Help! Multiuse bench, with quick swap. Show me yours
Alexbn921
East Bay Nor Cal
Hi
I have an 8x2 foot outdoor bench that I use for messy projects.:bigun2:
I set it up with three sections 4ft, 2ft non-removable and 2ft that lifts out to make an outfeed table for my chop saw.
Right now I clamp my grinder, buffer, vise... to the corner of the table. This is a multi-use table and I don't mind drilling holes adding/cutting as long as the different setup don't interfere with each other.
Now show me your setups.:drool:
A
Alexbn921
East Bay Nor Cal
Hey taumac
I see that you have wood attached to most of your grinders/vises. I want to do a similar setup. Any advice or pictures on your setup?
taumac
Brooksville, Fl
Thanks for noticing that. I mounted both grinders and 2 vises to wood cause it made it easier to clamp down wherever I choose to use it. I tend not to like things bolted on bench such as grinders and vises but I did bolt 3 of the vises down bit still have 2 on wood still to use anywhere. I havnt decided yet on a system but was thinking bench dogs like a wood worker or on the heavy gray table of making 2 reciever hitches on each side of drawer so when use a grinder or vise I can mount and remove. I did at one point had a 2 x4 mounted on grinders and used vise to clamp them down. That wouldn't be bad idea with carpenters vise for your set up.
taumac
Brooksville, Fl
If you look through think part 1 you'll see my welding/ mutli use table I built. I did cut it up cause it was great it took up a lot of room and was heavy. Then there was cut down version with tool box and now that also cut up. I will be using that flip idea on but on my roll chest one for welding and other just made of wood. I just ran out of space for a big table like you have and found smaller tables work better for my space. After all the years of tables and benches I've made I find that mounting vises and grinder and other tools such chop saws on wood and clamping them down I find to be easiest way. There was a table with like a say 16x16 square cut out of top and all tools mounted to wood you could clamp down in the place and rack that held all the tools. Below it what I use as my current heavy table/ welding and it on casters and had it out welding in new drawer to mount so can fab up a reciever hitch idea to that's better than clamps.
