Small shop/garage build in Arizona
steveivy
Gilbert, AZ
Hey folks,
A couple of years ago my wife and I decided to move onto a more rural patch in the middle of suburban Gilbert, Arizona. Our plot is 0.99 acre, and the original garage had been closed in to make a bonus room.
So, after several iterations on a design and going around with the city some, I finally got to "break ground" on it about 6 months ago. I contracted out the concrete, but have been building the structure myself. It's approx 30' x 28', with a low-pitch that tops out at around 10'.
This was after cutting the existing driveway for the foundation and stemwall...
Dug out...
After the footers and stemwall and final finish concrete was done...
Framing the 28x6 storage area across the back...
The side walls going up...
Framing out the garage door openings...
The first joist (yeah I hung all of them myself with a couple of ladders)...
(Follow up post coming!)
steveivy
Gilbert, AZ
Roof joists going up...
Ready for decking...
Moved my portable workbench and some tools inside to have them more handy...
Temporary bench for my miter saw made from 2x's and cabinets I recently liberated from a guest bath that is being remodeled.
Plans laid out on the podium I got for free when outer church moved into a new building and they didn't like the one that was there...
Thanks for reading, I'll post more as I get them. Right now the walls are all sheathed and the roof decking and fascia are complete. Getting the inspector out for strap-and-shear, then I get the roofer and electrician in.
Unfortunately in the end I only get half of it for my welding shop - the other half is for the wife's minivan!!
Cheers,
--Steve
rattle_snake
Chandler, AZ
Looks good Steve. Who are you going to have do the roof and stucco? I'm in chandler (chandler heights/gilbert) and about to start a similar project.
When its done just pile your stuff so that the minivan won't fit and continue to make excuses until she gives up.
steveivy
Gilbert, AZ
Hey rattle_snake,
I've got a roofer and a masonry/stucco guy that my concrete guy connected me with. Reasonable rates so far. (Do these forums have PMs? If so PM me for names/contact)
steveivy
Gilbert, AZ
So, this past week I got the roof decking finished, fascia added, and finished all the exterior sheathing with the exception of the garage door headers.
Father, nerd, hobby welder and do-it-yourselfer
Gilbert, AZ
steveivy
Gilbert, AZ
Hey folks - quick roof update:
The roofers came out yesterday and installed a 2-ply mixed bituminous (rubberized with asphalt-coated cap layer) roof. Shingles are cheaper but are not code here for low-pitch roof, and my roof is only about 0.5/12.
Next I get the electrician out, once the tax refund comes through!
--Steve
j p smith
Glendale, Arizona
Looking good Steve! Welcome from west Phoenix.
I hope you are going to be alright with that low pitch roof, I would be concerned for the monsoon season. The weight of the rain could get pretty serious when it can't run off fast enough.
j p smith
Glendale, Arizona
Well, JP, I guess we'll find out come August!
LOL.
Curious how you decided on the low pitch flat roof.
I am a big fan of the sissor truss, gives height inside for a lift with out a large presence out side. lower side wall & lower overall height. I realise we all have different goals with respect to what we do in our shops.
Are you doing the wiring your self? if you have condiut runs, I may have some 12 or 14 gage wire for you
steveivy
Gilbert, AZ
Hey JP:
The roof design decision was kind of made for me due to zoning laws and building height based on distance from the property line.
I'm not planning to wire it myself, but with some unforeseen panel issues coming up I may end up splitting the work with the electrician, and run the internal wiring myself if he does the feed and sub-panel.
steveivy
Gilbert, AZ
Hey folks,
Quick update - I was procrastinating deciding whether to divide the garage or just hang a welding curtain up to protect the wife's van, and Finally decided I'd rather be safe. So this weekend I framed out a wall between the two bays. Rather than frame a door I left a 4' opening - gives me more room to move between the two sides, and I can frame in a door way later if I want.
I'm waiting on the electrician to give me a quote, but in the meantime I scribbled outlets and switches on 3x5 cards with a sharpie and stapled them to the studs.
This let me "mock up" the layout and it helped the wife figure out where she wanted light switches and stuff.
Finally here's a pic of the "shop side" so far:
Cheers!
--Steve
steveivy
Gilbert, AZ
Oh one more small feature: rather than bother with full HVAC, I've got a roll-around AC that is pretty powerful. This weekend I also installed an exterior vent with 6" to 5" reducer to run the AC vent out of:
(The 2-bys are there to give the stucco doe thing to run up against. I'll paint and seal them after.)
1949 caddyman
Arizona
I like your build, I'm in Mesa & also was limited to 10' height.
I went with 8' walls, 20' wide. I used shingles for roofing. All this works ok but I
Wish I had more head room like you have.
shade
Phoenix, AZ
Roll around wont cool enough in the summer. I tried
if you can do a through the wall that works great. especially since you have the walls exposed.
steveivy
Gilbert, AZ
Shade - well I guess we'll see. Technically I'm not sure with my design I'm allowed to "install" AC - due to limited available insulation space between the TJIs, but I will definitely look into it.
steveivy
Gilbert, AZ
Almost finished the roll around base for my miter saw. Just need to clean the doors and attach them.
steveivy
Gilbert, AZ
So I got the final quote from the electrician today: $4k for everything except any potential saw cutting while running the feeder line from the house to the sub panel.
That includes:
- the 70+ ft run from the main panel, through the attic, down the house and under a sidewalk, then 20' trench to the sub
- 2 dedicated welder/plasma circuits and outlets
- 17 120v outlets (on several 20A circuits)
- 3 exterior GFI
- 2 exterior wall lights
- 3 carriage lights
- 4 switches
- a partridge in a pear tree
Is 17 outlets enough? HAHAHAhaha ha
Jon In Tucson
Tucson, AZ
Steve,
Have you given thought to using a mini split a/c unit? It may work for you and are super easy to install. I hope to use one in my future build here in Tucson. BTW, great job, I am subscribed. God bless.
Jon In Tucson
Jon In Tucson
Tucson, AZ
Hi Jon,
I had never heard of such a unit; what sizes do they come in and how do they install?
Do a Google search on mini splits. Tons of variations in them. You can even buy them on Amazon. I installed one on a friends 500-600 square ft efficacy rental last year. Runs on a 120V 20A circuit. Needs a 2" perforation in the wall for power, coolant lines and evap drain. Very impressive. God bless.
Jon In Tucson.
Sent from my SCH-I535 using Tapatalk
steveivy
Gilbert, AZ
Hey folks,
Today I spent some time framing out the inside of the garage doors in preparation for the stucco contractors coming tomorrow:
Foam and chicken-wire lath is stacked in the shop, waiting for an early start!
Still waiting to get on the electrician's schedule.
steveivy
Gilbert, AZ
Is it wrong that I want to play hooky from work today so I can just sit and watch the electricians rough in?
steveivy
Gilbert, AZ
The electricians have been awesome so far, very responsive to my questions, suggested improvements to some of the lighting layout even.
They spent some time talking out issues with the garage door installer (my ceilings are a bit low due to zoning height restrictions). Good guys.
So far I can recommend Guthrie Electric in the PHX area.
steveivy
Gilbert, AZ
Also, after discussing it with the lead guy, I'm moving my panel from the outside to a recessed interior panel. Labor and parts costs even out, and I'm happy not to have to go outside and through a gate to check the panel.
AZ Garage
Mesa AZ
Looks great so far!
How was the process of submitting thru the city, where they a pain to work with?
steveivy
Gilbert, AZ
Gilbert is known to be pretty stickler on the code; I found the process a bit tiresome but the people I worked with were very professional. I had to get a variance from the city for the location of the building, but that was the worst of it.
The larger hassle for me has just been learning about the construction process and what needs to happen when. Especially now that I've got overlapping contractors whose parts need to be done in specific orders - I'm taking a bit more Tylenol than usual. :grin:
Dirtydan69
San Tan Valley, AZ
Nice work so far. I wish I had the room but I'm stuck in a subdivision down the road from you. Just moved here last year and was surprised to see al the panels on the exteriors of buildings here. Way different than the Midwest.
