Armorclad Armorpoxy Install
krouchchocolate
Hey Guys,
Finally had the chance to install my epoxy that I purchased from armorclad. I did not know whether which company to go with (Legacy or Armorclad), but the 40% discount in savings that armorclad was offering was something I could not pass up.
I decided to grind my floor, then I acid etch it. Next time if I ever do this again, I will rent a edco grinder instead of using a diamabrush. That took forever!
I went with the 3 coat system. Primer, armorclad epoxy in a medium gray, and the military top coat. I loved the glossy look and how the floor felt when I laid down the epoxy, but I was kind of disappointed on how it looked after I had applied the military top coat with the anti skid. Used about 2/3 of the can on the anti skid and mixed it well before applying it to the floor each time. The floor did not look as shiny anymore and it feels kinda greasy when I walk on the floor. Wish I had known about this or I would had just coated it without the anti skid product. Not sure if this affected it or not.
Here are some of the pictures of my install on a 3 car garage!
1st day grinding the floors. Took a long time to grind it down with the diamabrush.
1st layer with the primer. For future people who are going to install the armorclad epoxy, do not be scared of how uneven it looked. I grinded my floor so some spots soaked up more primer than other spots!
2nd layer with the epoxy. Best to have spike shoes and with a 2nd helper. My wife was the one who was painting the edges and throwing the flakes, while I was mixing up the batches and painting the epoxy down. I had loved how it looked after the 1st day it dried up. Very glossy and nice smooth feel to it. Wish I could have just kept it at this stage, but I knew it was best to have a final top coat to protect it.
3rd Layer with the military top coat. As you can see in the picture, it gave it a more dull look, but more protection. Pretty cool that you can see the little anti skid sand stuff in the layer. Nonetheless, floor still looked great!
Have to give props to the armorclad team, chris helped me out a bunch. He was the one who recommended me the medium gray color and now I am glad I went with his opinion! They answered all of my questions that I had over the phone, even if I thought it was stupid!
My recommendation is to not use blue painters tape. Now I can't figure out to remove it from some spots! Wish I had some left over primer and top coat. I would have painted the 1" step in front of my garage.
Nipper
Amsbry Hills, Pennsylvania
I think it looks great mate! Remember, function over form! If that anti skid and top coat perform well then the loss of shine will be no biggie! Nice work!
Sent from my SAMSUNG-SM-G900A using Tapatalk
jwcarguy
Looks great!
I am still wondering how this flooring system would hold up to getting scratched/ gouged and also welding and grinding over it in a shop setting?
Seems that I missed out on the 40% off from Armorclad, it ended yesterday, I didn't have the time with time changes and depositing pay check! LOL
Great job on the floor!
K
krouchchocolate
Looks great!
Not sure any epoxy can withstand welding and grinding. I Was told to buy a welding blanket to lay on the ground.
Remythepug
Charlotte, NC
Thanks for sharing. Interesting about your experience w/ the top coat.
I just received my shipment today. (designer gray w/ upgraded top coat)
K
krouchchocolate
I also think it looks fantastic!
How did you prep those vertical edges?
The edges near the walls I used my 4 1/2 grinder with a Diamabrush attachment. On the steps I could not really do much about them other than acid etching it as best as I could. They won't get much foot traffic so hopefully I won't have to worry about it coming off.
K
krouchchocolate
I did notice that it was not as glossy when I had applied the military coat. I think a few other members also had the same experience. Regardless I am still happy with the outcome. Would definitely use their product again. I will be using a engine hoist to maneuver my ski/ski motors around. We will see how durable the epoxy is when I put it to the test!
Remythepug
Charlotte, NC
I'd be careful w/ the hoist. My last epoxy floor would easily scratch from the floor jack and motorcycle stands. I started using cardboard to protect the floor :beer:
Armorpoxy
Hi, use of a non skid additive will always deg loss a floor to some extent. Our standard non skids are very smalL particle size so the effect is minimized.
K
krouchchocolate
What kind of cleaning product can I use to clean the epoxy? Seems like dust has accumulated on the surface so I would like to mop it. Just don't know what I can use.
risc
I think it looks awesome.
Is the step more obvious in person? Might want to paint/tape the edge to prevent tripping.
tinmanwpk
Jacksonville
I am not the OP, but I installed mine about August 2016. It is holding up well other than some electricians who chipped the finish. I won't withstand heavy steel pieces dropped! Other than that it does what it is supposed to do. I did not place enough sharkgrip on the topcoat to avoid slipping when damp or wet, so be certain to use plenty of that when doing your installation.
K
krouchchocolate
Sorry for the late update. My floors are still holding great. I have not seen any yellowing either from the sun. My garage is typically up during the day when I am working on my skis. I also did drop one of those yeti type tumblers (30 oz) on the floor filled with water and the floor did not chip! It was a pretty big fall, b/c the stainless steel tumbler has a big dent on it now. lol
chrisingrassia
Placer County
Good stuff OP. Nice job.
I have probably spent around 20 hours over the last month hand grinding with my angle grinder and a diamond head my two-car garage. I've rinsed and scrubbed with a stiff bristle brush 3x, and after it's all dry, I still have just a slight amount of white dust when I run my hand/fingers across it. I think I wasted 20 hours....
LegacyIndustrial
deerfield, IL
Once the floor has been ground it will always have a small amount of dust, broom/blow 3 or 4 times and let her rip. I have been doing this 25 years and have never had an issue with a tiny amount of residual dust.
I think Armorpoxy would agree.
chrisingrassia
Placer County
That's a relief. I was pulling my hair out trying to figure out how to rectify. After I got all the epoxy ground up, I went over the whole garage again and ground up 19lb 8.2oz of additional concrete and leftover epoxy residue and any dark gray spots. (I weighed the bucket, it was nearly half full). Then I rinse and scrubbed, rinse and scrubbed. Let it dry overnight, rub my palms/fingers over it and sure enough this very thin light white dust is still there.
I just don't understand what was going wrong. The acid etching did a white fizzling right when I poured it on, and went away within 2-3 seconds max, sound like I was pouring Sprite on the ground. No yellow or "foaming" whatsoever. Armorpoxy says to let it sit for 45min, but everything I've been reading says don't let it dry on there, so I only let it sit for about 5-8min before rinsing/scrubbing it all out.
One thing is for sure, I have zero "buildup" of anything on top the concrete. I saw some acid etch videos with calcium you could scrape off with your nails. I have none of that.
Armorpoxy
Dust is 100% normal, it's virtually impossible to get it all up. You should be just fine.
chrisingrassia
Placer County
Finished the epoxy install yesterday afternoon. Just waiting to cure so I can roll on topcoat.
I stepped on it this morning in my socks (about 18 hours drying time) and it left slight imprints from my cotton socks. No epoxy came up, but hopefully the topcoat makes it less noticeable.
chrisingrassia
Placer County
Anyone have any ideas what I can use as a sub if I have a small section that didn't get cleared?
I didn't realize how tough that task would be trying to find out what I missed with the roller.
CJseven
Southeast Missouri
I have a spot maybe 3 sq foot I missed next to the steps for my loft, I too was surprised as to just how hard it was to see the wet clear from the dry floor.
I’m thinking about just buying another kit of clear and doing the whole floor again, just as a added protection before starting a lot of use in the shop.
chrisingrassia
Placer County
Is it possible to do that but also throw down more flecks with it?!?
Armorpoxy
All of our kits can be ordered with additional flecks from anywhere from light to full broadcast patterns.
