ventilate the fumes with a window fan in less time..and safely use the furnace.
Just heat it up first...try for a warmer day to do it...40's should be do-able in your neighborhood.
Hammerdown
The Motor City
The fumes would usually dissapate within the first 6-8 hours or so @ 68 degrees. Once the product cures to "tack free", it usually stops emitting odor. Bring the temp up to about 70 degrees, turn it off and coat. Be carefull with the fans, what may not seem like a lot of air movement to you can be to epoxy. Well ventilate the area.
krooser
Waupaca, Wisconsin
Just make sure it stays above 50 or so...my helper did one coat and it got down to 32 overnight..the finish went "flat" and we had to sand and recoat it...
muddy
BMW.......
You can check out the armorseal I just put down almost a month ago.....I purposely waited as long as I could until the forecast called for sub-50 weather then I went ahead and did it. It takes a little longer to cure but as long as it's fifty your okay.
My sherwin williams recommended fifty percent reducing the first coat. After doing it on the garage that way I decided on my shop to just reduce twenty five percent and I was happier with how it went on.......
If you look in gallery under detached building photos five you'll see my floors. When I did garage on the house I'll say my wife complained about fumes for a couple days but I didn't open garage door much. Good luck........ Keith
JayB
Canada EH!
The concrete extends outside a few inches past where the door closes down. The line left would be a bad thing to him?(maybe me too?)
Funny story;My boy & I were checking it out after he did it & my boy says "look at all the bubbles....there's millions of them!"(fish eyes in the paint) Well after getting stomped by a 5 year old,he sanded & repainted the garage!!
Did you check out his paint booth?(I call it his gimp room) It's awesome! The core drill was pretty cool,heavy though!
bmwpower
Bubbles in the entire floor? Or just the apron?
I think normally people stop the epoxy at the stepdown to the apron, thus not painting the apron.
bmwpower
Well...first coat is down...
I went ahead and put a first coat on the floor. Took me about 2-1/2 to 2-3/4 hours to coat the floor (850 sq ft). I reduced the epoxy 1pint per gallon as recommended by Sherwin Williams. I think it turned out great. The sad part is I wasted about 2 gallons of epoxy (gulp). I ended up only using about 2 gallons of my 4 gallon batch. Looks like Sherwin Williams coverage numbers don't hold up when you reduce the mix. Oh well, lesson learned. When I do the second coat I plan on not reducing...we'll see.
In any event, it's now close to 8pm. I started a 1pm, so I'm getting ready to turn the heat back on...I let it run at 70 degreees for several days.
I did everything possible to contain the heat inside the garage. The forecast for today was high in the low 40's. I insulated the entire perimeter of the garage block wall with 2" rigid foam insulation. In my testing this has kept the floor a couple of degrees warmer than without the insulation. To monitor the temps during the whole process, I used this wireless temp monitor thing I got last Christmas. It worked great. I sat the unit on the window sash so that it would be viewable from outside. The top temp shows the air temp right inside the window, which is usually colder than the air temp inside the building (at the time of the picture, the air temp in the building was 64 degrees). The lower temp is the temp at the wireless sensor site. I placed the wireless sensor on the apron, right inside the garage door. This location is the coldest part of the floor, so this will be my "worst case" temp if you will. In my testing the floor surface is up to 5-6 degrees warmer than the temp at the apron. I have another LCD monitor like the one in the window inside the house. It communicates to the wireless sensor as well, so I can monitor the coldest temp from inside the house (really cool).
To vent the fumes, I borrowed my parents window fan. It has a wireless remote to enable you to turn it on an off from a distance. I've used it to throttle the venting of the fumes since it has a low and high speed. Once the floor was coated, I kicked it into high so the room would vent better, but I kept it on low while I was coating to help keep the heat in the garage. Also, to help contain the heat from escaping the window, I put a towel on the outside of the window. This keeps any wind/cold air from entering the garage. When the fans are on, the towel still allows the vapor to escape, but heat is still retained somewhat in the garage. I did testing without the towel and the temp in the garage would drop 15 degrees in about an hour (yikes), which is why I came up with the towel idea. With the towel in place, the garage only lost 6 degrees in 5 hours...amazing.
Also, I used a hygrometer (just inside the window...originally on the floor, but moved for obvious reasons) to keep an eye on the humidity. One thing I noted, once the coating was down, the humidity dropped to almost 20% or less. I took this to mean that the "humid" air was being displaced by the coating vapor. Now as the coating starts to cure (and loses solvent), the humidity comes back up to where it was originally. This may be helpful for others when coating their floor, as this may help gauge the vapor content of the room.
I also used an infrared thermometer (Raytek MT6) to gauge the temp of the floor in various locations, too. Before coating, all locations where at least about 58 degrees, with the middle of the garage being close to air temp (70 degrees).
Oh yea, that gray patch on the wall is a test. I was going to use the remainder of the epoxy to start coating the walls, but I decided I better test it out first and then coat the walls when the floor is done. I'm glad I did, as putting epoxy on the wall was not really easy since there are so many little voids to fill (even with the block filler). It would have taken a while to do the floor AND the wall at the same time.
Hope this helps anyone else in a similar situation. Coming soon.... 2nd coat.
