dr_obson
Hi GJ'ers
IM Dane from Sydney Aus. Ive just got a welder and learning to weld mig. Its a Cigweld transmig 175i. A multi process inverter (mig with basic tig and stick).
I watched every single video on weldingtipsandtricks and then using the settings on the inside chart came out with this first bead.
All the welding pros please let me know what you think and where i can dial in the settings a bit better. I should have cleaned a bigger area as this machine struggled though even a little bit of paint.
Anyways onto the project
I only have a single garage so space is limited http://www.garagejournal.com/forum/showthread.php?t=214414 , im in the process of putting everything on wheels so i can wheel it out to use it and stash it away when im not.
This only cost me gas, wire and time all materials were out of the scap bin at work.
Started out with a bench grinder, linisher and vice to mount
layed them out on this piece of 4mm and cut it out.
The frame is made of old dexion warehouse shelving and some cheap castors from bunnings.
Slapped it together added a lick of paint, some tubs for storage and thats it easy cheap and space effective
In place against the wall. welding and grinding helmets on the side. Welded tips and comsumables in the top tub. 2 angle grinders and discs in the middle tub. Ro sander and all my sanding pads for it and the linisher in the bottom.
Gotta make a lid for the top drawer so it doesnt get **** from the grinder in it.
