Need help with air compressor pump (2-stage)
Schurkey
I have what amounts to a Coleman/Sanborn air compressor, using the two-stage SC-23 pump.
The 75-psi safety "pop-off" valve on the intercooler (between the low-pressure exhaust valve and the high-pressure intake valve) releases when the tank is about 2/3 pressurized--maybe 125 psi. If I hold the valve closed with a tyrap, the compressor will squeeze it's rated 175--180 psi into the tank. Clearly, keeping the valve shut isn't safe or recommended.
I have another 75 psi pop-off valve on order...but...I'm coming to suspect that the pop-off valve is OK, there's a problem with the compressor pump.
There are five valves in the cylinder head. Two inlet valves for the low-pressure cylinder, one inlet valve for the high-pressure cylinder, and an exhaust valve for each cylinder.
I'm thinking that perhaps the inlet valve for the high-pressure cylinder leaks, which allows excess high-pressure backwards into the intercooler, which blows the pop-off safety-valve off it's seat.
I have an exploded view of the pump, along with part numbers.
HOW DOES THE HIGH-PRESSURE INTAKE VALVE COME OUT? I removed one of the low-pressure intake valves. There's a threaded plug that holds it in place. Removing the plug required some cleverness, as the wrenching method uses a tool with two pins which fit into two holes in the plug. Once the plug was out, the retainer-cage and then the valve lift out by hand. The valve was covered in gritty carbon--but appeared to be working. I cleaned it and re-installed. I don't know where the gritty carbon comes from. Always has an air filter. Must be burnt compressor oil. Oil level never drops that I noticed.
Over the high-pressure intake valve--the valve that I think is leaking--there's a bolt that holds a heavy washer (Valve cover) to the cylinder head. I can remove the bolt, but the washer won't come off. I don't know what the bolt threads into--apparently it threads into the screw-in plug that secures the cage over the valve. I suppose the valve is also covered in gritty carbon, and won't seal any more. Perhaps it will if cleaned.
Exploded view here:
http://www.mastertoolrepair.com/air-compressor-pump-parts-040-0211-sc23-pump-p-48.html
Pop-off valve #73. High-pressure intake valve #62, retainer cage #63, plug #67. Bolt and "valve cover" shown above the #67 plug.
S
Schurkey
Answering my own questions: Yes, I had a leak at the high-pressure cylinder intake valve. The large-diameter copper sealing washer failed. This over-pressurized the intercooler, and caused the safety pop-off valve to...pop off.
The valves are all of similar but not identical design. They're held in place with a big plug that presses on a perforated-steel cage. The valves seal against the head with a copper sealing ring. Three of the valves use a heavy washer as a "valve cover" which is sealed with a paper gasket around the outside, and a small copper sealing washer where the retaining bolt goes through.
Threaded plug and fabricated "Special Tool". Pin C-to-C is 27 mm or very close--slightly more than one inch.
The ******* packet of three paper gaskets, three small copper washers, and five large copper washers is $50. Note broken sealing washer.
Assembly of the high-pressure intake valve.
I removed and cleaned four of the five valves. I couldn't get the high-pressure exhaust valve out of the cylinder head. Operation of the compressor assured me that the valve I couldn't remove...isn't leaking.
I did have another complication: A wayward piece of sealing ring fell into the compressor, and ended up jamming the one-way check-valve leading into the tank. I had an unending leak at the unloader housing (hisssssssssss) as long as there was air in the tank. I had to remove the main (big) copper discharge pipe between the aftercooler and the check-valve at the inlet to the tank, the small-diameter copper pipe leading from the one-way valve to the unloader housing, and then the one-way valve itself. Once out in the open, it was easy to remove the wayward fleck of sealing ring, and all was well again.
redmondjp
Redmond, WA
Thanks for updating this thread with great pictures of the tool and parts! Glad you got it working. Classic sign of second-stage inlet valve problem when then interstage relief valve pops off.
That's the one downside of the higher-end compressors with individually-serviceable valves - they often need a special spanner wrench to disassemble.
S
Schurkey
I'm about one step away from tossing a street-Tee and a pressure gauge on the intercooler. where the pop-off valve is. Seems like a cheap diagnostic aid for the future. Gauge low = primary cylinder problems; gauge high (and pop-off valve releasing pressure) = secondary inlet valve/seal problems.
redmondjp
Redmond, WA
A great idea, much like installing a fuel pressure gauge on a modern diesel engine with the tank-mounted lift pump - it's the only way to tell if your lift pump has failed.
S
Schurkey
Photo of cylinder head, with valves labeled.
1 = First Stage
2 = Second Stage
I = Intake
E = Exhaust
For the record, I re-used one of the paper gaskets, all three small copper rings, and four of the large copper sealing rings. I've got enough parts left-over to fix it again.
