The 211 is just a mig. The 210 mp multi process does DC lift arc TIG and stick machine. The duty cycle is about the same. The 210 is 220amps and the 211 is 230 amps I believe.
Interesting....
Anyone know what the real-world power draw is? Only have a 30A outlet at the moment.
Being inverted, it's going to be low. My dynasty 200 TIG would pull 19 amps on 220v maxed out.
The lincoln is only 20 amps more than my TIG. I can't see it pulling a big amount more.
14.7A on a 230V service, found the specs.
still only has a rated output of 200A, guess it wouldn't be much of a jump up from the 190A I have now...
I have been meaning to stop in at the LWS and give it a run, I have to call first and set it up since they don't have one set up on 240 in the test booth, but said that they will when I am ready to test it out.
OUTPUT RANGE:
230V: 20-220 Amps DC, Max. OCV : 56
Yes, it is a 220 amp machine.
Whats the duty cycle at 220A though, cant be much!
I ordered it from Lincoln's site since they gave instant 200 off. Tax and shipping it was around 1080 total. They're in Ohio, I'm in PA, so judging by their shipping estimate it should be here Friday or Saturday. They also have Free ship to store, but they're all closed by the time I'm out of work.Where's you get it?
LWS wasn't too keen on getting me a price or ordering one for me today....
I looked at these real hard when they first came out and never pulled the trigger. Besides being dual volt mig machine I would also like to play with aluminum, so I am thinking the spool gun would be a great add on.
Has anyone used this machine with the Aluminum or TIG packages?
How long will they run this offer?
Make sure you check the card you used to pay for it.... They added on an extra 54.** dollars to my total for some reason.... They'll be getting a phone call tomorrow.Pulled the trigger, will be at my lws tomorrow.
Could have saved $35 having it shipped UPS 2 day, but tryi ng to build the relationship with the LWS and will need some consumables soon, should pay off in the long term.
I'm guessing 20%. which will be the same as the miller 211.
I hate that there is no international standard for duty cycle testing. Miller even rates theirs different from hobart and they're the same company.
lincoln is different again. It really gets me mad.
would u guys recommend this .??????to learn how to weld???
Guys I found a tig kit available from USAweld it's include the compatible parts to add tig to the machine it is around $400 with the long cable or slightly less if you want the 12 foot
It's not Lincoln brand but it's made in USA except one adapter. The only thing to see is if the foot control normally it is a $300 Lincoln part and remains to be seen if their kit is as good as the Lincoln .
I thought maybe better to get the basic kit and add on the Tig kit for $400 since no tax on the $400 for most people.
From the flyer:How long will they run this offer?
I found out this machine cannot weld aluminum in TIG mode.
What's it's max amps at 100% duty cycle. My maxstar 140 str is 100 amps 100% on 240. And 80/100%/120
Sent from my SAMSUNG-SM-G870A using Tapatalk
You'd have to call lincoln as they do not state that info.
