Maxjax lift column leveling vs pad leveling
Denwood
Thunder Bay, Ontario, Canada
I've had my Maxjax lift for a year or so now and have been dealing with the fact that my garage slab "tilts" to one side of the garage by about 1.5 inches, over 16ft. With the Maxjax columns perfectly level and plumb, the pads don't match each other. This means I've had to use a floor jack and lift one side of car to get the right arms/pads (looking at them from the front) under my Audi.
I've figured that columns should be 100% plumb and level, until I did some reading on the subject. Jeff from Bendpak advised that having the pad levels match was more important (and safer) than column plumb. Having spoken with MaxJax (Danmar) today, it looks like Jeff knows what he's talking about :)
Here is an exaggerated image of the situation from pirate4x4.com
Here's my lift as it appears now that I've shimmed both columns (both "lean" slightly to the left now) and my pads/arms match. The columns are almost exactly parallel (+- 1/8"), an important safety consideration.
Jeff's original post was here on the journal:
http://www.garagejournal.com/forum/showthread.php?t=65457
That same post has made it onto Bendpak's site:
http://www.bendpak.com/car-lifts/two-post-lifts/leveling-shimming-two-post-lift-instructions.pdf
Gentlemen,
Good comments, but I was talking in general lift installation language. I understand the difference between the terms level, plumb and perpendicular, but field language has a way of evolving.
The majority of lift installers will use the term level when talking about runway type lifts, runways level, cross tubes level etc., and plumb when talking about two-posts. Perpendicular is rarely used. When plumb is used, it's usually both directions, with a level, and the bubble neatly between the lines, gravity.
Perpendicular columns to a sloped floor would result in un-plumb columns and unlevel pads just as plumb columns on a sloped floor will also result in unlevel pads (relative to left and right pads respectively) – assuming you did not raise the low side column.
Let’s assume our subject floor has a one-inch slope east to west with the high side being on the right column. (My comments are not related to floor sloping from front to back or vice versa. Mainly lateral slopes that have a way of dramatically affecting pad height due to the lateral outreach of the lift arms). We’ll assume the overall width on our subject floor is 12-feet at outside of base plate for the floor plan. That would be less than 1/8” of slope every foot. Could easily be perceived as a normal floor.
We have three options…
• Install the lift directly on the surface and shim only as necessary to plumb the columns. In this case, your lift pads would be one inch off – right to left. Assuming where your arms are positioned on the vehicle and the distance between pads, that one-inch could translate to dramatically sloped loading.
• Install the high side (right) column directly on the surface and elevate the low side (left) column an additional one inch with steel shim plates and Quikrete. Plumb both as required. In this case, even though the floor is sloped one inch, the columns would be installed plumb and the lift pads would be equal. This may be considered the “correct” way to do it, however you now would have 25% less embedment on the anchor bolts assuming longer ones were not purchased, and you would have different pad heights relative to floor surface with respect to vehicles sitting on the floor. You may squeak a lift pad under the right side of the car, but find out the left side pad is too high for your ground hugger.
• Third way – as I attempted to describe in previous post with final outcome being level pads and parallel columns.
I reviewed some engineering calculations assuming a 12,000-pound capacity two-post floor-plate model (with no top beam) – a kind of worst case. A ½” shim on the outside edge (or inside edge) of the base plate would cause the base plate to be at a 1.35-degree angle with respect to the floor. Lifts with smaller base plates more – maybe 1.75 degrees. A shim that thick would adjust the pad height position considerably - at least 2” of vertical movement just on the one column side. That is why in most cases, shims no thicker than 3/16” are all that is ever required to adjust pad height.
Assume a 12K two-post floor-plate model has been shimmed ½” on just one edge of the base plate only and is angled about 1.35 degrees based on the dimension of the typically sized base plate. Assume it has an arm that measures 45.1” to the center of the lift pad from the main column centerline when loaded. NOTE: The arm may be longer, but when positioned as it would be during vehicle lifting, the pad would be approximately 45.1” from the main column centerline = moment. The column will also be tilted 1.35 degrees with respect to vertical. When fully raised, the lift head is 75.6” above the floor and the arms move horizontally 1.78" from their original position. The moment arm has increased from 45.1” to 46.9” which is an increase of 4.0%. Due to the moment arm increasing 4%, the column bending moment arm will also increase by 4 %. Therefore, the moment applied to the column and transmitted to the base plate will increase 4%. A 4% additional moment load would increase the anchor bolt tension load from 2772 lbs to 2882 lbs. A single Wej-It 3/4” anchor bolt embedded 5” deep in 3000PSI concrete would have a rated tension capacity of 12,000 pounds or more. Two post lifts with a top beam would have less of a bending moment penalty due to shimming. Main lift structural components would be virtually unaffected by this slight increase in moment loading.
Bottom line, raising vehicles not perfectly centered between your columns will add more stress on the column, base plates, and anchors, than shimming out of plumb a degree or two. Either case, the stresses are very minimal. (At least on ETL certified lifts or those designed with similar criteria.) Two-post lifts rarely need shims greater than 1/4" thick, but you would be surprised what affect even the slightest shimming has on pad height adjustment.
Jeff
BendPak
Mr onetwo
Coastal Maine
Good write up Dennis...there is a lot of mis-information/hysteria about the loads on 2 post lifts...in particular the MaxJax.
D
Denwood
Thanks Mr. :) The setup in my shop is much better now with the pads matched. If I hadn't shot between the columns with a recently acquired self leveling laser, I would not have been able to accurately measure the height discrepancy on the floor. The laser level is a pretty handy tool to have during setup, ideally before you pour concrete :)
In My Garage
ON
You can say that again.
Some experts on here think there are greater fore and aft moments than inward moments on the columns, even when the vehicle is lifted about its center of gravity between the columns. Simply amazing.
D
Denwood
Alex, I hear what you're saying (albeit a very late response!). It's been about 7 months since I leveled the pads and the hoist is a lot easier to load now, particularly with lower vehicles. My retro slab has done two winters now with inside temps regularly below freezing. Zero cracks and zero issues with the hoist.
