Harris welding torch, tips info
kunkernator
US of A
I have had an oxy/acetylene rig for a while now, I have a Harris handle, with a cutting torch (only ever had to use for cutting). Anyway, I want to venture in to brazing, and heating with the same handle.
My understanding is Harris requires a mixer in between the handle and the tip. I purchased a #5 welding tip, and a Harris compatible rosebud.
Now, what mixer do I need to buy? The best diagram I found is from McMaster Carr
http://www.mcmaster.com/#catalog/121/3404
And I assume that since I have a medium duty handle, I would need a D-85 mixer? I have found it for $25 on ebay, or $30 on Amazon.
Can someone confirm this, or clarify any misunderstanding I have?:dunno:
Thanks!
Strouty
Southern Maine
If it was designed for cutting I would think it has the mixer built in. Usually you just unscrew the cutting torch from the body and add a rosebud or welding/brazing tips. Do you have any pictures? It may be an older style that is all one piece.
Strouty
Southern Maine
I guess I was on the wrong part, I was thinking the mixer was the valves on the body. My bad, but that search really threw me off my game.
K
kunkernator
US of A
trackwelder
n.y
The mixer is not in the handle of two piece torches. Quite a few torch companies build their welding and heating tips with the nozzle and mixer as one unit. Some have models that allow the nozzle to thread off the mixer. I prefer Smith which can be swapped with just your hand no wrench needed.
Strouty
Southern Maine
Smith is what I am used to. I haven't used a lot of other brands.
