Hencini's Garage / Workshop
Hencini
Hi all--
I'm a long time reader, fairly recent member and occasional poster, but this is my first thread. This site has been a tremendous resource both in terms of ideas and practical knowledge.
As a "city dweller" my whole life, I've never really had access to a decent-sized garage despite all my petrol-related hobbies. When we recently relocated to Memphis, TN for my wife's job, one of my top priorities was finding a house with a large garage and given the neighborhoods we were looking in, I did about as well as I could have.
It's a detached two car with an attached workshop. The bays are just under 19x20 and the workshop is about 8x14. Right at 500 square feet total. I would have preferred an attached garage, but in this neighborhood of 100 year old homes, there is no such thing.
The stable currently includes my 1998 M3/4/5, 1983 Jeep CJ-7, 1983 BMW R65LS and Mrs. Hencini's 2008 Vespa LXV 150, so it gets a little cramped in less than 400 sf of bay space.
Someone had done a marginal job of drywalling the bays and about half of the workshop. The other half of the workshop is the dreaded pegboard. It has a pretty basic work surface built in on one end of the shop and I brought an old set of lab cabinets and countertop from our old house for the other end.
There are fluorescent lights throughout. Four 2x60" lamps in the bays and one 2x84" lamp in the workshop. I will probably add some additional lighting over the work surfaces and may eventually replace one or both surfaces with something nicer. The garage also has a 100 amp sub panel and a 240v outlet, but my welder and compressor are both 110. I may add A/C in the Spring, though, so the 240 could come in handy.
Currently, the workshop houses our lawn and garden equipment in addition to a lot of my car stuff, but I'd like to put up a small shed on the side of the garage to free up some space and keep dirt and grass out.
I started painting Monday. Unfortunately, there was no time to work on the garage when we moved in six months ago, so I had to unload all the moving boxes onto some existing shelves and some plywood and 2x4 shelving I made in an afternoon and then turn around and unload those same shelves before painting.
I did the walls in a basic gray with maybe a hint of blue in it using Sherwin Williams SuperPaint flat. I would have probably gone with an eggshell or satin for better cleanability, but we had two gallons of unopened light tan paint in the basement that we weren't going to be able to use, so I had my man Fred at SW tint them up to a nice gray. The flat will make it very easy to touch up in the future and the SuperPaint is actually quite durable.
The pegboard looks about a zillion times better, plus the workshop is much brighter now that the brown pegboard is gone. For some reason, I can't find a pic to prove it, tho... :)
The big project this week was the floor. Holy hell.
After reading probably hundreds of flooring threads on here for the last nine months, I finally pulled the trigger on VCT. It should be adequate for my needs and the price was right. In the Spring, I will probably add a clear epoxy over it for a nearly bulletproof finish and to protect the tiles from yellowing under the tires, but for the time being, I'll just be happy to have a smooth, easy to clean floor. I've got many projects to do on the vehicles this winter and I wasn't looking forward to doing them on a nasty concrete floor.
When I built my shelving, my goal was to have anything without wheels off the floor. In the pics above, you can see how I used some basic, off-the-shelf hooks and hangers for my Jeep doors and back seat.
Because most everything was already off the floor, prepping the concrete was easier than it would have been otherwise. I moved everything (including the motorcycles) into the workshop and went to work with a grinder and cup brush on the globs of paint, joint compound, etc. on the floor. I used a Henry Feather Finish patch product (which is pretty impressive, by the way-- even faster drying than Quickrete) on the divots in the floor. The deeper divots required a second application, as they shrunk considerably.
I scrubbed the floor three times with a 12 oz:1 gallon mixture of Zep Concrete and Driveway cleaner. It did okay-- a ton of dirt came up and the floor definitely looked better-- but I still wasn't happy with some of the oil spots. I went at those the old-fashioned way with a brick and some kitty litter, then scrubbed those spots again. In the end, there were still some stains, but no water was beading on the oil spots, so I called it good.
For tile I used Armstrong Excelon in Blue/Gray and Classic White and Roberts 2057 glue. My biggest flaw as a DIYer is that I do tons and tons of research, but when I'm ready to roll, I can't wait to order anything-- I almost always do all off-the-shelf stuff. Luckily a HD near me had the blue/gray that I wanted, although I probably would have used the Armstrong VCT adhesive if I could have found it easily.
When I went to pick it up the tile supplies at the Depot, the guy helping me jokingly suggested I also buy three cases of a ruby red VCT that a customer custom ordered and returned. At that point a light bulb went on over my head. :)
Spreading the glue was pretty brutal. The floor had a slightly rough finish and I only got about 90-100 square feet out of a gallon of glue as opposed to the 160 or so they advertised. I used exactly four gallons on the 19x20 bay space. Because so much glue was trapped down in the "grain" of the concrete, I had to be very careful to spread it as thin as possible and it took quite a while for it to set, even with a space heater, fan and dehumidifier running full tilt. I got better at spreading it towards the end (I broke it up into four quadrants and did them moving clockwise around the room from the door to the shop). I noticed that when I got to the spaces that had the Feather Finish, it spread so much more easily and dried very quickly, so I'm sure a smooth finish floor would be a piece of cake.
The tile went down pretty easy, even around the edges. Along the back wall, I was able to plan a 6" gap, so I just cut the tiles in half and stuck them in place. The tiles cut pretty easily with a sharp utility knife-- they score with just a few swipes and break pretty clean. Irwin blades are *amazing*, btw. I did half the edge pieces with one side of one Irwin blade but the cheap off-brand blades I bought for this job were dull almost to the point of uselessness after three or four cuts. I think I went through both sides of four blades on the other half of the room.
Anyway, here's the end result (and you can see why I got excited about the red tile):
I'm really pleased with the way the AMC logo turned out. The BMW roundel is, well, not very round. Kind of the Atari version, if you will. I might bring a few pieces of tile up to my dad's place over Xmas and try to use his bandsaw to make some nice clean radius cuts for a proper look. Maybe a drywall or glass cutting compass would work, too.
It still needs baseboard and transition strip (dumb flooring place misordered it). I'll probably do the trim and shelving faces in blue and white. I also thought about looking into capping the shelves with stainless, but it might be cost prohibitive.
Anyway, thanks to all who were unknowingly a huge help planning the floor project. I'm looking forward to updating this thread with my progress.
H
Hencini
You are off to a good start.
Thanks. I had a pretty decent platform to start from, but there are still a lot of little things I'd like to change. Just now I noticed that all the outlets are all 15a, despite being on 20a circuits with 12ga wire. The drywall on the ceiling missed the 2x4s in a couple places and now the tape joints are failing. Just dumb amateur stuff like that. There will be plenty to do for a while. :)
H
Hencini
Looks great and nice write up. I like the contrasting tiles. I''l bet people say you're artistic.
Thanks!! I almost did the colors reversed with blue under the cars so any yellowing from the tires wouldn't be as noticeable, but when I was playing around with the layouts, having the white centers just looked so much better. They really grab your eye. Since the white sections are a little wider than the cars themselves, I'm hoping the white will accent them, as well.
87FoRunner
Memphissippi
Speaking of jeeps, have you checked out the local club midsouthjeeps? I am the current president and would love to have you join up with a CJ!
Midsouthjeeps.com is our main page.
OccupantRJ
Eastern North Carolina
I think you will find that your receptacles are OK wired with #12 on 20 amps.
H
Hencini
Looks great!
Now where are the jeep pics??
I'll get some up ASAP. :)
Great start!
Thanks!!
I'll check it out. It's been far too long since The '83 has seen dirt... ;)
Yeah, I know it's probably fine, but it's just one of those things... Why wouldn't the PO have spent the extra $0.50/outlet to put in the proper 20a receptacles?? :(
Anyway, they're almond, painted over with drywall primer/sealer and have no cover plates. They look schlocky. Replacing them with nice new white proper 20a outlets and cover plates might cost a few bucks but it will also bring things up to spec and make it look better in the process. :)
H
Hencini
That's a great looking space! Are most of your projects centered around the jeep, or do you use the garage for other things too?
Kev
Thanks, Kev. Like a lot of guys on here, I've got far too many garage projects. :)
The Jeep and my '98 M3 sedan keep me pretty busy. With a combined age of 45 years and combined mileage topping 350,000, there's always something going on. I did a bare frame "restification" of the Jeep about ten years ago, so it's pretty reliable for an AMC-era CJ, but there's always something to be done. The BMW is a similar story-- perfectly sufficient for daily driving, but perpetually just short of where I'd prefer it to be. I have several boxes sitting around the shop labeled "parts to be installed" that I'd like to have emptied out by the time spring rolls around.
The Jeep will be getting a junkyard GM TBI system this winter and the M3 will get a partial cooling system and rear suspension refresh. In between those jobs, I'll be doing fluid changes on the motorcycle and trying to find the source of an annoying oil leak on my wife's Vespa. :thumbup:
In the interest of equal exposure, here's the M3 and the R65LS:
H
Hencini
Minor update:
The Car Hole got a new resident today-- a stacked rolling tool chest!! :bounce:
A Home Depot near me is clearing out a bunch of their floor models and I was able to score the 32" rolling chest for $120 and the matching top case for $90. Certainly not bad for stainless and ball bearing glides, but it's neither the best design nor construction. Even though it's advertised as "full extension", the drawers don't quite slide all the way out and there's a significant lip at the front of the drawer that cheats you out of some usable space as well. Coincidentally, I was at Sears afterwards picking up drawer liners (HD was out :rolleyes:) and checked out an equivalent Craftsman setup. It was over 5x the price but a heck of a lot sturdier and better designed. Regardless, $210 is more than fair for this much storage space, and it's at least a thousand times better than what I had been using.
Being a Jeep guy, I've always kept a "trail toolbox" with the bare essentials for trailside repairs. For years, I just used my first and only toolbox, because I didn't have many tools. But as my collection grew, I outgrew that first box and got a smaller plastic box to carry a ratchet, some sockets, a couple adjustable wrenches, screwdrivers, pliers, etc. when I was on the trail and put everything else in the larger original box.
After a few years I bought another, much larger three drawer toolbox, so at that point I was up to three. The trail box for small jobs, the three drawer box for larger tasks and the medium size original box was relegated to automotive electrical duty. :shocking:
VnXvj5RXaXjPaQhOUPJWu4OigotjGbWE49Ez5F_7FhA=w737-h553
The tool boxes took up so much space that I had dedicated an entire workbench to them-- a workbench that could no longer be used for work-- and nothing stayed well-organized despite my best efforts. Wrenches were crammed into toolbox drawers and various hand tool sets (a set of punches, for instance) were split up between the "trail box" and the "shop box", just in case I needed them on the trail. Plus I had all my air tools, impact sockets and various power tools stored in a base cabinet that afforded less than ideal access. Now with the new setup, I will be able to just roll the box out next to the car and go to town. :thumbup:
Anyway, I'm very pleased with the finished result. It holds anything I use on a semi-regular basis and still has room to grow. As a recreational mechanic, I couldn't ask for much more. :thumbup:
Incidentally, while I was out in the Car Hole moving stuff around, I took a good look at my old vise. I think it's going to be my next project. Craftsman model 5249. Not much info available, but from what I can gather, it looks like it's probably post-WWII era. I'll post up more in the vise thread in a minute. :3gears:
H
Hencini
I was going to guess Midtown or East Memphis based on your pictures. I'm currently in Cordova but hoping to move to the East Memphis area within the next couple years.
Yup. We looked in both areas. Can't really go wrong in either, but Midtown was the only place in town that I could find a basement, and only a partial one at that. The main advantage of East Memphis, IMO, is that the houses are a bit newer and you don't have the hassle of undoing all the hack work that's been done to a Midtown house through the years. :D
HSpencer
South Central US
That's a really nice looking garage and what you have already done is great!! I love the floor and the workshop area. I think you are going to have a super shop and place to keep your rides. I am impressed already, and waiting to see where you go from here!!
Best Regards
Herb Spencer
H
Hencini
Best Regards
Herb Spencer
In my book that's one hell of a deal on box.
Have a good one, Gerard
The 5 Stitches Garage part 1 http://www.garagejournal.com/forum/showthread.php?t=142100
The 5 Stitches Garage part2 http://www.garagejournal.com/forum/showthread.php?t=211899
Thanks, guys. I was just out there for a couple hours swapping the summer and winter tires (I tried to get through my first Memphis winter on summer tires, but I'm driving up to STL in a week or two and they've been getting some pretty nasty weather) and doing a few other little odds and ends. It really is so much nicer to have everything clean and organized. :thumbup:
memphisnate
Memphis, TN
Ha! We'll actually be looking for a house built in the 60s with some mid century modern feel. Probably be a longer search as there aren't a lot in town.
H
Hencini
Well, best of luck in your search. And don't forget to buy one with a garage. :D
Fandango
Quite a bit of hack work has been done to my East Memphis place in the fiftyish years since it's been built. Most of it seemingly in the last few. :willy_nil
Good to see another Memphian around.
H
Hencini
And have you by any chance owned it for the last few years? :D
Just kidding... Yeah, we saw some weird stuff in East Memphis for sure (as well as a few nicely sorted Midtown homes), but holy hell, my basement looks like a 3rd world country. :lol_hitti
Some previous owner discovered flexible copper pipe and literally ran it anywhere he wanted. I'm not joking-- when we moved in, the kitchen had a pair of janky looking 1/2" flexible copper pipes coming up out of the floor about six inches from the wall and going straight up into the ceiling to feed the master bath. And the electrical situation down there is sketchy at best. The basement had multiple 20a romex cables running diagonally across the space, secured only by the box at each end. Why not just wire the house with extension cords!?! :lol_hitti
We're about to do a kitchen and first floor half bath remodel and I'm going to use it as an excuse to re-plumb and rewire most of the first floor.
Fandango
lol, I wish, that way at least someone could/would take ownership of some of the **** that I've found:
No filter cage/holder for the heater? No problem, stuff a 25x25 filter where a 20x25 should go and hold it in place with a pair of bricks. Yeah... Bricks.
Hot in the house when you're lipsticking it, getting ready to sell? Run that A/C full blast, sucking drywall dust through the whole system and coating the inside of the heater/air handler.
I could go on, but you get the idea.
H
Hencini
Small update:
I finally finished tiling the garage. The bays were already done, but I kept putting off the workshop area.
Before:
After:
I still want to get baseboard down and paint the trim, but just having all the tile done is a vast improvement. :thumbup:
H
Hencini
Also, I should probably note that I coated the entire floor with Henry Feather Finish 549 before laying the tile. HUGE difference in applying the adhesive. I got way more coverage.
I didn't think the surface in the bays was that rough until I started applying adhesive, but there was enough "grit" to it that it just sucked up gobs and gobs of glue, plus it tore up the trowel pretty badly.
And while the Featherfinish wasn't perfectly smooth (I think it would have been if I put another quick coat down), it was WAY better than the rough (broom finish?) concrete.
H
Hencini
New resident of the car hole:
HF 20 ton shop press. I bought it to help with a rear suspension refresh (bushings, ball joints, bearings, the works) on the M3. Quality is better than I expected but still pretty poor. :lol_hitti
I'll probably put it up on CL after I'm done as it's really stretching the limits of my available floor space. Even if I take a 50% hit on it, it will still be cheaper and more convenient than paying a shop to do all of it. :thumbup:
