hancock1701
I was replacing the lower control arms on my 2003 Honda Accord this past weekend. I thought it would be fairly straightforward and quick, until something was messed up and had to spend the rest of the day fixing that.
I used a ball joint separator, the 3 prong press type, not the pickle fork. The first time I used it on the lower ball joint (which was on the knuckle), it compressed the bolt so much that the threads expanded and the hole (for the cotter pin) got smaller, which gave me trouble when putting the castle nut back on. And there was a really loud noise when the ball joint was separated.
The second time I put another nut (not the castle nut) back on flush with the bolt, then both pressed and hammered it.
I'm not a professional mechanic, so please school me on the proper way to use (or when not to use) that ball joint separator. Is the nut always required? Can the castle nut be used for that?
http://www.amazon.com/gp/product/B003YVWHOE/?tag=atomicindus08-20
