Homemade Heated Jacket/Hoodie Power Supply
rslaback
Westcentral Wisconsin
Let me start this thread by saying the part that I made is now commercially available as a replacement part from Ridgid. It is also $40 plus shipping which for what it is, I find excessive.
Last spring I bought a Dewalt heated jacket from CPO as a clearance item. I also bought a drill kit so that I could scavenge the batteries. I sold the drill, driver and charger and ended up getting the batteries for free. This gave me 3 batteries that I could use with my coat.
Everything worked fine but I've been trying to consolidate my cordless tools into all one battery pack type. I've already built an adapter to use Ridgid batteries on Ryobi tools. Making my jacket use Ridgid batteries was the next step in that endeavor.
This past Sunday night however, that plan changed a bit. I was able to find a unicorn. I bought a Milwaukee M12 heated hoodie kit for $38.02. I think my plan is to keep the Milwaukee hoodie and sell the Dewalt. Luckily for me, the power needs between the two manufacturers are identical so the adapter works with either jacket.
This is the power supply that I came up with.
When I was making my adapter I bought extra power connectors. The shipping was the same for up to 5 of them and they were only about $3 each so it was foolish to buy just one.
I probed the power supply of my Dewalt jacket. The power supply puts out 12vdc power and the center of the connector is positive. As my batteries are 18v nominally I needed a step down module. I picked up this one from eBay for about a buck and a half.
It is rated at 3A (the Dewalt PS is rated at 1A) and is adjustable so I can get exact voltage. It was perfect.
I also knew I'd need the female dc jack. I did some measurement on the coat jack and determined that the dc jack is a 5.5mmx2.1mm connector. For ease of installation I wanted a jack on a pigtail. That led me to purchase this pigtail. The cost was again minimal.
Finally, to put it all in I bought an electronics project box. I got this 100x60x25 box off eBay.
As with buying anything from China, the money you save is paid for in time that you wait. Eventually everything came in.
The first thing to do was to use the template that I made for the adapter project to transfer the size and spacing of the holes I needed for the lock tabs and the connector onto the project box. I did this by taping the template on the box, drilling a small hole and then connecting the holes. I also created a small slot in the end of the box for the dc jack to come out.
Those holes were then cut out with a jigsaw and cleaned up with a knife. Next I did the soldering to connect all the parts together. In doing this, I made sure that the center pin of the dc jack would be positive.
I probed the output terminals on the circuit board and adjusted the circuit until I got an exact 12v of power with a fully charged battery in the connector.
Next I installed the battery connector into the box with a couple of rivets and backing plates. Then I used hot glue to solidly place the circuit board so that nothing could move around and short out. Finally I glued in a small piece of white plastic that I stole from the lid of a jar just to keep the box a bit more water resistant.
I scavenged a belt clip off a free Harbor Freight tape measure and used a rivet to install it to the box cover. I wanted to steal Ridgid's idea of using a belt clip so that the battery can be supported on my belt or in the jacket pouch.
Instead of gluing the box shut, I have it taped around the edges right now with masking tape. Just in case anything ever comes loose inside I wanted to be able to access it. I am planning to switch out the tape to either a good brand of electrical tape or black duct tape the next time I open it.
The only thing left to do was test it out. It passed those tests with flying colors.
kctyphoon
Jersey/Staten Island
just curious of you happen to know if the plug on the Rigid Power source for their heated jacket is the same as the Milwaukee and Dewalt.. im assuming you didnt buy it, so you dont know if the factory power sources are actually interchangable between Rigid and Milwaukee, but rather just built your own to fit your needs.. and WHERE did you find the hoodie for $38??
Still looking for someone who owns the Rigid Heated Jacket to post a review and maybe help with some info.. is anyone out there????
i made my own belt clip for the Milwaukee M18 2.0 batteries.. i really didnt like the weight on my belt and wond up just going back to the M12 batteries for the majority of my time..
nice project though - very nicely done.
EDIT - and i just realized ive been spelling Ridgid wrong my entire life..
R
rslaback
It is the same. I was at the Direct Tools Outlet in Wisconsin Dells this past weekend. The sales guy and I were talking and he mentioned that he gets a lot of guys who come in and buy the Ridgid jacket they have in store and use it with the Dewalt power adapter. The store sells a refurb Ridgid for $130 which beats the **** out of the Dewalt over at Home Depot for $200+.
kctyphoon
without actually having seen it in person - i think the Rigid jacket might be ALMOST the same as the discontinued black Milwaukee 2344/5 jackets..
just has subtle orange accents and the rigid name on the bottom.. it has the same 5 zone heating too.. i really wanna see one in person and know for sure if they will work off each other batteries..
from the online pictures, the Rigid might be my Favorite or 2nd Favorite looking heated jacket.. i should have my 2344 in a couple days - so the jury is still out..
kctyphoon
http://www.refrigiwear.com
Buy a good jacket and don't worry about batteries
you obviously have not tried Milwaukee's heated jacket.. ill stick with my batteries and wearing a long sleeve t shirt / thin Mikwaukee jacket in -18 with the wind chill weather.
i know it works when guys tell me they are going to go warm up in the truck, and i ask if its cold out..
R
rslaback
I may find myself back in that Direct Tools store this weekend. I'll try to remember to wear my Milwaukee hoodie and plug it into the display power pack in store. I'm sure it will be fine but that should give you a for sure answer.
falconero
Where would i be able to find a jacket power supply for a dewalt jacket? How about a adapter from usb port?
falconero
Thanks for the link, coincidently i already have the usb power source. It does not have a round output for the jackets. Which is what i want it for.
R
rslaback
Sorry about that. I made a (poor) assumption that Dewalt wouldn't have two products that are so close to one another. You actually need DCB091. I can't seem to find any vendors for that part solo so you may have to order it as a replacement part for a jacket.
The Dewalt part number appears to be N288459. One source for it is here: http://servicenet.dewalt.com/Parts/Detail/314755
mrvm
PA
No thank l will stay old shool
"Old school" is okay, it works, just like hand tools and knives but some of the heated jackets can be just as warm as "old school" without the heat turned on. Turning on the power source gives the heated jacket an extra advantage especially when your sitting and not moving. The power source in my heated jacket uses the same battery/charger systems as my cordless power tools. This thread demonstrates some ingenuity in designing a power source for a different brand of heated jacket or battery system. Think about how nice and warm it gets when you turn on the heated seats in your car if you have this option.
Twisted Sid
CA
I never knew they made these. Would be awesome if I go back into working in cold storage again.
I know it will depend on temp setting and other factors but how long does a battery typically last?
12three
I am thinking of doing the custom power supply from your OP, rslaback. i have ridgid batteries and a dewalt coat.
does the ridgid battery have the ability to discharge too much?
i once used a craftsman 12v nextec battery with a 12v heated car seat cushion via a simple spade connector... i fell asleep with it on and as a result the craftsman battery threw errors on the charger for about an hour before it finally decided to charge back up.
rlitman
Long Island
Ridgid put their battery protection in the batteries instead of the tool. You shouldn't have any problems with over discharging them.
Which is exactly where it should be for lithium batteries. I'm SHOCKED someone would be dumb enough to put it in the tool. Scary!
R
rslaback
It's about 50/50 with tool companies. I imagine the prevailing thought is that the circuitry costs money so putting it in the tool allows them to save money.
12three
i found a deal on dewalt stuff that included 2.0 ah batteries and a charger. honestly the 2.0ah dewalt battery is a bit bulky and awkward. i think i am going to hold off on doing your mod for ridgid batteries to work with the coat bc my ridgid batteries are 4.0ah and 2.0ah. i think the 4.0 is going to be too big to be comfortable, but your belt clip is a good idea that would benefit even the all-dewalt setup...
on a side note, i have seen ppl create battery packs using old 18650 batteries from laptops (18650s are what is inside most tool battery packs anyways). so i think if i create anything it will probably be creating a custom pack out of 18650s. i think it will be quite a bit slimmer than using dewalt or ridgid bc i can lose the bulky plastic tough cases and i could keep the batteries in the coat with greater ease.
thanks for responding and doing the work to find the proper barrel connector, that will come in handy. i will just have to figure out how to go about charging a custom 18650 pack and doing discharge protection on it too.
12three
i have a wall charger that outputs 12v dc at 1.5Amp thru a barrel conenctor that fits the jacket...
the dewalt adapter puts out 12v dc at 1.0Amp...
do you think that extra .5Amp is going to burn up the jacket??
12three
I wouldn't expect you to have any issues. That said, why would you want a wall adapter for your jacket?
i am planning to do some cold weather camping this year. my thought was that there may be times when i could wear the heated jacket inside a cold camper instead of running the furnace and save a lot of energy. from what i can tell from just using the coat a few times it could work out fairly well in terms of saving energy bc the camper heaters have quite a few issues. they are either an electric hog or produce a wet-heat if they are propane fired.
i would be able to give the tool batteries a rest if i ran the wall charger off an inverter connected to the camper batteries
