My Akro type bin solution - homemade mount track
rslaback
Westcentral Wisconsin
So I know everyone here loves the Akro type bins. I am no exception. In my previous garage I had them all over the place, wherever I could find room. Some were hung with factory plastic track and some on homemade metal rack. I even had a bunch of bins that weren't in use due to lack of space and rack to hang them on.
We moved this summer and I am still unpacking the garage (and will be for months) but I wanted to get all the bins up that I own and have them all in one location.
Today I did that.
The biggest problem that I think anyone has in having a bunch of this type of bin is that the track is pretty outrageously priced for what it is. I did some searches on homemade track solutions and couldn't find anything that looked strong enough to me or fit the bins well. The closest I found to a good fit used suspended ceiling track angle but I have my doubts as to the strength of that track if I load up the bolt and screw bins.
To make my own solution I used old school shelving standards like were popular in the 80's. I picked up 4' long chunks at $3 each. The metal is nice and thick and fits the bin lips well. The height of the legs are also nice and short so the bin won't have as much leverage. As a bonus, they even come with prefabbed holes for mounting.
http://www.fleetfarm.com/detail/-single-track-wall-standard/0000000042131
The standards were fastened onto 1x6's that were ripped in half widthwise. You could get by with a lot smaller material but I wanted something that would support the entire back of the bin so it couldn't cam out of the track. I screwed the standards on so that the lip was flush with the face of the 1x with #8 - 3/4" sheet metals screws (using pilot holes). The screws are far enough away from the lip of the track that it does not interfere with the bins at all. Then the 1x was screwed to the wall across 4 studs.
After that all that was left was to hang the bins. Some are missing still in this picture as they are somewhere in the garage. I picked this wall because it has an outside door to the right and the dryer vent sticks out into the garage (you can see it below the bins to the right) so I can't really use the space for much else.
I like how clean the installation turned out, the racks are strong, cheap and can easily be removed to move with me whenever I move again (or build my second garage/shop). Total cost for the 12 racks was about $40 including screws. By the way, all the red bins were free after rebate from Menards. If you happen to be near one, snag some next time they are FAR.
wrench409
Over here....
Great idea.
I was given a bunch off these along with the metal wall mount. I was dreading cutting it to fit the area I need to use them.
I think your method is easier to make.
Thanks!
<mytubeelement data="{"bundle":{"label_delimitor":":","percentage":"%","smart_buffer":"Smart Buffer","start_playing_when_buffered":"Start playing when buffered","sound":"Sound","desktop_notification":"Desktop Notification","continuation_on_next_line":"-","loop":"Loop","only_notify":"Only Notify","estimated_time":"Estimated Time","global_preferences":"Global Preferences","no_notification_supported_on_your_browser":"No notification style supported on your browser version","video_buffered":"Video Buffered","buffered":"Buffered","hyphen":"-","buffered_message":"The video has been buffered as requested and is ready to play.","not_supported":"Not Supported","on":"On","off":"Off","click_to_enable_for_this_site":"Click to enable for this site","desktop_notification_denied":"You have denied permission for desktop notification for this site","notification_status_delimitor":";","error":"Error","adblock_interferance_message":"Adblock (or similar extension) is known to interfere with SmartVideo. Please add this url to adblock whitelist.","calculating":"Calculating","waiting":"Waiting","will_start_buffering_when_initialized":"Will start buffering when initialized","will_start_playing_when_initialized":"Will start playing when initialized","completed":"Completed","buffering_stalled":"Buffering is stalled. Will stop.","stopped":"Stopped","hr":"Hr","min":"Min","sec":"Sec","any_moment":"Any Moment","popup_donate_to":"Donate to","extension_id":null},"prefs":{"desktopNotification":true,"soundNotification":true,"logLevel":0,"enable":true,"loop":false,"hidePopup":true,"autoPlay":false,"autoBuffer":false,"autoPlayOnBuffer":false,"autoPlayOnBufferPercentage":42,"autoPlayOnSmartBuffer":true,"quality":"default","fshd":false,"onlyNotification":false,"enableFullScreen":true,"saveBandwidth":false,"hideAnnotations":false,"turnOffPagedBuffering":false}}" event="preferencesUpdated" id="myTubeRelayElementToPage"></mytubeelement><mytubeelement data="{"loadBundle":true}" event="relayPrefs" id="myTubeRelayElementToTab"></mytubeelement>
southalabama
Brewton AL
That's a good idea.
I've got some of the shelf brackets left over from a bookcase project that never materialized.
R
rslaback
Your solution was actually the one I referenced in my first post. Have you had any issues with that track bending with a full load in a bin? It is hard to see but some of my bins are heaped full of bolts and screws.
PCO6
Newmarket, Ontario
None at all. The bins in the picture above have been up for close to 10 years I have had no problems. In fact I have some larger bins that I used 1"x6" pine for and they are good too.
whyNick?
Midwest
Thanks for the idea, I have a bunch of the Menards bins myself and now I have a cheap way to mount them.
Knyte Tyne
Johannesburg South Africa
I know this is old, I know I only found this now... But thank you!!! What a brilliant solution. Combine this with a French Cleat and I have a solution to a problem I've not yet solved. Shot Gents.
rlitman
Long Island
It's a nice solution, IF you don't have the ability to weld.
If you do, 3/4" steel angle is cheaper than shelf standards, and you can make a stronger wall rack. I had a deep but narrow hall closet that made it impossible to get to things on the back of the shelves. I replaced the shelves with 18" deep Akro bins, and now I can pull a bin out when I want something from the back.
R
rslaback
I'm confused. It seems like you are saying that you either mounted just angle to a wood runner (but that wouldn't require welding) or you welded two pieces of angle together face to face to make a Tetris S shape. Do you have any pictures of your mount to make it clearer?
isb cornbinder
Today I did that.
Great job.
Husky79
North Central MN
I am confused too, was hoping someone would chime in with answers by now. I am wondering the exact same thing as I have whole bunch of Akro bins in the storage and want to put it in use.
isb cornbinder
I found the Acro Mills louvered board on CL. I think I paid $40. There are two boards mounted back-to-back separated by a square tube frame on a base with castors.
Many of the other AM bins came from Amazon.
The grey ten drawer cabinet was found on CL. Each drawer holds 20 bins. This cabinet was $25, if I remember. The cabinet weighs about 60kg. (132#) I am going to put 6 casters under this cabinet.
alinc100
Dearborn,MI
we install graphic/acoustical panels/markerboards every day with this aluminum zee bar. Would it fit your bins? a couple 12 ft lengths are not too pricey. I would think any aluminum supplier in major cities would have access. link for reference, not an endoresment:
aluminum zee bar
PoorUB
Fargo, ND
I don't know how you guys survive with open parts bins in your shops. I had a a few Akro bins years ago and they collected an obscene amount of dirt, saw dust, grinding dust and welding dust.
All my colections are in covered parts boxes, or in bins inside cabinets.
isb cornbinder
That is lots of dust. Are you wearing breathing protection? My Dad refused to wear dust protection and he died at an early age. He had asthma and emphysema. Dad's brother used to wear a KOTEX pad on his face. Dad used to say, "My brother finally got something right. He put the pad on the right end."
PoorUB
Fargo, ND
It isn't like they were full of dust, but more than enough dust, over a period of a year or two that what ever was stored in the bins was very dirty and had to be cleaned before use.
I have a working shop. At the time I was doing auto repair and often worked most evenings in the shop. I also do some woodworking so wood working dust and metal work so grinding, oxy-acetylene cutting and welding create dust. I have built trailers and other items.
