BearsFan315
been debating o HOW to climate control the detached garage, 20x30 main reason was for the humidity and the 1929 Chevrolet stored inside. Detached Garage & Climate Control\
First step was to insulate the rafters, walls were already done when i bought it, but want to keep as MUCH Heatings/ Cooling in as i can. took care of that here: Garage Roof/ Rafter Insulation... To Vent or Not to Vent ?
Did a ton of research on window vs PTAC vs Portable. decided to go with the PTAC, actually a mini PTAC.
Went with a Islandaire Series 26
...these units are 26" wide x 16 tall
this is a 12k BTU unit w/ heat Pump & 3.5k emergency heat backup/ defrost
uses R410a, 220V unit @ 20A Circuit
