Show Off Your Custom Tool Storage!
Loscaldazar
Thought this could be a cool thread for people to show off their custom made tool storage ideas, and where others could find inspiration to make something that fits their needs.
I'll start off with a screwdriver holder I made from some scrap angle iron I had hanging around. Wiha screwdrivers all have the same sized round plastic nub that the screwdriver shank is pressed into, so with the exception of those that have a hex bolster instead of the round plastic part of the handle, I was able to use one drill bit for most of it. They sit pretty securely too. This is just for my phillips and torx collection (two most used types).
I've been tempted to redo it with some rectangular/square tubing so that they would be even more secure. Plus I need to find a better holder for my flat head screwdrivers rather than sitting in a drawer where they're hard to find and taking up space I could use for other things...
Based on making the screwdriver holder, I made a prybar holder, but I just went ahead and used tubing instead of angle this time (and it worked really well, which is why I'm tempted to do a screwdriver holder out of tubing). This consists of a 6x2, 4x2, and 2x2 rectangular and square steel tubing. All material was 11 gauge (only thickness I could get in all three sizes- didn't want to weld materials of different thickness to each other). If you have the money, aluminum would be way better (this steel one weighs over 20lbs without any tools it, kinda heavy!).
Then with some nice Milwaukee hole saws and Norseman drill bits, I drilled it out, deburred the holes, drilled some holes to mount it to the toolbox, and added two hooks I bent out of some flat steel pieces I had around. That way it is bolted into the toolbox and doesn't flop around, but the sheet metal of the box isn't supporting the weight, and instead the top corner of the box is.
This prybar holder worked out very well. Very happy with it!
Let's see what you've got!
hayhauler71
MN
truck box locker. top tube holds my under hood light
Ram Hemi
Sudbury, Ontario
Following. Probably going to make some sort of back piece for my kra that can slip under the stainless top and be snugged down when the top is tightened back down, somewhere to hang stuff on.
superautobacs
Vancouver, BC
Some examples of what I did for my toolcart:
I made this for my 1/4 drive socketry
I did this one up with some scrap wood I had laying around
The socket tray hangs onto the vertical divider, holding my most used 3/8 impact sockets
Bunit98
Canada
Pryabr holder that bolts to my vise stand
jsaleen
Hi, never posted on this site before but I've been a long time lurker.
Just finished these today, French cleat tool holder that run along the bottom of my pegboard behind the work bench.
gdocktor3
Connecticut
Not sure if this counts, but it wasn't intended for tools. Pulled this out of the scrap pile at work yesterday. Some sort of industrial medical bench. All I know is it's like 300lbs, the drawers are strong as hell, and I can't afford a comparable snap on or Mac box. Now I can have a bench top and drawers big enough for my long pry bars, 36" pipe wrenches, bolt cutters, and basically anything else. It's like 4 or 5 ft long and the drawer sliders are solid.
mitusa
SW Oklahoma
I think that should qualify for a big "YOU ****".
Good find......add some casters and you're good to go!! If nothing else, you could make some separations for the drawers and use if for regular tool storage.
:thumbup:
b-dog
Lakewood, CO
I made this tool holder for my Tormach CNC mill.
That's rad! I need to do something like that. I just a dumb plastic carosel for collets but my bigger stuff like drill chucks just sit on the bench.
Do you have model files that you could share?
gdocktor3
Connecticut
:thumbup:
Yea I actually have some large steel casters that I took off of some large industrial flat bed carts I took out of that same pile :p
Check out the drawer tracks. Pretty heavy duty.
kkroger
18 Ga CRS, Plasma Cut, Powder Coated, I do them in a Chrome look, Red, Blue, Black, Yellow, pretty much any powder coat color to match tool boxes etc...
Generally get about $20 out of them. The Air Tool Rack includes a bottle of air tool oil that no one ever has near their air tools...
Vise Grip Racks
Air Tool Rack
phule
New favorite thread! That truck box is a awesome idea! Gonna keep an eye on craigslist for those.
Sent from my SM-N910P using Tapatalk
Tejaas
TX Hill Country
That's a hell of a find.
You definitely ****.
LXCam
I got a couple simple ones that were handy.
I repurposed a Klein screwdriver wall mount display into this.
Bent up some sides and a back piece.
Mock up
And done, just not the final organization
I also made this for my T handled units. I always meant to machine some feet for it so it wouldn't be tippsy, but it's been a couple of years and it's never fallen over. But still it'd look much better with some.
BTW, these were bussbar rems I hand laying around from some gear I stripped long ago.
And did this for my 1/4" bits.
Jerm137
Mo
I kept getting mud dauber nests in my seldom used air tools if I left them out, so I made a rack to hold them. Frees up a drawer too.
bobcatdan
Kaukauna,WI
3/8" and 1/4" sockets kept on the end of the bench for easy to grab while doing something.
R. Johnson
CT
Prybar holder. I'd probably use box tubing if I had some, but this works. Going to put a strip of wood below it to keep the bars from banging into the box.
Organizer for my Greenlee punches
Made two of these for my bit sockets and such. Used the plastic HF rails.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Finky198
North East
My prybars, impact extensions, and 2 ratchets. It's made from some pallet racking
And my current project is a custom Dayton job box for carpentry tools... Pics coming
Wood work is pine, plywood, and cedar. All sanded and finished with Thompsons or Boiled linseed. Have neo magnets glued into pine 1"x2" than can be placed anywhere and can be used with screws or nails to hold objects like canvas bags, organizer, ect. Trying to source a pelican lid organizer that's the proper size for small items. the possibility of more magnets... And finally a ply wood deck and storage for saw horses. We'll see I'm building as I go....
Finky198
North East
Added some plywood sides to the box a little paint, a few more details and it will be ready for action... I can't wait to organize our carpentry tools In one area of the shop
superautobacs
Vancouver, BC
I had to do something to my file cabinet drawer that contained all of my clamps, so I came up with this solution.
All of the plywood is reclaimed and the 2x4 materials were off-cuts.
All the racks were made with hand tools only.
The tray was cut with a circular saw (don't have a table saw). The handle is also recycled.
