JohnnieMo
I'm designing a 37x26 with 10' walls. I'm tight on funds but also tight on time. I'm looking to do this build next summer. Given that I don't have a lot of time I see close cell spray foam making a lot of sense. That way I could build it, spray it, then have all winter to run electrical, water, air etc before installing drywall.
Another factor is the ceiling. One half is scissor (for the lift) and the other is a loft that needs to be warmish (I.e. Inside the warm zone). It seems so much easier to spray the back of the roof sheathing rather than having to create air space, stuff batting, then struggle to to install vapour barrier between all those joists.
Cost of foam in town is $2.40 sqft installed for 2" closed cell.
My thought is to do 2x6 walls with 2" foam, and 3.5" of batt. Same for the ceiling. However is it overkill to spray and batt a building where the doors let cold air rush in every couple hours???? That would get me R28 or there abouts.
Couple questions:
1) Can you spray directly to the back of roof sheathing?
2) is it worth doing both spray and batt?
3) Do the garage doors remove any heat savings I may gain?
Looking at radiant heat mounted near the ceiling.
Sent from my Passport
Couple questions:
