spraying rustoleum
Jon Jacobs
London Ont Canada
Hi all, I am planning to paint some crane rails with Rustoleum with my paint gun. Has anybody tried this ? If so which is the preference, Acetone, Laquor thinner, reducer or paint thinner. What is the best ratio ? Thanks
gungatim
west mich
I did a black utility trailer. just used cheap paint thinner/mineral spirits. came out fine, but I believe some people may add some hardener to it. I didn't...don't recall the ratio, something close to 50/50 I think...just so it sprayed and flowed out.
toplessHO
central florida
yep just sprayed some industrial semi gloss black
used Xylene for thinner and added universal hardner 8:1
sets up great and holds up much better with the hardner.
must use a good mask and in well ventilated place(outside is good)
dont thin any more than 20%
Ign
Butte Peak ND
Read the can!!! IIRC Rustoleum is very specific about only using acetone. Doesn't mean you have to but if in doubt I go with the manufacturer's reco (call me crazy)
I'd try as thin as 1:1 for spraying, but it may run on you depending upon your technique & skill.
crab
I used acetone and didn't need to thin it a lot for it to spray good. Don't really know what the ratio was. I didn't use any hardener but probably isn't a bad idea .
zkling
Acetone. Thin will depend on your gun tip, but around 10-20% to start, up to ~1/3.
Gerald O
NC
+1 for acetone. Sprayed the undercarriage of my MGB with black Rustoleum when I restored it. One thing to be careful of though is don't lay the paint on too thick too fast in hot weather or it can bubble from the acetone evaporating rapidly.
gungatim
west mich
actually, the can I have specifically states to use mineral spirits for spraying, but I searched and they do say acetone will flow out better...I may try that next time to see if it works better. my black trailer still looks good 5 yrs. later, but I did a red one a long time ago and recall it fading within a year...
Eriehunter
I sprayed some this past fall. It sprayed ok. I used acetone, which is what rustoleum recommends. It still takes a while to fully dry, I painted some old metal kitchen cabinets, they turned out pretty good, car paint would have been better but at about 5x the cost for material it wasn't justifiable.
Also it is crazy sticky with overspray, cover everything you don't want painted. Including yourself !! That stuff was stuck to me for 2 days!!
I still have one more large cabinet to do but I am going to wait for a nice spring day so I can do this outside, my floor is red now.
I used the "Safety red" color which is a pretty decent approximation of tool box red.
NUTTSGT
Northern Central Ohio
Been a couple of years but I need to spray some Rustoleum. Anybody have any new thoughts ? I have used mineral spirits in the past but think lacquer thinner or acetone.
NUTTSGT
This is the post I saw the other day that I was looking for but didn't know where it was. I wanted to add it to this thread too.
I use rustoluem. Bare metal, painted metal, rusted metal, and ect. Clean it and wipe down with rag/acetone. Cut paint 50%-75% with acetone where it will spray easily. Drys almost instantly and hard as a rock. Can redcoat almost immediately. 3-4 coats. Immediate dry and hard. Looks like powder coat. Very durable.
Showkey
"MEMBER EMERITUS"
Wausau WI
As the answers are confirming........it’s appears to say on the can ( depending on the age of the can) either mineral sprites, acetone or xylene. Mineral sprites is going to take a long time to dry.......like weeks to fully cure.
Every can does do not use lacquer thinner.........that might be because it’s more volatile and would need more ventilation and be a real danger in a confined space.
ard
Isnt "Rustoleum" the name of a company, and NOT a product?
Ive use many, many different Rustoleum products- from DTM paints, concrete flooring epoxies, rattle cans, etc. All sorts of solvent systems
Id figure out which rustoleum product you are using, and download the product information sheet for that item
persburn0
Yeah I always thought that it was a name of the company and not the actual product but I’m not sure.
66cj225
NH
I like Xylene, shoot outdoors and normally late spring early summer for maximum insect content; levels and hardens well. Crane rails are more about the color than close inspection.
Showkey
"MEMBER EMERITUS"
Wausau WI
Think it was assumed and understood the OP was spraying solvent based paint product. When acetone, mineral spirts and xylene was mentioned they were thinning solvent on the same paint product just different cans.
Iron-Iceberg
A-town
Yea, mineral sprits drys really slow. Acetone will dry much faster and flow nice.
I use a Ford cup to get the same viscosity each time. Otherwise the paint can be thicker or thinner from one can to another, some are like peanut butter. So if going by percentages I end up adjusting the gun or adding more aceatone or material and chasing my tail to get it right. With the Ford cup it comes out the same each time.
My .02
NUTTSGT
When I went back to the garage let night, I checked the back of the can. It does say to use acetone and I took a picture. I need to check PB to see if it uploaded the picture.
Yes, Rustoleum is a brand but they are known for their spray paint and oil based paint. I believe most are referring to the oil based paint when they say "Rustoleum" Maybe I'm just getting old.
OccupantRJ
Eastern North Carolina
Well, just to get off the subject title, I also use Naptha with Sherwin Williams industrial enamel paints. I was turned on to this by the Sherwin rep when we had some painted metal doors that were painted and took forever to harden the paint.
ard
Not to belabor the point, but I think it is irresponsible to suggest paint thinning based on beliefs and what we think OP might have been referring to.
Could may well be. Id still ID the actual paint, and read what Rustoleum recommends.
NUTTSGT
True but maybe those that are suggesting should also state what product they are thinning. Six of one and a half dozen of another.
Since the thread is two years old, it might be a little bit late to ask the OP what he was referring to. However, I will post a picture that I have in the morning when I get home.
NUTTSGT
Hopefully this will attach.
This is the back of the Rustoleum label from a can of oil based paint.
dogdog
A noob question... what is this Harderner you guys are speaking off?
mikegt4
sw ohio
I spray Rustoleum thinned with Acetone and get good results. Last summer I repainted a boat trailer that I had painted 15 years ago using Rustoleum and a engine hoist that I rescued from my brother's back yard. Both turned out very good. I refuse to use Rustoleum in the spray can due to the ridiculously high chance of a terminally clogged delivery system but from my own spray gun works great.
aka Larry
Eastern, NC
In the past I've tried a few combinations with Rustoleum. Lacquer Thinner, Mineral spirits, and Acetone. From my limited experience, Acetone indeed worked the best and dried faster.
The last I thing I painted was a trailer in which I used Rustoleum Hammertone Silver thinned with Acetone (approx. 15%), and I added some hardener to reduce the dry time. The hardener definitely sped up the process. Turned out pretty well IMO. About 35 PSI IIRC using the purple HF HVLP gun.
BigSteve63
SW Missouri
aka Larry - Nicely Done!
Stopped by the local Sherwin Williams today and picked up some enamel to paint a Poulan Pro mower deck. Asked about the mineral spirits vs. acetone and was told that the acetone would indeed help with dry time. Was also told to not cut as much with the acetone, but was not given any reason for that - would it dry too fast?
Steve
NUTTSGT
Steve
Possibly, it might spray dry and come out like sand.
