Bit of an update of what's happened over the Christmas and new year period. Have been flat out the last few weeks but given the time of year it hasn't all been due to working on the shed.
One thing I discovered is the beetle can do do a u-turn in the shed, go in one door and straight out the other. Will be a bit trickier to pull off once the shed's actually kitted out and not an empty shell though.
Spent a lot of time cleaning up the yard and removing rubbish, I had accrued a fair pile of rubble, old concrete paths, old bricks etc. As the floor is now hard enough to drive on I was finally able to remove a lot of the rubbish and tidy up the back yard a fair bit. Ended up with a full trailer load going to the dump.
View media item 78096
Annoyingly I ended up hiring a trailer for the rubbish removal as my dad's trailer which I'd normally use is still loaded up with the 2 post hoist I bought which is too heavy for me to bother unloading. But I have a hoist now which I'm very excited about. Ended up purchasing a second hand one, an automotive training school closed down and all their gear went to auction and I won one of the two hoists up for grabs. Picture of the hoist assembled from the auction website, it was supplied disassembled.
View media item 78097
And how the hoist is now, sitting at the parent's place on dad's trailer all covered up.
View media item 78098
When I was demolishing my old carport the neighbor had an old rickety home made "shed"/lean she used to store various gardening tools and supplies and random junk. It was very old, probably been there 50+ years, and it had started to lean up against the carport. It fell down as I removed my carport and at the time I'd promised to help her out and build something as a replacement so I kept a stack of the old shed and carport components to build a replacement. I finally got around to honoring the promise and replaced her rickety home made shed with something home made but sturdy.
View media item 78099
The end result is a three sided structure roughly 3x3m which provides much better shelter than the old one which was mostly fallen apart. My old car port sliding doors made for good pre-assembled walls and you can still see the old rollers on top. In the picture above you can see the carton of beer I received as payment, dad helped me with the build and he got wine for his efforts.
View media item 78119
I've still been slaving away with the sorting out power to the shed. The shed to meter box run of cable and conduit is complete but I still need to complete the run from my meter box to the stobie pole in the street, required as I'm upgrading the house supply from single phase to three phase. Once this is done I can upgrade the meter box to a three phase unit and have all the wiring terminated. I've completed digging the trench from the meter box to the fence line but haven't laid any cable or conduit or dug from the fence to the stobie pole. Due to proximity of the run to existing water and gas lines it all needed to be hand dug and I got that honour.
The existing power supply to the house is an aerial cable from the street. The power company advised if I were to replace it with a three phase aerial cable they would locate it right smack in the middle of the house gable not to the far side where it is now UGLY! Hence I decided to trench and go underground instead of the aerial cable. While I'm digging for power I will also be laying conduit and cable to replace the telephone line which is an aerial cable as well and leave a few pull through's in the comms conduit for NBN and whatever else may be required in the future.
View media item 78100
On the topic of electrical things I've picked up a bunch of LED battens for the shed, and a few extra to replace the dull fluro tubes under the back veranda.
View media item 78101
