New project
royce
fairbanks ak
I need to make some pull down stairs for the loft in my shop.
To do that I need to straighten the aluminum sections I'm making them from.
To do that, I need to get a table and welder set up.
To do that I need to make a boom for the wire driver.
So then, I got the slab of iron drug into the shop today and cut the legs cut off to tack some casters on.
Just getting to the project is a fair chore but here I go.
Royce
RivennHewn
PNW
I'm thinking you want a bad *** bench, and the pull down stairs are just an excuse.
I like the way you think!
drivesitfar
Royce: just curious how much that steel bench weighs? also how did you shorten the legs?
Also wondering if you finished the AWESOME lista drawers wood cabinet you built. did you fill up the drawers with nuts and bolts and ?? any more pictures to post on the old thread?
BOY do I hear you about having all your ducks or pieces of the puzzle figured out when you start almost any project.
good luck
tarbellb
Oregon
Ugh..... I want those casters! What brand are they, kinda look like Aerol?
Keep us posted, bench looks badass as well.
R
royce
fairbanks ak
good luck
Drive,
The bench is 24"x85"x5" but I don't know what it weighs.
I cut the legs with a portaband.
I got the drawers loaded with what I had in the shop, waiting for the snow to melt to get everything out of the shed.
Sorry, no more pics and thanks for all the nice feedback.
Royce
R
royce
fairbanks ak
The two silver ones are marked caster concepts, the two green ones just have a patent number.
Will do and thanks.
Royce
R
royce
fairbanks ak
Got the wheels glued on the table today and started gathering parts for the boom.
Also drug in the stair sections that will need straightened and spliced together to make the height needed.
They came off a cat train camp and are less than perfect, but are aluminum so I can keep the weight down.
drivesitfar
Royce: you've got SKILLS SIR and nicely done putting on the plates for the casters because that couldn't have been as easy as you make it sound.
looking forward to seeing what your stairway will look like because I don't have a clear picture in my head.
good luck
Strouty
Southern Maine
I like the table!
I am thinking that I too suffer from the "start a project to finish a project" train of thought. I have several things that I would like to start, but there are too many projects that need to be completed as a step in the process of completing the original project (does that even make sense?) so I never seem to get started.
R
royce
fairbanks ak
good luck
Drives,
The stairs are in the early stages of design, I envision a Rube Goldberg deluxe special edition.
More to come, as it is made up on the fly.
Like you, I don't have a clear picture either.
Thanks
Royce
PelicanPines
I like the table!
I'm exactly the same. Project A needs the use of a chisel... I find one that's dull... suddenly I'm sharpening 40 chisels.
Need to rip some thin strips on a table saw... suddenly I'm buying a new table saw that entails setting the whole thing up along with building jigs I may need in months to come.
I would love to get into welding and would love that table. The casters would be a requirement for me. Beautiful job.
R
royce
fairbanks ak
I like the table!
Strouty,
Not that it should, but yes it makes sense on my planet.
For me it gets worse or better depending on a given perspective.
With the attention span of 3 year old and having a few projects to do, just to build some lousy stairs, I find myself thinking about 12 other things I'd like to build.
But, you know, that's alright by me.
It's all easy,when you don't know any better!
Royce
R
royce
fairbanks ak
Pelican,
I went to the store the other day for a loaf of bread and came home with a gallon of milk.
Do you feel that is the same syndrome or do I have more than just the one issue?
Thanks
Royce
PelicanPines
Pelican,
Thanks
Royce
My wife is a math wizard ... she calls what happens in "our" situations... is called "Vectoring". It's kind of like a bullet ricochet... everything takes on a direction of it's own. :bounce:
drivesitfar
Royce: you'll be fine. just keep your eye on the GOAL and you'll figure out a way and get there eventually. pretty funny stuff about the what I call Senior Moments
Pines: your wife is very wise. also are you experimenting on scary cat Avatars?
R
royce
fairbanks ak
This aught to get me a blue ribbon in vectoring.
Instead of working on what I should, I stripped down 3 vises to give them a bath tomorrow.
drivesitfar
Royce: personally you can make as many of those kind of interruptions during your original project you have my permission not that you need it. is the big swivel jaw vise in front an AMERICAN SCALE or do tell? can you take more pictures of it and give us more information on the main vise thread? we need more vises like that over there if you have time and here's the link.
http://www.garagejournal.com/forum/showthread.php?t=44782
WELL DONE and nice little vise family you have there. not sure what that is in the background, but sounds like it might be a BIG GUN?
R
royce
fairbanks ak
Thanks drives,
I'll post a bit on the vises on the other thread.
Royce
R
royce
fairbanks ak
Made a wee bit of headway on the boom for the welder this weekend.
Spindles welded to column.
Hubs Temporarily bolted up.
Wheels tacked to traveler.
Deck frame made for power source.
Boom arm and a couple truss cords tacked up.
sublime68charger
SW Wisconsin
Royce just found this thread this morning but I can relate to the due 3 different things to get to work on the 1 thing you wanted to work one to begin with.
keep up the great work!
R
royce
fairbanks ak
Thanks sub,
I started on the boom last week and the more I looked at it the uglier it got.
So, I got off my wallet and bought some tubing and started fresh.
Here is the progress so far.
R
royce
fairbanks ak
Adjusted the wheels on the traveler and bolted some uhmw slides to it also.
LXCam
Hey Royce loooooook.................a bunny!!
That should keep ya occupied for a couple months
:D
R
royce
fairbanks ak
:D
Now you done it LX,
Made a little more headway today.
drivesitfar
Royce: it wasn't clear how you were going to use those welded pieces on the floor you posted a few days ago, but nicely done and looks like your welder has a home and works ok there. While i'm trying to figure out how you are going to put tie the ladder in with that framing you NEED to tell us the story behind your DOG and that BIRD. OMG that cabinet looks AWESOME and again nice work putting that all together last month.
good luck with the project and i'll just sit back and watch and enjoy the work you do.
R
royce
fairbanks ak
Thanks Drives,
The dalmation and vulture were sculpted with duct tape by my youngest daughter for props for a Red Green duct tape boat regatta.
Royce
JAKE-THE-TOOL-MAN
Bremerton, WA
This thread keeps getting better! Royce you have awesome equipment from what I can see so far, amazing shop. keep up the good work, I'm looking forward to seeing more
