Porter Cable, DeWalt, Craftsman, Black & Decker, & Mac Tools... all seem to use the same 20v lithium ion battery system system, as if made by the same parent company. They are identical in slide mounting style at the bottom of the tool handle, using the same mounting direction and beveled retention and release tab, and are only differentiated by the button and spring design of the release, and various interference tabs in the molding to prevent owners of one brand from buying the batteries of another brand.
This is NOT the case with the 18V Lithium Ion systems, as there are substantial physical as well a few small electrical differences across various brands with 18 volt battery systems. However, in the latest crop of 20 volt lithium ion systems from the brands listed above appear to have all standardized on one battery system manufacturer/supplier/design.
The irony is two fold... first, even though the mechanical attachment and retention systems are common across most of all of the 20v tool brands, they are purposely prevented from being interchangeable with small differences in their plastic molds.
The second irony is that a 20V battery really is still really an 18v battery, but appears to be marketed as a 20v by measuring the elevated surface charge fresh off the charger. Much like a car battery is 12v, but can measure a surface charge as high as 13.2 volts when taken fresh off of a charger with no load being applied.
