New Craftsman Extreme Grip tools
Tellingthem
Traverse City, Michigan
I saw this cruising the Sears website. New Craftsman Extreme Grip tools Link:. They have screwdrivers, wrenches, sockets, and some adjustable locking wrench thingy. Looks like mostly gimmicky type stuff but kind of interesting.
prod_1349947412
spin_prod_1324738412
spin_prod_1324736612
prod_1349948612
prod_1386276112
Bobcat753
New Hampshire
The sockets and screwdrivers look interesting. The other things are just plain stupid. Guess I'll look at them on my break tomorrow.
MrJason
Bakersfield, CA.
Am I the only one who thinks that the locking adjustable wrench is just over compensation?
If you have enough room to use that, then you have room to use more applicable tools.
Gimmicky and a useless attempt at relevance. IMO.
Jason
oak_park
Chicago
The ratcheting wrenches look like 6 points, and the banded sockets remind me of the old stainless/lifetime era sockets.
ADSR
wow! Check the finish on these. Looks like they tossed them in a cement mixer with drain rock.
prod_1386277312
Tanro
Ah more gimmick tools. Ffs when will they learn?
More of the one size fits many wrenches....really?!
the74impala
Trying to go light weight / minimal space, they might be just right. Not for at home/pro use, but on the road might make a lot of sense.
thecody59
Twin cities, MN
The screwdriver set looks pretty good you can use a $10 of $20 coupon to get the price down. But still seams pricey for Chinese screwdrivers.
the74impala
In fact, covering maybe 15 wrenches with 5 in the back of the car, would be nice if the price is right and they actually worked. The screwdrivers are well made, they look good too.
nicksnothereman
In the Mojave
I don't understand what I'm looking at with the sockets and wrenches.:bounce:
Diamond tip screwdrivers? They done lost their mind.:thumbup:
Don't get me wrong...new stuff is never bad. Just uh make sure it works as intended okay guys.
zcbauer89
NW OH
I was wondering what we'd see in time for Father's Day. Interestingly, they've used the "Extreme Grip" branding before.
It looks like the wrenches work like the old "pocket sockets" (and similar gimmick tools throughout the years). The sockets seem to have three "jaws" that I guess you tighten onto the flats of the fastener.
Stanley has, of course, made locking adjustable wrenches for a while now.
I wonder what the gimmick with the screwdrivers is. Maybe anti-cam-out tips (which would actually be useful, but even the Craftsman Mach series had one useful tool). The handles look the same as (or at least very similar to) the spinner handles that come with the Max Axess pass-through socket sets. Also kind of remind me of the original Craftsman Professional screwdrivers from years back.
Those "pocket sockets" are actually pretty good at holding punches and chisels. I think every guy got a set of those years ago. This new line reminds me of that Skil wrench that came out this past Christmas, which seemed like a real knuckle breaker. This is a gimmicky line of tools, that may be okay for the kitchen junk drawer, but would waste space in any tool box, or my tool box anyway.
Gmonkee
My "muscle wrench" adusts from 8 mm to 19 mm. Makes for a very short 19 mm and a very thick 8 mm. 11mm of adjustment is too much. Its not a good tool at the extremes.
This sports that off corner broaching and adjusts 12 - 13mm for a range of about 1.5mm adjustment total. That brings ( or should ) head size into a tighter range and length also where you would be able to use it as intended more easily.
Moviing parts make it a little thicker than a fixed size wrench. But not nearly as bad as other efforts like the Bionic wrench and its Asain clone were in bulk issues.
A downside l see is 6 pt box ends make 30 degrees of movement between positions and this is where we lose pros and head deep into daddy's day gifts, a 12 pt box end gives 15 and has become regular in auto work. Then decor them with rubber grips and drive that home.
Then the screwdrivers, to maximize on the name more than innovate maybe? Every handle variation short of a cube has been tried over the last century so this has to be easy efforts by marketing dept. more than a breakthrough design.
sk farmer
nd
out mexican corespondant is pretty quick at figuring the ins and outs of tools from pictures. most of what you say seems spot on.
a slightly better attempt with similar poor results.
tjpavlov
Providence, RI
What does the AE stand for? I don't remember seeing that code before.
From the background pics, it looks like a ratchet is coming too.
Hootbro
Delaware
Date code. Most of the new Craftsman stuff has it.
AA = 2011
AB = 2012
AC = 2013
AD = 2014
AE = 2015
See the pattern?
Some tools will have have a prefix pattern like "L-AD", "S-AD" and similiar. Those prefix letters are either a country of origin code and/or manufacturer code.
Pstychologist
I had a locking adjustable wrench about 25 years ago, so it's not a new concept. I really liked it on the farm because I could put it on to hold the other end of a long bolt and it would stay. I wonder where that went to?!
Parrothead
Earth
Confirmed the screwdrivers are made in China
Me: Model #25006 if that helps?
Stephanie G: Let me try if I can pull it up.
Stephanie G: Thank you.
Me: xxxxx is my zip code
Stephanie G: I was able to pull it up, Sir. Please give me a minute or two to verify where it's made.
Me: No problem
Stephanie G: Thank you for waiting. This is made in China, Sir.
Me: Okay, that's what I thought. I am sorry to hear that, I won't need to purchase these then. Thanks for your time and effort.
tjpavlov
Providence, RI
I wonder what that says for the Western Forge Partnership. The wood chisels seem to be going chinese right now. I wonder how long the regular screwdrivers will last before they get outsourced.
Hootbro
Delaware
This just my theory but I believe the only reason the regular Craftsman screwdrivers have not gone off shore is that WF makes enough drivers for economy of scale pricing that offshore drivers and shipping cost to get them here does not make them cost advantage to outsource yet.
It is now pushing into the 4th year since Sears has started to convert over the majority of their previously USA made hard line tools to overseas sources. One would think if getting foreign made drivers was cheaper, they would have already.
My only caveat to my thinking is maybe Sears/Craftsman had some long lead contracts with WF that has yet to expire?
Wizzard
Craftsman needs to come to the realization that gimmick tools are not an acceptable substitute for bringing back quality USA made tools to their store shelves. They are going the wrong direction. Kobalt did the gimmick tools thing for a little while as well...now their tools are mostly junk these days.
Parrothead
Earth
On some level, I agree with you. However, I suspect the contract is running out at WF and this will be the end of WF for Sears/Craftsman. Watch the pliers and adjustable wrenches follow suit. If they've been dumping all of the other stuff, why not the drivers too? Get it while you can, because it's never coming back.
Gmonkee
Evolv, Dunlap, Sears, Mach or this one its not the CM core line of old that most expect. Because even they know its a short run to cash out on fast. Hype sells and the unsuspect ing will buy, hell, l'd buy the sockets and the wrenches on clearance table prices.
just because we'll never see this stuff again.
l really am curious about how that socket is designed to adjust. Those have been marketed before but much chunkier . This looks like Bionic wrench tech gone micro.
dede2897234
Northern, Ohio
The Craftsman Extreme Socket set is very similar in concept to Grip-Tite's to using internal moveable pins to provide more grip to removing rounded and rusted fasteners. However, as you can see below, the Craftsman socket uses less and wider pins than the Grip-Tite model.
I hope the manufacturer of the Craftsman sockets does not use plastic parts (Amazon reviews for Grip-
Tite
) like the Grip-Tite sockets. Otherwise, the customers of the Craftsman Extreme Socket sets will be taking full advantage of the full warranty. :lol_hitti
Dave
dede2897234
Northern, Ohio
For slightly more than $6 a screwdriver at introduction on 5/16/15, Craftsman should have incorporated a hex bolster between the handle and driver shaft of their Extreme Grip diamond tip set. If this screwdriver is intended to drive out slightly rounded or rusted fasteners (slotted and Phillips), this tool should be full featured like the competition.
Besides, the set is made in China. The ********* tool consumer will not buy this set because of this fact. However, it won't stop the DIY crowd from buying it if the price is right like on sale around Father's Day.
Dave
Pstychologist
I noticed that a lot of reviews for this sort of product start with "I got my husband this for X" and how happy they are with it.
IF your wife is buying you tools you didn't pick out, of course you are happy, but that doesn't mean you'd ever buy that tool yourself.
