Let's See Your Custom Made/Modified Hand Tools
gdocktor3
Connecticut
Thought it might be neat to see all the different modifications we've made to our hand tools for that one tough job. Bent, cut, welded, etc. Here are a few of mine. I regret bending the billings wrench, but it was all I had that would work. It works good on hydraulic fittings.
crewchief888
NW indiana
bent this one up for 1 PITA bolt in a transmission....
:beer:
F150tech
Central CT
No pics but I have machined sockets down on a lathe to fit tight spaces and have several cut in half wrenches for specific jobs on diesels
Ghost11
I thought about starting a thrrad like this, but it was gonna be what to do with extra screwdrivers and wrenches. I have a few custom made wrenches, screwdrivers. Made some stubbys out of bigger wrenches. Ill get pics tomorrow.
Superbec
Netherlands
this is fresh out of the bucket, brake bleeder for some bmw motorcycles
Provincial
Near Salem, OR
I worked for years flying and maintaining old radial-engined airplanes. I made a couple of special sockets for removing ignition leads from spark plugs in hard-to-reach places. Many times an open end or crowfoot wrench just won't fit, but there is pretty good access straight out from the spark plug. These were patterned on original Pratt & Whitney tools. The P&W wrenches were a smaller size than I needed because spark plugs changed over the years and went up in hex size twice.
The wrench on the left is an original P&W. The center tool is a 3/8" drive 3/4" deep impact socket sliced with a cutoff wheel and carbide die grinder. The tool on the right is a 1/2" drive 7/8" deep socket with similar modifications, plus shortened and with a 3/8" square drive welded on.
The cutout in the socket is to fit over the ignition lead that comes in the top of the spark plug. The hex has to be cut away and a relief made to clear the lead when the socket is turned. Unless there is corrosion or physical damage to the threads, the lead nut will only need about a 1/2 turn before you can use your fingers to finish unscrewing the nut. You may have to reposition the tool a couple of times to get the nut loose.
JSGAuto
Northern NJ
I made these (I didn't do the anodizing) for removing the tappet covers of SOHC Honda Motorcycles. It is a low profile 17mm nut that regular wrenches are to loose on...and being aluminum, just strip the covers.
I sell them on ebay, little extra cash to support the habit!
Jim
G
gdocktor3
Connecticut
Jim
Good for you! That looks like a nice little tool. What's different about your 17mm and a Snap On 17mm? Is your's a 16.5mm to snug it up or something?
JSGAuto
Northern NJ
Thank you.
It is made with only a couple thou clearance, and no significant chamfer. All of the commercial wrenches I measured were .020-.040 oversize. Really I think the large chamfers on wrenches/sockets are the problem with such a small profile nut.
Being aluminum, its also non-maring.
Jim
G
gdocktor3
Connecticut
Thank you.
Jim
Just curious, how many people are looking for a wrench specifically for that Honda bike? In other words, how many have you sold?
Teenager with old tools
riverside california
Ground an old craftsman double open end because it was too thick. Have some bench wrenches just not pics of them. I too have turned down a socket on my lathe after cutting off a quarter inch
K-Dog
Millersville Maryland
I have a bunch of these I cut off of used doors. They make it easy to jump window motors when the door is off the car or the battery is disconnected.
Belt moulding tool
Flattened the head on a few chisels. Work great for metal work.
Wyoming09
Wyoming, MI
I was needing to attach a 4" vinyl hollow fence post to my garage wall using an eyed lag screw about 5" down inside the post. This fit great over the eye and allowed me to use a ratchet to drive in the screw. Made from an extra spark plug socket I had laying around.
TonyCH
Finland
******-socket, ie. socket for removing and installing black powder revolver *******. Could not find one that would fit my ******* so little file to a socket and voilà!
MushCreek
Upstate South Carolina
I've done a lot of them over the years- no pics, though. I had to make a socket to fit an old Ford Pitman arm nut. It's a really oddball size- couldn't find one anywhere. I took the next size down, and re-machined it in an EDM machine to make the odd size. I might still have it somewhere...
dwysywd
SE Michigan - Romeo area
believe it or not, i've stripped these more than once. i'm now looking for one bc i didn't even know they existed before this thread. i think that once people start learning they are out there they will buy them.
@JSGAuto contact the guys at Cycle X ([email protected]) and the guys at cafe racer magazine.
Sent from my facsimile machine
kansei
Greenville, Michigan
Just a few made years ago, but have been used over and over since...
Back in the '70s and into the mid-'80s or so, Mazda had essentially four different front strut piston shaft indexing profiles, obviously depending on supplier. Aftermarket items only added to this number, so every time I came across a new/different one, I would have a new 'holder' CNC machined into the end of a 3/8" drive extension to match the profile, except for one that had to be scaled up to 1/2" due to the diameter of the shaft, and profile. I think I have five holders now, and two sleeve sockets for the top nut securing the strut mount. This is one pairing from different angles:
Another Mazda tool- this one for the '76-'78 CD Cosmo strut gland nut, which seems to be its own animal. Started with a socket which had an OD sized to match the OD of the gland nut. Spliced in a section of pipe long enough to clear maximum extension of the piston shaft, in the event I had to work on a car that had the struts changed out to gas at some point (original design was oil). Cut in gland nut tang profile, and it has worked like a charm. At the drive end (3/4"), the socket was inverted and milled down flat. It provided a natural bevel of the socket for welding to, and being able to grab the top of the socket and ratchet head together helps with leverage when the strut is in a vise, as the CD gland nuts always seem to be welded in place.
This one is just a lengthened socket for the flywheel nut on OMC Wankel engines (Johnson and Evinrude sleds). The length is needed to clear the eccentric shaft once the primary clutch assembly is removed.
That's all I have loaded on this machine...
Superbec
Netherlands
vfr1200f clutch holding tool out of a rear sprocket and brake link from another bike
wxm
Spanner for removing the walker 93632 tank nut.
Infinia
SoCal
3/8 to 0.25 magnetic bit holder
seems a no brainer for a tool, but couldn't easily find this adapter.:headscrat
made by removing a hex socket bit and installing the ubiquitous mag holder bit:)
can use a ratchet wrench for torque or a t-handle for speed. I like it !:thumbup:
Superbec
Netherlands
I don't get it , what exactly did u make there?
kblee27
Singapore
I mentioned somewhere my jump starter SLA battery went dead. I didn't think it would survive long since it wasn't built as an automotive battery, so I didn't replace it.
I took out the cable and clamp and add a quick-connect terminal clamp to it.
So now I got a jumper cable connected to a real automotive battery.
I can carry the jumper cable around separately, since it's quick connect just 2 secs to hook it on and take out.
moron88
kalamazoo, MI
no pics but last year i took a couple wrenches to the bench grinder to take a bicycle apart. beats coughing up the dough for real bicycle tools for a one off job. made a wrench for my angle grinder because i lost the original one. also made a 2' pry bar for my chainsaw gas cap (it doesnt thread properly. it seals, just doesnt want to turn. way harder to loosen than tighten).
gungatim
west mich
I like the ingenuity. you know craftsman actually sells a really nice version of that, complete with t-handle, adjustable spinner, and the hex socket bit adapter...I use mine all the time, but yours is cooler!
bookmarking this thread too, I need ideas to make a tool to remove the stupid plastic canister oil filter housing on my kids 4cyl Malibu. can't fit a wrench, adjustable, socket, and can barely get channelocks on the stupid thing. tore it up good the other day doing an oil change...maybe the guy making that Honda wrench can make one for those eco-**** motors!
Infinia
SoCal
Thanks:beer:
Yes indeed one of the CM Mach series tool really worth having! Sears offers it both in 3/8 and 1/4 versions.
I like my version much better for more than a few reasons besides the sheer flexibility /compactness of the thing. strangely not many tool makers sell an adapter:dunno: I really like T-handle tools! I like to feel the torque feedback for precision control yet still have some of the speed, you cant get all that in a power tool.
Derek420
Southern Indiana
I had to take a grinder to a socket to remove a Oxygen Sensor it works perfect and saved me $. I still have it somewhere it lets the wires through i used a stanley socket might me a spark plug but cant remember as i only used it once and i usually just cut the wires off.
gungatim
west mich
Thanks:beer:
I like T-handle tools too. I didn't post any pics because they're really nothing special, but I have a bunch of screwdrivers, allen wrenches, and socket extensions that I welded Tee handles onto for special situations...
