You have little understanding of electricity.
Oh really. Actually I am the one showing diagrams and proof points. You just spout vitriol, vulgar obscenities, and attack me personally.
If you are so sharp, show me the current flow of how the current in the secondary of the thermostat transformer flows into the secondary of the furnace transformer. Instead of insults show some proof. So far you have showed nothing but a vulgar mouth.
R and W are the contacts of a relay within the thermostat and C at the thermostat is not connected to ground nor back to C at the furnace. Also the thermostat transformer secondary is isolated by the transformer core and not referenced back to ground or C. Show me the current flow…….
…connect L1 from the furnace to your scrotum. Oh, and don't forget to post it to YouTube (where you seem to glean all your knowledge) The pain and embarrassment you experience from the backfeed jolt will be short lived in light of the royalties from the millions of views you'll get.
Do you kiss your kids, wife, and mother with that mouth? Again no evidence why it is a risk, just personal attacks. Just a thought. People that can’t explain things (i.e. they don’t fully understand) like to redirect with personal attacks.
I have been installing and servicing HVAC equipment for over 35 years. Stacking transformers results in damaged controls, erratic operation, spurious fault codes, and failure. And possibly blistered scrotum.
More potty mouth, very impressive. You are singlehandedly capable of moving the term “Tradesman” back to the stone ages. As to your “so called experience” WiFi thermostats have only been around for about 5 or so years so your first 30 years of experience is irrelevant. In any event, not understanding something well enough to articulate the fault mechanism is simply timeless. I understand what is happening at a components and circuit level. You have a vague incomplete understanding at a block diagram level.
This started as you saying it (a separate transformer at the thermostat) wouldn’t work to no comment of whether it would work but the possibility of a fringe back feed safety scenario when power is disconnected to the furnace. It’s not me who is back peddling here….
So let’s decompose this as I am more inclined to explain than vomiting verbal attacks like you. There are three scenarios to consider. They are:
1. Furnace powered up, thermostat remotely powered and controlling (operational mode)
2. Furnace powered down, thermostat powered up, Thermostat calling for heat (R & W joined by relay in thermostat). (Service mode)
3. Furnace powered down, thermostat powered up, Thermostat not calling for heat (R & W open, relay off). (Service mode)
Case 1
Local power for the thermostat is achieved by the 24VAC across R and C provided by the local transformer. This power source feeds the thermostats internal electronics only. The contacts of the heat call relay close and open to join R and W as required for heat calls. C at the thermostat is not grounded and not connected back to C at the furnace so there is no back feed path to the furnace by virtue of the contact isolation of the thermostats heat relay and no ground return path. Well documented on many web sites as an acceptable means to overcome the lack of a C wire to the thermostat (just a few show below). Conclusion works as advertised.
Case 2.
Solely a safety scenario when the furnace is powered off. By definition then, not an operational concern. In this mode the thermostat is powered up and a call for heat is active so R and W are connected by the closed contacts of the heat relay in the thermostat. The suggestion of back feeding the transformer in the furnace is not possible since the 24VAC of the thermostat, while present in the furnace due to the joined red wires at the thermostat has no return path to the C of the transformer at the thermostat. Conclusion no shock, no death, no blisters.
Case 3.
Solely a safety scenario. Same as case 2 except that the thermostat is not calling for heat and W and R are not connected via a relay. W is open circuit at the thermostat end. This case sets up a potential problem in that now the 24VAC from the secondary transformer is present inside the furnace on the 24VAC line and the coil of the heat relay or gas control valve is a connected to the other side of the furnace transformer and then returns to the thermostat via the W wire. If the W wire were connected to the C of the thermostat then a valid return path would exist and the back feeding of the furnace transformer is real and accordingly the primary would rise to 120VAC. But W is not connect to C. W is open circuit because the contacts of the heat relays are open. Without some current path from W to C at the thermostat, there is no current path to create the dangerous scenario. The attached diagram explains this fully. Conclusion no shock, no death, no blisters.
Even if you don’t believe me on case 2 and 3 you could simply put a sticker at the furnace shutoff switch that said something like. “This system is controlled by a remote WiFi thermostat with independent power source. When performing maintenance you must disconnect the power source at the thermostat in addition to switching off this disconnect point before performing any maintenance.” I tried not to use any big words so it should be understandable. This label is not needed but doesn’t hurt.
Same goes for your isolation relay. Not necessary but won’t hurt any. But when you add in fan control and AC compressor in addition to the heat that becomes three isolation relays and this quickly gets out of hand.
Here’s a number of web pages citing the 24VAC local transformer approach. I suppose you’ll hurl some insults to them as well.
http://tombuildsstuff.blogspot.com/2012/10/how-to-add-c-wire-to-thermostat.html
http://www.dslreports.com/forum/r29542718-HVAC-Installing-new-Honeywell-WiFi-thermostat-no-qcq-wire
http://diy.stackexchange.com/questi...nsformer-to-provide-a-c-wire-to-my-thermostat
This never started this as a preferred way to implement. I would always try to run a common wire back to the furnace. Depending on the home however, that can be near impossible after the fact. I was simply offering an alternative for folks unable to run the common line. I’ve shown why it will work and why it is safe by decomposing it to the component and current flow level. You’ve done neither and simply insulted me.
Now who looks silly.
