Randy in Maine
Whatever you do, I'd definitely go with the radiant floor heat! Good luck!
With at least 2" of insulation under the concrete.
I'm glad so many brought up in floor heat...... now I don't need a new thread!With at least 2" of insulation under the concrete.
I like spray foam because it's quick to do, easy to put on the underside of the roof, and it leaves much of the wall cavity available for other things.
The big deal is that I need to get the garage water proof (Ie vapour barriered) by snowfall. If I do batt that means I need all the electrical, air lines, gas etc done beforehand. Spray foam means there is no rush.
. . . If you think the door is not an issue, check this pic of the outside of my shop at -5C. . . .
Do you have any pictures or designs on how the roof is constructed? I'm interested to see the support mechanisms.My studio is all SIP's (walls and roof deck) -- pipe for the horizontal ties . makes for a very tight building and I like the tall ceilings.
Building with stick and foam is greta also -- my last couple of houses are foamed. Don't mess around with vents or vapor barriers -- spray the roof and be done with all the problems.
Any tight building needs ventilation -- this is not difficult.
Thanks Randy.
I think the heated floor with pex is a reasonable approach. I am already running water to the garage and am intending a hot water heater also. Is it possible to combine the two? I think I would prefer antifreeze but I'm wishy washy on it. If I could save myself an extra hot water tank it might be worth it.
The sewer line resides right where I am excavating already. It will be a big dig but quite do-able. The water will come from the house via a heat traced line.Water in the garage is going to be expensive, you'll have to put the line 5' into the ground and the sewer will be even deeper, or you'll have to build a dry pit / well. That's a lot of excavating.
If you go with infloor heating it MUST have antifreeze. Some event will occur and you don't want to damage the concrete from freezing. If your regular water heater burst you just have a mess to clean up not replacing the concrete.
The numbers say our ground freezes down to 7'. The water and sewer lines to the house are at 8'. So the rules state anything less than 8' need to be heated.
I seriously doubt it freezes that deep but maybe it did once upon a time.
Does the engineering include an Alberta P. Eng drawing for the foundation? Building inspectors usually require them for any non-concrete foundation.
3) Everyone says 2" under slab insulation.... what type?
I've confirmed that the engineer is a P.Eng and the drawings are stamped. I've asked them if they could also design the foundation and slab - they said yes. I'm going to meet with them next week to discuss with the engineer.
I seem to be going down this SIPs road almost entirely by accident.... funny where GJ can take you..![]()
