Cleaning up Vintage tools
Johnnyo
I am sure this has been discussed many times so I apologize in advance. What type of cleaners are folks using on vintage tools (ratchets, sockets etc.)? General cleaning, light rust removal...
jakemac
New England
Degreasing/cleaning - Simple Green
Derusting -
- plated (chrome, nickel) - CLR
- bare metal - EvapoRust
If a wire wheel is needed - only a fine wire wheel.
If buffing - Red or White rouge
J
Johnnyo
Thanks Jake! I have used vinegar on rust before but I’m not sure if that might be a little harsh on 75 year old chrome.
jakemac
New England
CLR is made to be used on chrome plumbing fittings, so it works a little slower and gentler than EvapoRust or Vinagar. But if left too long it can still eat the chrome.
On older plated tools, if you see a white foam developing pull the tool out and rinse in clean water to neutralize the CLR. The foam indicates that the plating material is starting to be affected.
ZRX61
Solar Blight Valley, SoCal
I got pretty spiffy results on some old rusty Craftsman sockets with my deburring wheel.
https://scontent-lax3-1.**.fbcdn.net/v/t1.0-9/11952030_10206335668063345_1992946169781342128_n.jpg?oh=eaebed267059f64770fb9f6d2ce6fe58&oe=582C0902
https://scontent-lax3-1.**.fbcdn.net/v/t1.0-9/11150833_10206335669223374_3872561104192946660_n.jpg?oh=98ac3d984225f09cab50015417a9ade7&oe=57EF1037
ZRX61
This was rusted solid, I beadblasted it, freed it up & then wirewheeled it:
How I found it:
https://scontent-lax3-1.**.fbcdn.net/v/t1.0-9/563986_3279115749520_1854165463_n.jpg?oh=cfae64acfeafa5174771d676f7668928&oe=57F9DE01
Beadblasted & freed up:
https://scontent-lax3-1.**.fbcdn.net/v/t1.0-9/563986_3279115829522_817308586_n.jpg?oh=f17efdb2571e43d706848f80c6f01876&oe=57E9D9E2
wirewheeled:
https://scontent-lax3-1.**.fbcdn.net/v/t1.0-9/563986_3279115909524_1237809242_n.jpg?oh=86e49afedd98513f9ebe047a82f43376&oe=57F39B2A
Ramper
Southern MN
I have cleaned many vintage tools, but my issue has been what to put on them AFTER I have cleaned then. I have gone to heating them up in an oven and the dunking them in oil. Is there a better way?
Davefr
OR
There's more then one way to skin a cat but I like Molasses (feed grade). It's a chelating style rust remover that's safe on the base metal. You cut it 10:1 with water. (it's cheap when you buy it at a feed store in a 2.5 gallon pail).
Throw the tools in a tote with the solution and then come back in a week and check the progress. It works slow and gentle.
After the rust is gone you can use a fine scotch brite pad, fine wire wheel, brass brush etc.
General rust cleanup on lightly rusted and unplated tools - fine wire wheel or E-tank
Plated tools with surface rust - oil and 0000 steel wool or sometimes water and SOS pad (Not Brillo its too coarse)
De-greasing - SG generally, solvents for really tough stuff in gradually increasing strengths, but generally starting with lighter fluid/Naphtha/Coleman fuel (same stuff), and moving up from there. For painted tool boxes I'll start with WD-40
LesserSon
PA USA
I remove bubbly or crusty rust (hematite) by hand scraping with stiff putty knives, drywall blades, screwdrivers, dental picks. I try to pick a tool slightly softer than the object, so a slip doesn't leave a gouge. Stainless is usually a safe bet. Last step is a fine wire brush. Been using a battery brush for inside sockets. Maybe it's my imagination, but I stopped using wire wheels because I had the impression they were magnetizing the tools. And the broken off wires get into EVERYTHING.
On plain steel, my usual goal is not to reveal bright metal but to leave a thin layer of magnetite - this is a natural blued finish. To help prevent further oxidation, I scrub in boot sealer with a toothbrush, and wipe it down with paper towel.
This is labor intensive, but makes NO chemical change to the surface of the steel, and at the speed of hand work, I can really control the process. I've done a couple dozen hand saws this way.
If I do want a bright metal finish, I still give it a scrape to see the degree of pitting. Deep pits will look worse on bright than dark steel. Then I use sandpaper on a block, moving to finer and finer grit.
Bierisch
San Antonio, Tx
UH Exsqueeze me, how did those sockets go from being pitted with rust to being that smooth and shiny with flawlessly smooth surfaces?
ZRX61
One of these mounted to a bench grinder:
http://www.ebay.com/itm/like/381694858709?lpid=82&chn=ps&ul_noapp=true
& hardly any pressure applied. I got the sockets at a yard sale for a few bucks so I wasn't too worried about making a complete *** of it. Pleasantly surprised at the results :)
The inside of the sockets still look like ****, but that will get taken care of with glassbeading at some point.
dkroth
Rochester, New York
EvapoRust works by chelation. It does not affect chrome at all, though it will turn high carbon steel black.
cgrutt
Those sockets look great ZRX, nice job! Is that deburring wheel stone or cloth? Hard to tell from pic in link that you put up. I'd like to try that out :)
ZRX61
It's like scotchbrite, but a lot denser. Burns like a ***** when you accidentally slip & stick a knuckle into it.
& they last forever so long as you don't try cleaning anything sharp at the wrong angle.
Shiftless
East Bay SFO
I put an extension on the crusty socket before I take it to the wheel. Keeps my knuckles well clear of danger. Just make sure it fits tightly. Safety first.
ZRX61
I didn't do the knuckle/wheel stunt with the sockets, but I've done it a time or 5 in the past.
Safety third! :)
Also: if you're rolling the socket or whatever on the edge of the wheel, try to keep that action to one side of the wheel so the other stays 90deg & only one gets rounded off.
r_olson_06
SD
Evaporust is amazing for rust. Just have to be careful to wipe it off it will get sticky.
Sent from my XT1030 using Tapatalk
Bierisch
San Antonio, Tx
And it was just the wheel? No polishing with anything? It just came out shiny that way?
I had a small wheel like that for a dremel that I took to a surface rust covered revolved and it just looks matte now. not shiny.
Does vinegar ear chrome away?
Sent from my SM-G920T using Tapatalk
Short answer: Yes. If deep pitted, Evaporust or a molasses solution there...
If surface rust/stains, SOS pad and water, or 0000 steel wool and oil.
I just did the chrome on a scale with 0000 and oil...
Ole Slewfoot
Freedom, CA
I saw 3m surface conditioning pad for belt sander like that the other day too.
How about cad plated tools? I seem to lose a lot of plating with either vinegar or evaporust if I leave them in long enough to do much.
ZRX61
Can't speak about cad plating on tools, but on hardware we've used acid to strip the cad off them & then had them replated. Local shop has a $45 minimum, but we've sent so much stuff there over the years that the foreman usually throws the stuff in with someone elses order & does it for beer money
Al Borland
For mild rust and pitting, try Barkeeper's Friend. Won't hurt existing/remaining Chrome.
It helps to polish the tool as well as remove rust.
