TOOL FANATIK
Decided to see how the 10" Channellock Griplock pliers would hold up in a torture test with the infamous grade 8 bolt. This is a small, 3/8" shank bolt with a 9/16" hex, and 1.5" in length. The test was simple: stack the bolt to the top with grade 5 nuts with matching thread size, and put it in the vise. Then just tighten the bolt on the nuts until I couldn't tighten anymore or until the nut threads strip out or the grade 8 bolt shears...OR until my test subject fails!. Results? Grade 8- 1, Channellock- 0.
Note the section that chipped off the top tongue of the pliers. Also note how the bottom jaw is now bent. In all fairness, I used all my force (no cheater bars were used, only my extremely rediculously ripped arms) and the bolt did yield. When the pliers failed they were kind of on an angle, which probably helped to cause the failure- the plier jaws are wider than the flats of the bolt, so half of the jaw width was not on anything. But, still a very real world situation, to mimmick a frozen and rounded off bolt that has been subject to harsher climate. Hope you enjoyed! I did! questions, comments?
I hear you Vantastic, but I have a little cautionary tale for you. It contains within it a valuable lesson.
