My first broken snap on socket.
OHMS LAW
Houston TX
I was using my long 3/8 rat tightening a hub assembly and I went for the final crank the socket gave way and i damn near busted my hand. Will warranty it but i only had it about 4 years and i never even used it on a impact
Ponchoguy
It happens, I wouldn't worry about it per se. I broke a Snap On Torx socket on a brake caliper mounting bolt and I was surprised at that. Back in the day, a little bit of an act of Congress to get it replaced, but eventually it worked out.
O
OHMS LAW
Houston TX
Sorry I can't add more than one attachment at a time on my phone
O
OHMS LAW
Houston TX
My snap on guy is pretty good. He will warranty stuff regardless of age or if I bought it from someone else. It doesn't hurt I pay in crispy bills every time I see him
Zrexxer
Pflugerville, TX
I've broken Mac, Matco, and Craftsman sockets like that; it happens. Can't say I've ever broken a Snap On, though.
Olson Boy
Find the snap on guy, or call corporate, show them the broke socket and recieve a new socket. It's pretty easy.
purplezr2
Central MN
13mm deep socket?
Deep sockets are much more prone to break. Guessing I have broke 50 over the last ten years. Mostly all C-man, but I have broke a snap on one too.
O
OHMS LAW
Houston TX
Lol. Thanks guys. Switched careers a few years ago and now I'm getting to the real meat of the job. There is no point to this thread. Just sharing isn't that what we do here?��
O
OHMS LAW
Houston TX
I normally use a mid length chrome or the impact 13 but that day for some reason I just grabbed the deep. I haven't used those in a while
90zcar
Lol. Thanks guys. Switched careers a few years ago and now I'm getting to the real meat of the job. There is no point to this thread. Just sharing isn't that what we do here?í*@#$½í²[emoji767]
Ur fine man. This forum is to talk about tools and garage stuff. There isn't a single topic that hasn't been covered atleast twice on here. Sometimes people get worked up when they feel a topic isn't worthy of posting.
Anyways that's cool just get it warrantied. I myself haven't actually broken a snap on socket yet. I have broken a snap on wobble extension before and other things as well.
Wakefield
Arlington VA (but would like to get out to country
Probably contained an air bubble or speck of slag that made a cavity inside of the metal of the wall. Doesn't look like it had offcenter mouth unlike a socket I broke.
I wonder if NASA screens theirs with X ray or something to try to catch the problem before it happens?
Deej
Colorado
I broke a snap on socket yesterday too. Mine was a 3/8 drive semi deep 1/4. usually its the 8mm sockets that always break on me
rlitman
Long Island
Are you talking about the tools that go to space? The EVA tools aren't steel. It gets too brittle at the low temperature extremes. But I believe they carry a few sets of normal sockets for inside use too. There have been writeups on them, and from what I've seen, they're off the truck stuff.
Karl_B
Killeen, TX
I find that sticking to short sockets in high-torque situations helps keep my sockets in one piece. If you have to use a deep, make sure you put pressure on it to keep firmly and squarely seated on the fastener. It also helps keep you from tearing yourself up, and we don't come with warranties.
Empty Pockets
Rural New York
My SnapOn guy is happy to take worn folded currency, too
Sent from my SCH-I535 using Tapatalk
abvw
Toronto, Canada
Did an Escalade wheel hub/bearing and cracked the 15mm semi-deep with my FLL80 (last bolt). It made a loud bang but luckily nothing gave up. Still finished the job with it.
One of my friend uses the deep 8mm chrome on impact all the time, cracked it and still use it for two years before he finally got a driver to replace it.
They're not indestructible. Take a picture for memories, and send it back for warranty. Next time step up to a bigger drive size.
MikeF2316
Thornhill, ON
It seems some on here feel physical pain whenever they see or hear about anything Snap-on that fails or breaks for any reason. :lol_hitti
Disclaimer: I have a couple of dozen Snap-on tools and a toolbox and I've never broken any of them, or any part of the toolbox.
d.mcfarland
Western PA
I wonder where the broken part was in relation to the direction of the handle? I'm guessing the crack took some weird stress and the twist motion then compounded it to failure.
2ndGearRubber
Pittsburgh
Welcome to the club. I bought bulk Zypher torx bits after destroying handfuls of the snap on gold bits, split snap-on sockets, blown up ratchets, etc. If you use anything enough, it will fail eventually, especially in a shop environment with high use.
Kent_B
MI
14 mm. deep 3/8 drive Snap On broke on a hub bolt on my Subaru sedan. Same scenario, long handled ratchet & it split. Being as it's 30 years old, I don't feel right trying to get it warrantied.
