Building a Pit Cart
DEllis
Carlisle, PA
The below DropBox link contains the pictures missing from the thread.
https://www.dropbox.com/s/596xcs4st25c7x8/Photos.zip?dl=0
I'm a club racer with NASA (Spec Miata). One of my winter projects before the new season starts in March is to build a pit cart. I had been maintaining a separate set of tools which I kept in the trailer, but there were still items I had to load every race weekend.
I've sold the trailer tools, and another large toolbox in my garage, and plan to construct the pit cart and keep all my auto related tools in it. Non auto stuff will be stored elsewhere in the garage. Then on race weekends I'll just need to roll the new toolbox up the ramp.
I plan to build the pit cart around the HF 44" box and the side cabinet which I picked up this weekend.
I ordered a pit cart suspension from Irvan-Smith which should be here tomorrow.
ctrp-1302-31_thinking-outside-the-pit-box-irvan-smith-tool-organizers_unassembled-parts.jpg
Steel has been ordered from a local supplier and I hope to start mocking up a frame on Saturday. I'll post updates as the project continues.
Duncan
SHAZZAM
Roseville, MN
I've been thinking about doing this for a long timefor motorcycle racing. Only as a concept, never could figure out the details. I can't wait to see this.
Do you have a sketch of the plans and what wheels/tires are you using?
Nate
D
DEllis
Carlisle, PA
I only have a set of hand drawings, but it shouldn't take more than a few days to get a rough frame assembled.
I'm using 8" trailer wheels (16" diameter)
Duncan
D
DEllis
Carlisle, PA
I need to move quickly, as I had to move all the tools out of the toolbox I sold. I can't reinstall them in the new box because I need to be able to move it for mockup.
As it stands, all my tools from the old box are piled on my work bench. It's a bit of a mess. Things will get a little better after next week, when I put the engine back in the racecar. Then I can move it to the trailer and free up room in the garage.
Duncan
SHAZZAM
Roseville, MN
Oh and based on dragging my roll away craftsman box around for the last few years I would suggest shadowing every drawer. Mostly to help keep thing organized in the drawer while bouncing down the road. Also to help make sure you don't forget something.
Ohmthis
Outside of Louisville KY
DEllis, this idea has a ton of potential, my only caution is the strength of the slides and how long tney can hold up to tne road. I built a pit box from a 26" craftsman bottom, and although it had ball bearing drawer slides, got beat to hell. I believe the HF box is way better built than my old box, just a concern. I agree on shadowing the tools, or what I did was leave them in as many cases and holders as possible. I actually had to pull some of the drawers out to get tools that had bounced out...............No fun
shrttrackr
Frankfort, IL
Subscribed.
DEllis, I race circle track and there are a few tracks that do not allow our haulers in the infield. i have been wanting a small pit cart for a while. i will be watching with great interest . good luck with the build!
navin
sub'd for this! What region are you with for NASA?
<- Mid-Atl (Northern VA guy here)
Capt Chrysler
Middle of nowhere.
Not to bash on the HF tool box. I'm a little concerned that the drawer slides will hold the tool weight with the road vibration. I do know we killed a few Carftman and Snap On boxes back in the old days 80's - 90's.
Cool project, I will be following it!
Capt. Chrysler
D
DEllis
Carlisle, PA
Not to bash on the HF tool box. I'm a little concerned that the drawer slides will hold the tool weight with the road vibration. I do know we kill a few Carftman and Snap On boxes back in the old days 80's - 90's.
Capt. Chrysler
I've had a cheaper toolbox in the trailer for a few years with no issues. The trailer rides pretty well. It's a 36ft enclosed gooseneck with torsion axles. It's heavy at 15K and doesn't bounce around much. It's smooth enough that I've set stuff on the counter in the LQ and forgotten about it, and arrived at my destination with everything still in place.
Duncan
SRD9Boss
East Hartford, CT
Just a suggestion but make sure the cart is deep enough - the depth of the box is NOT deep enough. Roll it around on an infield and it will be very unstable. Make the back portion accessible and use it to store spares/creepers/jack/jack stands etc.
D
DEllis
Carlisle, PA
Just a suggestion but make sure the cart is wide enough - the depth of the box is NOT wide enough. Roll it around on an infield and it will be very unstable. Make the back portion accessible and use it to store spares/creepers/jack/jack stands etc.
Agreed, the current plan is to make the cart 24" wide. I'll fabricate a pocket in the back of the toolbox where I can store items like my extra ballast weights, electrical cords, and other items. I might be able to push the width to 26", but any wider than that it won't fit through the side door of the trailer easily.
Duncan
SRD9Boss
East Hartford, CT
That still may be on the narrow side - consider loading the cart before the car - via the ramp. That is how all the roundy roundy guys I worked with did it.
D
DEllis
Carlisle, PA
Did some measuring in the trailer, and as long as the cart can make the turn at the front of the trailer to be stored cross ways across the trailer, I can comfortably make it 30" wide. I'll do a mockup and some testing this weekend.
Duncan
D
DEllis
Carlisle, PA
Pit cart suspension pieces have arrived.
Backside of the trailer hub. I'd like to look at the possibility of putting disc brakes on the front, but will probably need to have a machine shop make me some custom rotors.
Picking up the steel tomorrow afternoon, should have more pictures on Saturday.
Duncan
kbs2244
Do we understand that the tool box will be outside the trailer at the track?
If so I would be worried about it be too narrow and tipping.
(At the least, very embarrassing. Been there, have the Tee shirt)
If it is a semi permanent (race night only) install, I would think about a powered winch to pull it into place in the trailer.
Then you cold manually pull it out as far as needed during the week.
This assumes the trailer and the maint. shop are in the same room.
gte718p
I used go-cart rotors on my old pit box. They fit perfectly, same size wheel you are looking at. I made my own hubs though so I had enough space for the caliper. Used a motor cycle master cylinder to actuate the brake and a line lock to act as a parking brake. Ended up working out very well. With 2 nitrogen cylinders, box, tools, my box was probably 600+ lbs. The brakes made going down hill much more comfortable.
shrttrackr
Frankfort, IL
any photos of your cart?
pmason0
East Tennessee
Be interested in how it progresses. I started to build a smaller version with a 36in toolbox top with a generator, etc on the bottom. The idea was I wanted to move some weight to the back of my trailer, built the frame, but realized how heavy the damn thing was going to be. I ended up building a tire cart instead, about the weight I was looking for.
D
DEllis
Carlisle, PA
Thanks. That's helpful. Picked up the steel this afternoon and will start tacking together the frame.
Trying to decide between a stainless top and a rubber mat. I'm thinking the rubber might actually be better to stop things sliding around.
Duncan
D
DEllis
Carlisle, PA
Started work today on the cart.
Laying out the basic frame. 1x2 11 gauge square tubing.
A few hours later.
Tomorrow I need to weld on some angle for the front to strengthen the connection between the front riser and the main frame, as well as weld on 1/8 plate to accept the tool box. That should do it for the frame, and I'll start building the risers for the work bench.
Duncan
