Quartz Double Broadcast Floor
12ozd
at the kegerator
Something a little different;
I just finished doing my garage floor.
It was a complete disaster form the day it was poured.
Slab was not flat, improper slope, bowls, Saw cut a crooked joint in the middle,etc. etc.
Contractor tried to repair w/ coating (applied by 2x4 and brick).
Had 3 different contractors tell me the only fix was to demo and re-pour.
That wasn't gonna happen, so You know the old saying...."Do it yourself"
(there is another thread I started w/ pics last year, if you're really bored)
Anyway.......I spent ALOT of time reading everyones flooring threads, and none really solved my issues. I needed alot of hide/build to cover the ugly.
Enter benwah, I Pm'd him w/ some questions, seeking advice, and he recommended a system I never heard of before, didn't know I've seen them, but would solve the ugly floor issues !
Double broadcast quartz floor..Here's how he explained it to me.
1. prime coat
2. 100% solids epoxy coat, broadcast to refusal with quartz or silica sand @ 20 mils
3. 100% solids epoxy coat, broadcast to refusal with quartz or silica sand @ 20 mils
4. clear or pigmented 100% solids epoxy coat
5. clear or pigmented polyurethane/polyaspartic (optional)
Sounds perfect !!I made a couple changes, I liked the quartz look, but not the price.
So benwah says; use sand for the first coat, it's going to be covered up anyway. Brilliant !..Quartz is $70.00 a bag, sand is $7.00 !
PM Justin @ GFLLC, he has exactly what I'm looking for.
Following his recommendations, ORDER PLACED !
Now for some pics;
BEFORE
Crooked joint, "smear coat"
Finished corner
Drain
Kinda thick, huh?
l
12ozd
at the kegerator
On to the prep
Diamabrush w/ buffer and dust skirt
Works pretty good
Amount from a 10 x 10
Half way there, looking better!
All done
Here's a little tip, wrap the vac hose and (buffer) electric cord together
makes moving around alot easier
12ozd
at the kegerator
My "Crash cart" keeps everything together and stops me from moving it 20 times
Still wet :lol_hitti
Materials arrived...Thanks Justin :thumbup:
Silica sand (picked up locally)
12ozd
at the kegerator
Primer ready to go !
Primer coat down (note arrows on walls, define measured space)
1st epoxy coat, broadcast w/ sand
Full broadcast
12ozd
at the kegerator
Now we run into problems...
After sweeping sand from floor, this is what I found:confused:
Spike shoes were hard for me to get used to, did alot of slipping
the marks dried in the epoxy
had a few spots that looked pretty bad
So...buffer and 60 grit sand paper, prep for 2nd coat
12ozd
at the kegerator
My topcoat didn't cover as much as I thought, so timed out on it.
I wasn't able to apply 2nd coat w/ in time requirements.
I called Justin, he got some out really fast !!
( I think I still have to pay him :bounce:)
The recommended prep before re-coat was to scuff and solvent wipe.
I was not looking forward to that.
Garage Journal to the rescue.
Scotty recommended a Mal-grit brush. (thank you :beer:)
So it was off to the buffer AGAIN:mad:
Worked like a champ!:thumbup:
12ozd
at the kegerator
I will post a current pic w/ completed top coats.
This is a cross section w/ a mil gauge we keep hearing about from the pros here.
(courtesy benwah)
Needless to say I am very happy w/ the results.
Looks alot better than I expected.
Justin @ GFLLC was great to work with, top notch materials, and customer service!
Saved a bit of money taking advantage of his loaner tools.
benwah was a great source of information, thank you my friend.
(Feel free to seek information from either one of these guys)
'cause if you ask me, I'm gonna PM them:lol_hitti
Seriously, I would be glad to answer any questions.:beer:
Thanks for looking at my project.
fury9
Mchenry, IlLaHnoYs
Looks fantastic to me, even though the finished pic isn't up yet. Do you think you'll have ant trouble with jack stands or rolling heavy loads around?
12ozd
at the kegerator
ADSR
Wow! What a transformation! That was a lot of work!
Well done!
Garage Flooring
Grand Junction, CO
The job looks incredible and we greatly enjoyed working with you.
A couple of notes here:
He used our clear epoxy specifically for broadcast systems. http://www.garageflooringllc.com/clear-epoxy-for-mica-and-quartz-full-broadcast-systems/ as in many cases, we encouraged him to go direct on the quartz as often that is cheaper.
The silica sand broadcast is not something we had done before. Looks like that portion turned out well!
A lot of times in full broadcast systems we find a single clear epoxy top coat followed by an aliphatic top coat is the way to go. In this case we did two coats of aliphatic.
The nice thing about doing the epoxy as the first coat is it goes on thicker.
The entire project was an amazing thing to work with on a supply side of things. This all started with a simple Rust Bullet project and what has emerged from it is a lot of fun.
Shea
California
Great job! Very smart using all the resources and help available here. You now have an extremely durable garage floor that may last longer than you :thumbup:
12ozd
at the kegerator
Well done!
The job looks incredible .
Thank you !
Great job! To everyone envolved.
Great job!
Was hoping you two would chime in, saw aot of your posts during my "research". Appreciate feedback from the pros.
Speaking of resources, I spent ALOT of time @ All Garage Floors.:bowdown:
Thanks for that site, it was invaluable while doing my research.
(glad you, Justin, and benwah didn't charge me by the hour :lol:)
benwah
Lakewood, Colorado
Great looking floor D! I am glad everything turned out well for you man... Now it's time to start bustin' down rigs on that, right?!?!:lol_hitti
In all seriousness, you put an extreme amount of work into this floor, and I hope it lasts you a long, long long, time! :thumbup: Glad this system worked out for you, and yeah, looks MUCH better!
I can tell your level of craftsmanship is above most and attention to detail is on point! Get with me anytime my friend :beer:
12ozd
at the kegerator
Here's a couple before and after shots (same corner, different angle)
12ozd
at the kegerator
Black base sets it off pretty nice. (crooked saw cut gone !!)
ripkinc
Wow! This is what I want to do. Do you havea estimatedfinal cost per square foot?
EricVonHa
Eastern Pa
All in, a minimum of $3 per square foot.
This includes the cost of the quartz/sand and grinder/buffer rental.
Friend labor for assistance is priceless.
Ben is a good guy. I recently went through a similar finish installation and his expertise is amazing.
