What's this Speedaire compressor worth?
skelrad
I'm looking for a solid 30ish gallon compressor. Found this one, but not sure what it's worth. 3 hp Speedaire three cylinder 2 hp motor 115/230 volt 1755 rpm 22/11 amp. It is wired to run 230v single phase.
Asking $250. What do you think?
zkling
I don't that it is bad price, then again I don't think it is a "you ****" either.
Depends on if it has the CFM output you need. With that motor I would guess a CFM output of ~6CFM at 90psi. But that is just a guess.
skelrad
I'm going to get some more info on it tomorrow. My problem is that I have a bad habit of always needing the "you ****" price when I buy things used. Always been that way, probably always will be. But I've got a lot more money in the bank because of it! So we'll see how it pans out. Thanks for the feedback.
larry_g
oregon
I would double check the max pressure on that. Some of them were in the 60-90 psi max range. Looking in my old catalogue that looks to be a 3Z170 pump head rated for 100 psi, 650-900rpm, and 8-10 cfm with a 2 to 3 hp motor.
lg
no neat sig line
mayday0017
Houston Texas
I would try to get it for closer to $200, I would much rather have it then a newer one with the same CFM specs. I say this because I would be willing to bet that compressor is very quiet. Go take a look at it and hear it run, also speedaire is Granger rebrand of CH and Champion compressors so parts should always be easy to locate, just figure out who really manufactured the pump. I do agree that it looks like a Champion 3Z170 pump.
djjsr
In the cornfields
I would definitely buy it. If you spent $250 on a new compressor, it would not be anywhere near the quality of that one.
Tap on the bottom of the tank to be sure it's solid.
skelrad
Yeah, my big worry is the age - I don't know if I can get parts if something goes south on it. I'd hate to spend $200 on it and have to put $200 more in on parts. My guess is it's around 30 years old.
skelrad
I had pretty much written off this compressor because I had to leave town for a few weeks, so I figured it would be sold by the time I got home. Not only is it still available, but the price dropped to $150.
It doesn't look to me like the tank is original (check out the weld job on the mounting plate in the first post), which worries me a little. I've only seen tanks that have the end caps welded on, but this one looks like it's welded down the center only. A newer tank (relative to the age of the pump) may be a great thing, but not if it's some sort of backyard propane tank job or tin foil thin or something. Any idea what this is? I obviously just want to make sure it's safe!
Here's another pic:
[URL=http://s913.photobucket.com/user/bryostdc/media/3M33J93H55G95H15Jdd4ta4436125c6e11118.jpg.html] [/URL]
zkling
For $150 if it runs like it should I think I would grab it. :thumbup:
As for the tank. That square plate on the back side, upper right hand corner, should tell you all the specs on it. Make, date, capacity, pressure, etc. See if the current owner will let you pull the two plugs on the back of the tank. Put a flashlight in one hole and look in the other. See if there is a bunch of rust or any other signs for concern. If not, I would buy it.
