Best and most complete bolt extractor set
Loren871
I'm in the market for a complete bolt/nut extractor set. I have a small 5 piece set of Irwin bolt grips that have worked amazingly when I have a stripped bolt in one of those sizes.Now I'm tryin to find a complete set from about 8-19 that doesn't skip any sizes. Would like a good SAE set aswell. Have searched and just can't find a complete set. I've found that Pittsburgh and Irwin seem to have the biggest sets but they both skip sizes mainly 15 and 18 which I see a lot of in my line of work. So my question is,is there any better brands or more complete sets out there? Thanks
gdocktor3
Connecticut
Irwin/Hansen most likely makes them for all the big name brands. Craftsman also makes pretty decent sets that I believe are still USA made. I wouldn't touch Pittsburgh because I've had bad luck with a lot of their stuff when I really needed it to perform. Not wasting my time anymore. I have the small Irwin set that works awesome. You can also look for twist sockets. SK makes some I think.
ttpete
Dearborn, MI
I have the Snap-On master set. It includes everything up to pipe sizes and has the proper drills and drill bushings. Made by Ridgid, it would probably be cheaper from them.
LXCam
I have a Matco SEXS25 kit that pretty darn well equipped. I know it's a rebranded set, and I think it's an Irwin product but not dead certain. I will say it's a top quality set and has saved my *** way more than a few times.
L
Loren871
Def gonna check out the all the truck brands you guys mentioned next week when they stop by.
I really like the craftsman set,they look like their pass through so will work well on nuts that are stripped where a shallow extractor won't work.
I've seen a lot of good reviews on the Pittsburgh ones but hey I hear ya. Have had my share of good and really bad from HF to so I dunno...
Anyone ever tried the grip tites?
Mohawk Dave
SoCal
I love extractors and use them a lot on stuff I refurb.
But there is a bunch of different types.
Bolt = Screw (Irwin, Cleveland, etc and they have different pitches) vs wedge (rennsteig) vs spline (Ridgid)
Nut = spiral screw (Blue-Point) vs spline
Buckgnarly
VT
Turbosocket in SK flavor gets yout a warranty at a decent price. I use the **** out of mine and have warranties two with no problems from SK.
xjfish
I also started out with the small Irwin set... I now use the deep metric Blue Point set (Turbosocket?). Good quality, they will eventually dull so warranty is great for heavy use. I'm sure I paid way too much...
T45
Try looking at cman, they have a decent set from like 8-19 ist 32 or something dollars.
spin_prod_207242301
gdocktor3
Connecticut
Note these are "low profile" and not as deep as the Irwin's. These also cannot be used with a 3/8" ratchet like the Irwin's. Not sure if that's ever a bad thing, but I'm just sayin...
I've always used open end wrenches with my Irwin's.
LB-1911
Northwestern Il.
10 pc. Damaged Bolt/Nut Remover Set Low Profile Bolt-Out
# 00952166000P Model # 52166
Can be used with a combination wrench, adjustable wrench, pliers, vise grips, or socket
Ratchet drive size is 3/8"
3/8” – 9mm (Ext Hex 5/8”)
10 mm (Ext Hex 5/8”)
7/16”–11mm (Ext Hex 11/16”)
12 mm (Ext Hex 3/4”)
13 mm (Ext Hex 3/4”)
14 mm (Ext Hex 13/16”)
15 mm (Ext Hex 7/8”
5/8” – 16mm (Ext Hex 15/16”)
17 mm (Ext Hex 1”)
19 mm (Ext Hex 1-1/16”)
The OEM of several Craftsman offerings is
http://www.ajmanufacturing.com/
From home pg select - Products - then - Twist Socket - Part # 0200C
LB-1911
Northwestern Il.
AJ Manufacturing Co., Inc.
From their Home page select Products from Chose Our Products page select Twist Socket
:beer:
L
Loren871
Those turbo sockets are nice!! No 18 but they come in deep and shallow.Might just have to find a 18 by itself somewhere.
Lots of good stuff on here guys from brands and sites I had no clue about.Started with few choices now I have to many!!Knew I came to the right place to ask. Thanks guys
gdocktor3
Connecticut
Ratchet drive size is 3/8"[/I]
That description is wrong. They cannot be used with just the 3/8" drive. They are "pass thru" design to fit long fasteners. The description from AJ Man. does not say they fit 3/8" drive either. Some yahoo copy and pasted the description from the regular stud removers.
Also, here's an interesting line from AJ Manufacturing - We currently provide our products to a number of customers including Snap-on Tools, Matco Tools, MAC Tools, Sears, and Wal-Mart as well as a number of WD’s throughout the United States.
Now the question is what do they sell in Walmart that I can buy???
252chvv
gdocktor3
Connecticut
I wouldn't even consider HF for something like this. I'd get American made Irwin or Craftsman, but that's just me. I've used my Irwins many times and they work, but more importantly they work the next time, and the time after that, etc, etc. Will the "cheaper" HF extractors hold their shape after first hard use?? Don't care to find out.
Danglerb
SoCal
Turbosocket looks like the best, branded on a Truck for wealthy, SK for the common folk, but I would still consider HF at $20 minus coupon for a set instead of a socket.
The trick with all the types and brands is to stop if they aren't working and try something else.
Danglerb
SoCal
Drill and twist from the middle is fundamentally inferior to twisting from the outside of the screw head. Torque is distance from the center x force at the point its applied.
Different tools for different situations. If an external remover bites and not slips, its the best shot at removing short of destroying the bolt via progressive drilling or one of those zapper things.
powertrip
Columbus Ohio
The thing that steered me away from the craftsman is that if you break one you have to return the whole set as sears does not carry singles. Irwin' s can be had in singles from their web site. Correct me if I'm wrong.
Danglerb
SoCal
Worse, unless I have it wrong, the Craftsman set isn't lifetime, its one year.
SK easy warranty for me, same for Pittsburgh
I am still hunting for completing one of my Craftsman sets, but more and more I may just buy Irwin/Hanson and be done with it..
SRSLY?
You expect a warranty on an item like that? :lol:
You're kidding, right?
This one set me back about $30 bucks as I recall. Worth every cent. Fought with that goddam blade bolt for an entire day before I drove over and bought the kit.
Seems I just posted these in another thread here somewhere yesterday, but here you go:
