Harbor Freight all-stars
sac02
We have the HF pass/fail thread, but that's a little difficult to navigate at 336 pages and growing. Plus, that thread is a home for reviews of every single HF tool ever (tens of thousands of items).
The goal for this thread is to gather a short list of best-of-the-best Harbor Freight has to offer. These are tools that almost everyone would agree are very good quality, and an excellent value.
Request: I would like to keep this thread focused on simply what HF tools you consider best-of-the-best, and avoid discussion cluttering it with request for reviews, or "What do you guys think of such-and-such tool?" type posts.
Here is the list that I've got so far based on previous knowledge of GJ favorites and feedback in this thread. I am also collecting a running list of "nominees" - if they get enough votes, I'll add them to the All-Stars list.
If you disagree, please comment. If there is disagreement on if something is an "All-Star" or instead just a "generally good tool/good deal", I'll make that note, and potentially remove them from All-Star status.
I'm wondering if I should try to add what is generally considered a "good price" for each All-Star...
All-Stars:
  1. Pittsburgh Pro impact sockets, various
  2. US General Tool Boxes, 44", 56", (and 72"?)
  3. US General Red 5-drawer tool cart
  4. Earthquake impact guns, 3/8" and 1/2"
  5. Orange dead blow hammers (-2)
  6. Composite ratchets, various
  7. Torque wrenches, various
  8. Breaker bars (non-ratcheting)
  9. Pittsburgh Professional screwdrivers
  10. Nitrile gloves
  11. 4.5" heavy duty (red) angle grinder
  12. ?
Nominees:
Magnetic parts trays (+6, -2)
2 ton aluminum floor jack
low profile racking jack (+2)
breaker bars (+1)
motorcycle lift table (+2)
disc brake service kit
DA polisher (+1)
heat gun (+3)
4ft Pittsburg level (red) (+1)
Moving blankets (+2)
battery chargers
3/8" locking extensions
right angle die grinder (+1)
free tape measures (but only as a freebie?) (+2, -1)
freebie blue LED flashlight (but only as a freebie?) (+1)
7pc ratcheting wrench set
short bar clamps (+1)
reciprocating saw (+2)
flex head ratchets (new item)
1/4 and 3/8 dual flex head long ratchet (+2)
blue mechanics gloves (red) (+2)
Orange handled picks (picks) (+4)
2-ton engine crane
2-ton load level
1000lb engine stand (+1)
1000lb mover's dolly (+1)
6 gallon compressor
60 gallon compressor (+1)
black 4 drawer cart (+3)
roto head ratchets (+1)
left hand drill bits (-1)
triangle welding magnets (-1)
1-ton gantry and chain fall
single drawer service cart (+1)
red through handle, long shaft screwdrivers
20 bin plastic storage boxes (-1)
foam mechanics pads
stubby wrenches
garden soaker hoses
12 ga extension cords
6 outlet heavy duty power strip
1/2" extendable ratchet (+1)
flex head composite ratchets (new)
26" tool chest
Push pin pliers
electrical jumpers
wind-in brake caliper set (+1)
disc brake turn back tool set (same as above?)
3oz Super Lube (+2)
brake line forming tool
10" miter saw
16" tie rod separator
4pc impact extension set
Ball joint service kit
Portable halogen shop light
steel bristle brush
swivel lens headlamp (-1)
transmission jack
wobble extensions (+3)
shrink tubing (-1)
Iron armor etching primer
electronic calipers (+2)
brass hammer
jack stands (+2)
4-ton portable hydraulic kit
36pc 3in" screwdriver bit set
swivel head ratchet, stubby 1/4 (green handle) (+1)
SDS hammer drill
Acculink belts
Polycarbide abrasive wheels
Pittsburgh Pro sockets (Taiwan)
Pittsburgh Pro 72t ratchet
High Visibility Socket set (-1)
Warrior spot weld cutters
3/4" ball joint separator (+4, -1)
11ga coil roofing nailer (+1)
20 ton shop press (+1)
12" sliding miter saw
bottle jacks (12 ton and 20 ton)
hose clamp pliers (+2)
2-in-1 adjustable wrench
6pc SAE jumbo angle wrench set
28pc transfer punch set
5" high speed air sander
1/2" quick release impact extension bar
indexable ratchet
3/8" double flex ratchet
7" grinder
Pittsburgh Pro 5pc flex ratcheting wrenches
Magnetic tool box accessories (various) (+1)
8gal oiled compressor
21degree framing nailer
18ga brad nailer
Socket trays (+1)
3/8 air ratchet (-1)
Purple HVLP paint gun (+1)
Oscillating multi-tool (corded)
300lb capacity mobile base
mattock
machete
10x10 shade structure (ez-up)
14pc hydraulic punch driver kit
SAE drill/tap/deburr bit set
F-clamps, 6", 12"
horizontal toggle clamps for woodworking
Japanese flush cut saw
3" swivel caster with brake
Disposable brushes
pegboard hooks
1200 grit sandpaper
Front wheel bearing adapter press kit
200/400W power inverter
Tarps
Super long screwdriver set
50' retractable hose reel
Currently, I'm using a criteria of (+5) unique positive mentions to move an item to the All-Star list.
Once the item is in the list, I will only track the number of dissenting opinions (tallied as "negative votes) from those that do not think the item belongs as an All-Star. If the negative tally of an All-Star becomes significant, I will reevaluate it's inclusion in the list.
Edit: (10/02/2014)
Updated the OP with all the nominations through post #55. Moved the following items into the All-Star list:
"Pro" screwdrivers
Nitrile gloves
Edit: 10/02/2014 - Updated through post #74
Edit: 10/04/2014 - Updated through post #99. Moved the following items into the All-Star list:
4.5" angle grinder
The magnetic parts trays have several dissenting opinions, hence they have not been moved into the all-star list.
Added links to most of the All-Star items.
Edit: 10/06/2014 - Updated through post #141.
BirdMobile
Most people around here like the composite ratchets.
I like the magnetic parts trays just fine...
BirdMobile
2nd the Torque wrench nomination. My 200 Inch Pound version is within 2% over the full range - not bad for a $10 (with coupon) tool!
fourtythree
WV
My favorites:
low profile steel jack
Earthquake impact
composite ratchet
DA polisher
chipper
Williamsburg, va
I like the things mentioned above I also have the 56" box with a side cab and the 5 drawer cart but my favorite consumable are the nitile gloves....I already bought the new composite ratchet and that is an improvement over the old
vartz04
LaSalle County IL
Earthquake impact
4-1/2" red angle grinder (have beat the hell out of it for 3 years and it won't die)
Impact sockets.
4' Pittsburg level (red one)
Tellingthem
Traverse City, Michigan
Maybe not a tool per se but I've always loved the moving blankets. I always buy a couple when they are on sale. Use them for everything.
Oh the gloves are pretty solid too!
BFBOB
Battery chargers. Got several of the 2-10A + 55A start on sale for $25. Handy to have sitting around - got one dedicated to my electrolysis tank, others in various garages. Handy.
sac02
I updated the OP with the results so far.
What do you think if I tried to include what is considered a "good price" for the particular item in question? For example, the 44" toolchest would be $369, since that is the (current) lowest price you can get on it.
Haveblue
kansas
Do they still offer the large 4 magnet tray? I Had to re-glue a couple of magnets on mine, but no big deal, great tray for a fraction of others. 4 piece Pitt pro 3/8" locking extensions..locktite the set screws, and good to go. Torque wrenches..I compare mine to my beam type often, and they are always VERY close! Right angle air die grinder..Very good..I have two. On one the gears are sloppy, so I use it for "light duty" The other is tight, I kinda push them, they both are holding up well. Picked up the three piece pro CM wobble impact extensions..I like 'em. These are tools I use everyday...I feel they have paid for themselves, and more.:thumbup:
hayhauler71
MN
I think the free tape measures are a great product. the ends are nice and tight and I would even pay the $6.99 for the tapes.
jd_1138
NE Ohio
I think the "no brainer" HF tools (in other words, must buys) are:
breaker bars
torque wrenches (so cheap you can keep them in your trunk for flat tire changes)
freebie LED flashlights (give 'em to your friends and family for purses, glove compartments)
Also, I like the 7 piece ratcheting wrench sets that are quite nice.
http://www.harborfreight.com/7-piece-metric-ratcheting-combo-wrench-set-95552.html
Pittsburgh Pro screwdrivers
http://www.harborfreight.com/8-piece-professional-screwdriver-set-94607.html
RivennHewn
PNW
Price/quality ratio is great on the short bar clamps.
For $2.99 who cares if they break.
I buy a pair every time I go in.
Some for the job, some for the truck, some for the welding cart, and some on the bench.
Haven't had any problems yet.
Bend em, brake em, burn em up with the welder -- No problem.
The longer ones, not so much
jonti48310
Their new flex head ratchets sound like winners based on the other thread going around now. I'll be picking up a 44" box tomorrow for escuela, might just pick up these new ratchets depending on if my store has them or not and how they look quality wise in person.
RedFordTruck
The Blue mechanics gloves are a win for $3.89.
The price/quality ratio is on point. They fit well, are perfect for most jobs, last decently long, and are cheap enough that I'm not upset when I lose one out of the truck or off the 4 wheeler.
MRunabout
San Diego
Things that I have first hand experience with:
2 ton engine crane
2 ton load level (the plastic handle has a tendency to unscrew itself, though)
1000lb engine stand
5 drawer service cart
6 gallon, 150psi, oilless compressor (loud but doesn't leak with occasional usage...had it for 10 months now)
60 gallon, 165psi, 2 stage, oil lubed compressor (brother has had it a bit over a year with no problems)
3/8" composite ratchet
Rogue1987
Missouri
The black extra heavy nitrite gloves are awesome
impact sockets
magnetic parts tray
red service cart
44' toolbox
picks
composite ratchets
roto head ratchets
Earthquake 1/2" Impact
moving blankets
magnetic roller thngey for picking up bolts and screws
Free tape measures
left handed drill bits
Red levels
Diesel compression tester set
those cheap *** $10 grinders
1 ton gantry and chain fall
those really long through handle shaft screwdrivers with a red handle
92integra
rear caliper turn in kit is an A+ in my book. as well as the 4 drawer cart!
BirdMobile
I'm going to have to disagree on the tape measures, free or not. I have 2 of them, and they both have smeared sections on the scale painting. Unimpressive.
BirdMobile
Oh yeah... love the roto ratchets! Too bad it looks like they're clearancing them. :(
TerryH
Springdale, AR
Aluminum motorcycle/ATV lift
Red mechanics gloves
Foam mechanics pads
1500 watt heat gun
Stubby wrennches
Garden soaker hoses
4.5" heavy duty grinders
I'm sure I'm missing some things.......
Myth
8 pc pro screwdrivers #94607
Nitrile gloves
1/2 extendable ratchet #98831
New flex head composite ratchets
black 4 drawer cart #61634 or Item #95659 - not as good the red 5 drawer but still good for the money ($99)
26" 16 drawer tool chests #67831 - not as good as the bigger boxes, but still very good
