Galvanized pipe for compressor run?
matt_i
"it works" but its not the right stuff. The galvanization can break off in chip form and kludge up the works downstream.
If there's a choice use black iron (steel) pipe
coljar
Belpre, Ohio
I ran black iron myself, but we have miles of galv. air lines here at work and a good amount is supplying instrument air to millions of dollars worth of machinery.
koditten
Midland, Michigan
I used galvanized electrical conduit. I don't know what the difference between that and galvanized pipe, but the price was $3 a stick cheaper.
Radix2
the thumb!, MI
yah, because we know steel pipe full of moisture, rust, oil, and gods knows what else never kludged up anything downstream...:evil:
I seriously doubt that ungalvanized is the right stuff for any reason other than it is the cheapest stuff sufficient to do the job.
bob15
Northeasten, CT
And what happens when the black iron develops rust inside? Same results.
To the OP:
Galvanized pipe is fine, as is black iron. Or to go all out, use copper.
NUTTSGT
Northern Central Ohio
I used black pipe for mine but I considered galvanized. I wanted to paint my some I went with black pipe plus it was slightly cheaper. As far as I'm concerned, either one is better than what I replaced.
koditten
Midland, Michigan
No problem, I should have stated it was rigid, threaded electrical conduit. Sometimes I forget that not all of us have been around building materials. Sorry.
ryolse
Colorado
Actually I'm a controls contractor who's around sites new and old for the last 11 years. We just always use EMT and use rigid very rarely except where it's required for explosion proofed spaces.
C
crooklyn
Prince George, BC
It'll be fine, that's what I used in my shop.
I used galvanized pipe, been working fine for 8 years now.
To the OP:
Thanks all for the response. I will be using Galvanized especially as I'm able to get it for dirt cheap at work :)
What else can I make out of galvanized pipe? Maybe that's for another post
rburke65
Canfield, Ohio
ryolse.....you may have "been around sites for 11 years" but you have never seen EMT used for a compressed air lines!
Techie1961
Pickering Ontario Canada
Galvanized is what I prefer when putting in a new dry cleaning plant. I don't like black pipe and copper makes me nervous. If it was silver brazed, no problem but regular solder comes apart too easily in my view.
This is an example of what black pipe can look like after a few years. I have seen this more than a few times in a system where there is a lot of use and not the best water control at the compressor. I have seen lines completely blocked with rusty **** in them. This is what I managed to loosen up in a customer's air line with black pipe. The air line is shown disconnected top center of the photo.
Techie1961
Are some of you actually using electrical EMT for running air lines? Is it possible that some of the responses to this thread are referring to the electrical lines for the air compressors. I would never dream of using non-pressure rated tubing for air lines. That's what EMT is isn't it? Please clarify me if I am wrong.
coljar
Belpre, Ohio
Fortunately, you're wrong.:thumbup: Post #8,9,11,13 will explain what went down.
Techie1961
Thanks for that coljar, I saw them and am still a bit confused. What is "threaded galvanized electrical conduit"? I've seen electrical ******* that are marked as electrical use and even those, I wouldn't use for pressure applications. Hoping to be educated here.:thumbup:
Techie1961
Okay, found some answers. Rigid electrical conduit isn't pressure rated and should not be used for air line applications. There seems to be some discrepancy on whether they come with tapered pipe threads or straight and obviously, a threading die will cut a tapered thread if you are doing it yourself. Still, I wouldn't use tubing/pipe that isn't certified for pressure if it was me.
ryolse
Colorado
And where did you assume that I ever said that I have ever seen EMT used for pressurized pipe or that it is appropriate to use?
Charles (in GA)
50 mi south of Atlanta
3/4 makes good downrods for ceiling fans if you need a custom length, esp if real long. I made 4 ft ones from 3/4 galvanized water pipe. Just requires care to drill the cross pin hole and the drill and tap the threaded hole for the gound wire.
Doozer75
Buffalo NY
You can use regular thin EMT for air or water.
Copper elbows and fittings solder right on.
I know this guy that owns a local bar.
He is really cheap.
He plumbed the bathrooms with 1/2" thin EMT
and soldered on copper fittings. Still there and
that was over 20 years ago.
-Doozer
mike_dmt
Spokane Washington
I've heard of guys using PEX. Would that be the cheapest option? I'm doing my air lines in the next week or two, so I've been kicking options around.
yaidunno
WI
He is really cheap.
-Doozer
For the record, EMT is in no way rated for pressure, and should never be considered for compressed air applications, or even water. It's one and only use is a raceway for wire.
Just because Joe Shmo was cheap and scabbed together his plumbing does not make it correct.
To the OP, use a proven, pressure rated pipe for your install. Black, galvanized, or copper will all do just fine. Compressed air can have serious consequences if not handled properly. The difference in cost is should not even be considered when choosing a quality, safe air system.
nadogail
Coronado, CA
Rigid Conduit threads are the same form and pitch as pipe threads. The threaded ends are straight instead of tapered, so you will not get the sealing like you get with pipe joints.
Additionally conduit is not rated for pressure like pipe, so can not be depended upon to remain intact when pressurized.
In my opinion, conduit is a poor choice for compressed air use.
matt_i
If it leaks due to poor threadform, the $3 saved per stick will be long gone. Compressed air is very expensive.
Another view: galvanized pipe is unusable for natural gas lines....and those run either 1/4psi or 1/2psi...my understanding is because of the propensity of galvanized flakes to accumulate...my personal feeling is that's not going to alleviate under conditions with 100+ psi differentials.
Copper is of course highest cost and best practice. In my opinion, the solder to use is Stay Brite #8. It melts with a regular propane torch, flows like the old leaded solders (although no lead, NSF rated safe for potable water lines). Much higher tensile than your generic big box "lead free plumbing solder" and most importantly, the alloy will not "creep" under load. Of course, the solder also costs more too :) But, an important detail when designing a ~175psi pipe system rather than a 50psi potable water system.
sberry
Brethren, Michigan
These threads spin to nonsense fast.
Get a couple sticks of 1/2 black pipe and a few simple fittings to make a manifold to get to where you need it. Ball valve after the comp and then a hose to the pipe. I like to stick with 1/2 where I can, makes it so easy to fit and least use of fittings.
JunkYardDawg
Maine
I've just always used black pipe and painted it green per ANSI. Those practices used at work make sense in my home shop as well.
sberry
Brethren, Michigan
A lot of concepts people see at work are not practical for a home garage. Some of them downright not good ideas and the downside is a lot of expense and effort. They may also induce problems.
I would have guessed green was O2
sberry
Brethren, Michigan
When I entered the work world I figured I could outsmart the old guys that said use black pipe. These were guys 20 years ahead of me. Today my stock answer and if a bud wanted help piping a circuit in a small garage would use 1/2 black pipe as was suggested then. Its what old timers 20 yrs ahead of me still have.
yaidunno
WI
2007 ANSI/ASME A13.1 calls for compressed air to be blue with white markings. Green is to be used for non hazardous liquid. Please correct me if I'm wrong, but these are the standards I've seen and read about.
koditten
Midland, Michigan
I have my own pipe threader. My threads are exactly the same as pipe threads. My compressed system is charged 24/7. I have no leaks.
I find the galvanized threads better. The black iron would tear while threading. I found this out while plumbing my gas lines.
Use black iron if you can afford the american made, not mexico black iron pipe.
I did want to see pics of this thin wall, EMT tubing soldered to copper.
sberry
Brethren, Michigan
I used some home store 1/2 black and did have to make a thread and it seems to me I recall something funny about it but I put it together on the floor farmertite and it didn't leak.
I am actually a fan of the box store pipe in the fact it is available and cheap. Its 10 ft and with even a small imagination can make up from ready made parts and when you get down short the selection of ****** length is super.
Most small garages would be well served by half a dozen pieces and half a dozen fittings. I have some pieces of galv in here and there, cant see as it hurts a thing.
SmokeyBC
Salmon Arm
I used PVC pipe, schedule 80 wall thickness. I put it in my home shop 12 years ago, no problems.
I know, but I've had no problems, and its easy to add drops and other changes.
coljar
Belpre, Ohio
Ok, the pot is full and the fire's going. Now where is that ladel?:lol:
