Askme42
Just got this in and figured I'd do a quick review. Will add stuff to it as I use it more. Well here's the complete set
The ratchets are pretty heavy compared to the armstrongs I've been using but they feel fairly smooth. As far as pure socket sets go you're not going to find a much more complete set. All 6 point sockets.
1/4 drive 5/32-9/16 and 4-14 mm. Deep and shallow with deep not having the 5/32 and 9/16. 3,6, and 10 inch extensions. 1 u joint. And one 1/4 to 3/8 adapter.
3/8 drive 1/4-7/8 and 10-21mm excluding 20mm. Deep and shallow in all sizes. 3,6,and 10 inch extensions. 1 u joint. 1 3/8 to 1/4 adapter. 3 spark plug sockets 5/8,3/4,and 13/16. 9 hex bit sockets 5/32,3/16,1/4,5/16 and 4-8 mm. 8 torx bits t10,t15,t20,t25,t27,t30,t40,t45.
1/2 drive 7/16-1 and 13-24mm excluding 20 and 23mm. Deep and shallow in all sizes. 2.5,5,and 10 inch extensions. 1 u joint. 1 1/2 to 3/8 adapter.
The wrenches are about the only place this set might fall a little short but at over 40lbs I don't think I would want it any heavier as a travel set. Wrench sizes are 11/32,3/8,7/16,1/2,9/16, and 5/8. 10-16mm excluding 12mm.
There are also 28 hex keys ranging in size from 3/64 to 5/16 and 1.5mm to 7mm.
The case holds everything in place really well. After a 300 mile treck to my house thru the ups system only 3-4 sockets had fallen out of their place.
Here's a few pics of individual pieces of the set.
