Aussie 12x12m (40x40) VW Shed
60beetle60
Adelaide, AUS
It's finally time to stop lurking and show what I've got on the go. I'm a big aircooled VW fan and I've run out of space for toys, between a bug, a karmann ghia and my brothers boat there's no room left. I'm the process of replacing the old shed and carport combo with a new 12x12m shed so will soon have plenty of room.
Overview of whats going in:
- 12x12m
- 3m wall height 15deg roof pitch
- 2x double roller doors to the back lane
- 1x roller dooe and 1x PA door into back yard
Completed so far:
- Replaced old sewer line running underneath new shed
- Demolished old carport and shed
- New shed delivered
Still to go:
- Build Shed!
- Run power to shed, getting 3phase to the house and then trenching it to the shed
- Pour slab and figure out what floor coating to go with
Couple of pics to show what I started with
View media item 78036Shows the old lean to and the poor old plum tree which had to be let go to make room
View media item 78037the old double carport
60beetle60
Adelaide, AUS
Replacing the sewer line under the shed:
My place still had the old ceramic sewer lines running down the back, I wanted to replace this before they deteriorate and I need to cut out a freshly poured slab to replace the pipes.
View media item 78038
View media item 78039
The sewer runs to about 2m deep at the back, so its a lot to dig up
60beetle60
Adelaide, AUS
Demolition:
The lean to and the plum tree were the first to go
View media item 78040
Dad and I did most of the demo work ourselves, didn't take too long. Two days of work to remove all the sheets and framework shown in the above picture.
View media item 78041
View media item 78042
One of my favorite pictures of the demo, taken from the old carport roof showing my ghia hiding in the yard
View media item 78043
Another day for a bobcat to rip up the old slab, remove rubbish and level the area
View media item 78044
How the site looked after it was levelled
View media item 78045
hewey
Blue Mountains, Australia
Welcome mate, sounds and looks like a great project. Would love to see some pics of your veedubs (I had a bug as my daily for 8 years a few years back, so have a soft spot for them). And make sure you let us know what city you're from too.
60beetle60
Adelaide, AUS
Couple of pictures of the cars as requested
My 1960 Karmann Ghia, pictures from when it was one of the cars for my cousins wedding.
View media item 78048
View media item 78049
I don't have any recent pics of the bug, it's also 1960 and it's my daily. I don't have a recent pic of it, but it hasn't changed much since I've had it, and I've owned it longer than I've had a drivers licence.
View media item 78050
60beetle60
Adelaide, AUS
Update on the work completed today. Builder measured out and marked up locations for all the footings for the shed. All the footings were dug and installed and concrete poured for the footings.
Digging the holes for the footings
View media item 78051
Showing the pins which are cast into the concrete footings to support the columns. All the pins were set to height for the desired floor height then held in place for the concrete to be poured.
View media item 78052
Footings being poured
View media item 78053
View media item 78054
Where work has finished up for the day.
View media item 78055
The last pictures gives a good idea of how it all goes together. Columns bolt to the pins cast into the footings.
scarab
Adelaide, South Australia
Hey man, that's gonna be an awesome shed!!!
I'm a fellow VW nut, and also in Adelaide....small world ��
I think I recognise the White Karmann vert in the wedding photo....wouldn't be Andy T's by any chance?
cros13
Sydney, Australia
Hey mate did you have any drama with council for your shed? or are you asking for forgiveness rather than permission?
Oh and that sure as hell aint no bobcat you were driving, it was a Skid Steer Loader! ((Im a mechanic at Toyota Forklifts, in Sydney, have to work on that rubbish haha!)
Rudi.
60beetle60
Adelaide, AUS
I've received full development approval from council, only concession from initial submission was to have the shed 1m back from the rear boundary. Honestly surprised they let me have it as max recommended area for outbuildings in the council area is 60m2.
60beetle60
Adelaide, AUS
Todays progress
Wall frames assembled and stood up
View media item 78056
Rafters installed
View media item 78057
Purlins and bracing installed
View media item 78058
Side sheets installed
View media item 78059
Beams and columns for roller doors installed. Can also see them installing the wire mesh which will hold the roof insulation in place
View media item 78060
Should have the remaining walls and the roof installed tomorrow. The roller doors are being delivered on Monday, so will be able to finish the build off on Monday
60beetle60
Adelaide, AUS
There's been a good amount of progress with the shed build however not as much as planned due to bad weather, was too windy for doing the roof sheets over the weekend. Monday the weather was fine and the builder powered through.
The roof is insulated, picture below shows the insulation being rolled out over the wire mesh. The insulation is a reflective foil with fiberglass matting.
View media item 78061
Roof was installed section at a time, where roof sheets would be laid over the insulation progressively.
View media item 78062
Completed roof with purlins for the walls started and header beam for rear roller door installed.
View media item 78063
Wall sheets going up, note window and personal access door are cut into the sheets after they have been installed.
View media item 78064
The roller doors arrive!
View media item 78065
Picture of the roof sheets all installed and the front walls sheets started, flashing and roof capping still to be installed.
View media item 78066
Personal access door installed. Unfortunately I didn't check the size soon enough, I had ordered an 1100mm wide door and they supplied an 800mm door, so they will replace it later on as it is an approx 2 week wait for the door to be fabricated.
View media item 78067
Roller door installation start, they've only been hung at this stage, still need tracks to be installed
View media item 78068
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
Wow, looking good.:thumbup:
Its been windy here as well. Good to see you have added some blanket with the insulation foil, that's something I regret not doing here.
Thanks for the update.:thumbup:
Regards
60beetle60
Adelaide, AUS
Got more work completed on the shed today.
Start with some tidy up jobs including slight adjustments to the lengths of the front sheets to better align.
View media item 78069
Installing the window above the area which will have the main work benches.
View media item 78070
Finishing the roller door installation, setting the tension on the doors, installing tracks and installing the control boxes and programming the remote controls. The two large doors to the back lane are powered and have the remote controls. The smaller door into the back yard is manual open only at this stage as it wont be often used; although if I do find a cheap enough motor it may be powered sometime in the future
View media item 78071
A good photo showing how the shed fits into the landscape of the back lane
View media item 78072
Barge board flashings installed at each end although only temporary at this stage as I'm waiting for the corner flashing to arrive before the barge boards can be finalised. The overhang extending past the walls will be cut back once remaining flashing arrives. There is also additional flashing required to run vertically along where the roller doors meet the walls.
View media item 78073
Picture showing how the view from my backyard looks with the shed installed.
View media item 78074
First night for cars to actually be stored in the shed
View media item 78075
Progress will take stop for a while as the replacement PA door and flashings are being made up.
60beetle60
Adelaide, AUS
It definitely gets too hot in summer to go without any insulation in the shed, I'm hoping the roof insulation is enough to take the edge off. If I need more cooling later on I might consider picking up an evap cooler for the shed
Awesome! Love the veedubs and that's a real nice size shed, especially for a suburban block.
Thanks! and yup, doesn't really get any bigger on a suburban block.
Progress looks great. Did you take down the side fences for the install? Must have good neighbours. :thumbup:
The shed runs boundary to boundary so shed walls replace both side fences. I still need to reinstate an approx 1m section of fence once the corner flashings are in place. Funny enough in my council you don't need permission from neighbors to install outbuildings even if they're on the boundary, so I didn't even need to tell my neighbors about the shed if i didn't want to. I get along really well with both my neighbors so they both knew well in advanced what I've been planning; they're only comments were "that's really big" and "I hope you don't want me to pay for any of it"
joeyp
AU
Solid shed!!
Any reason why you didn't go with some skylight sheets on the roof?
anth
Australia
Very nice mate, that's a whopper of a shed! Can't wait to see how you finish it off.
BUGTHUG
Kansas
WOW, love the VW's, and your avatar. How did you make that?
Anyway, its interesting to see how other countries build stuff. Is your frame painted silver or is that some kind of coating to prevent rust? It almost looks like aluminum?:dunno: Man those are some BIG doors, should be able to put 6 bugs at a time thru those doors:lol:
I can see why the council approved your shop, its one of the best looking down that alley. I hope someone doesn't TAG your walls with graffiti, that would ****!
Are you going to open a small business out in the new shop?
madoc1
spicewood, tx
very nice shed. sure doesn't take long to put up that style of building. what are the plans for the floor?
jim
60beetle60
Adelaide, AUS
Anyway, its interesting to see how other countries build stuff. Is your frame painted silver or is that some kind of coating to prevent rust? It almost looks like aluminum?...
made the avatar as a flash animation then exported it as a gif, did it a few years back when I used to be better at that sort of thing.
The frame is galvanized steel, they coat normal steel in molten zinc which helps the steel last a lot longer without rusting; very commonly used for shed in Australia.
Not going to do any sort of business, shed is just for hobbies.
jim
In the process of getting quotes for a slab to be poured, looking at doing 135mm slab, maybe bit thicker for where I think I'll put in the hoist
Solid shed!!
Was more worried about the shed not getting silly hot during summer. I figured I can open up the doors or turn on the lights to get brighter but its harder to close the skylights when its too hot.
