Schurkey
I have what amounts to a Coleman/Sanborn air compressor, using the two-stage SC-23 pump.
The 75-psi safety "pop-off" valve on the intercooler (between the low-pressure exhaust valve and the high-pressure intake valve) releases when the tank is about 2/3 pressurized--maybe 125 psi. If I hold the valve closed with a tyrap, the compressor will squeeze it's rated 175--180 psi into the tank. Clearly, keeping the valve shut isn't safe or recommended.
I have another 75 psi pop-off valve on order...but...I'm coming to suspect that the pop-off valve is OK, there's a problem with the compressor pump.
There are five valves in the cylinder head. Two inlet valves for the low-pressure cylinder, one inlet valve for the high-pressure cylinder, and an exhaust valve for each cylinder.
I'm thinking that perhaps the inlet valve for the high-pressure cylinder leaks, which allows excess high-pressure backwards into the intercooler, which blows the pop-off safety-valve off it's seat.
I have an exploded view of the pump, along with part numbers.
HOW DOES THE HIGH-PRESSURE INTAKE VALVE COME OUT? I removed one of the low-pressure intake valves. There's a threaded plug that holds it in place. Removing the plug required some cleverness, as the wrenching method uses a tool with two pins which fit into two holes in the plug. Once the plug was out, the retainer-cage and then the valve lift out by hand. The valve was covered in gritty carbon--but appeared to be working. I cleaned it and re-installed. I don't know where the gritty carbon comes from. Always has an air filter. Must be burnt compressor oil. Oil level never drops that I noticed.
Over the high-pressure intake valve--the valve that I think is leaking--there's a bolt that holds a heavy washer (Valve cover) to the cylinder head. I can remove the bolt, but the washer won't come off. I don't know what the bolt threads into--apparently it threads into the screw-in plug that secures the cage over the valve. I suppose the valve is also covered in gritty carbon, and won't seal any more. Perhaps it will if cleaned.
Exploded view here:
http://www.mastertoolrepair.com/air-compressor-pump-parts-040-0211-sc23-pump-p-48.html
Pop-off valve #73. High-pressure intake valve #62, retainer cage #63, plug #67. Bolt and "valve cover" shown above the #67 plug.
Exploded view here:
