Saving a Craftsman Tool Chest
Zeeman
Bartow County Georgia
I finally found this chest that will match my lower cabinets, but it is in terrible condition. I smells like tacos (no kidding), is rusty, bent, missing the lock, has a ton of holes from the rivets that were in it, and generally hard to like. So why am I trying to fix it? Because I've been looking for one or two for several years, but they just don't seem to show up near me, or they sell before I can get there. Here are some pictures of what I started with, and I'll try to document my progress. The previous owner riveted on a lot of galvanized sheet metal to cover the big rusted out spots, and must have used it in a taco business. The more I got into the project, the worse it got. Anyway, I'm determined to make it look much better. Probably not like new, but better.
The pictures when I first got it are on my phone, and I have not tried to upload them yet.
Z
Zeeman
Here are some pictures of how I repaired/am repairing a few areas.
someofusgotfarmingtodo
PA
Wow Zeeman, you got your work cut out for you. Looks like a good project, looking forward to seeing more photos of your work on it. :thumbup:
Z
Zeeman
Yep, a lot of work, a long row to hoe! I have next week off, so i hope to make more progress. The paint that was on it does not want to come off easily, and I've hit it with every sander, and wire brush I have. It laughs at a wire cup on my grinder. Once the paint is off, there is the rust issue.
yhprum
Brisbane Australia
if you fill up a big enough garbage can with water and citric acid, and put in, it will dissolve the rust. One source is concrete paint etch.
thehorse13
Jefferson County, WV
You really should consider dipping that entire box or media blast it if you can't find a dipping tank. Of course proper cleaning and prep is needed post blast/dip as well. I'm sure you know this already.
Getting that patch to set up cleanly will be a challenge for sure. I've taken on insane projects in the past and when looking at the condition of the rest of the top tray, it might be easier to find a donor box and weld in an entire new top tray area.
Z
Zeeman
Thanks for the replies. I will look into dipping, or blasting. My current compressor is not big enough to blast, but I might be able to borrow one. The sunshine red will be a while for sure!
Ridjobradi
Evaporust works amazingly well. You can soak rags in it to lay over the rusted portions and then put plastic wrap over it to keep the keep it from evaporating away. It's too expensive to buy enough to dip your entire toolbox at one time.
Sent from my SM-T330NU using Tapatalk
rsanter
visalia ca
I recomend dipping over blasting
The blasting can warp the thin metal and it will get grit everywhere but will not derust areas you cannot see.
A garbage can full of citric or oxalic acid will eat all the rust and leave the base metal
Bob
Z
Zeeman
Yep I do guys. I'm pretty determined to make it well again. Hope to be able to post some progress soon. Feel free to chime in with suggestions. I don't have access to a welder at this time, so it's rivets, and sweat!
rsanter
visalia ca
Please no rivets......
Look into silver solder. You can make the replacement pieces, use a hidden lap joint
Z
Zeeman
OK, sell me on the silver solder. I've never done that.
Thanks for all the suggestions. I'm thinking about the dipping. Here are a few more pictures.
One of the drawers.
Z
Zeeman
Here's the rolling cabinet that the chest will sit on. I'll have to find some better, completed pictures. This was a pretty labor intensive project too, but not like the chest.
Z
Zeeman
+1
That's not even a ball bearing model. I think you can buy a new Standard Duty chest for less than $100 nowadays...:dunno:
http://www.sears.com/craftsman-26in...SellerId=Sears&prdNo=6&blockNo=6&blockType=G6
Yes, I really want it bad. I like the old vintage stuff. It was well made, and it just makes me feel good to see it in the garage, even better to get tools out of it that I used when I was a teenager. I don't care about ball bearings in drawers one bit. If I wrenched for a living I would probably have drawers with ball bearings in my work cabinets, but still no ball bearings in my stuff at home. The new 100 dollar stuff is nowhere near the quality of the 70's and earlier stuff.
altersaddle
Victoria, BC
That looks like my Triumph!
To properly repair that I think you should weld it. An oxy-acetylene kit with a 000 tip would work, with patience. A MIG or TIG would also be just fine with the right kit.
Another option would be to get new drawers made up by a competent sheet metal shop - it's not complex, but could be a bit expensive for the shop time.
taumac
Brooksville, Fl
[emoji482] I think some wouldn't understand the addiction of the G/R era vintage tool boxes. Once you get one you have to get MORE.
If your gonna be collecting more I really think you should browse CL for a small Lincoln mig unit or bite bullet and get like a Lincoln 140 or similar unit from Hobart, or Miller.
rsanter
visalia ca
Silver solder will allow you to join the new and old pieces af material and it will appear to be seamless when done. Rivets will be temporary solution that you will want to replace later and have to undo the damage of the added holes.
Silver solder can be done with a propane torch
How about finding a local member with a welded that will help out.
If you were more local to me I have a brake and a spot welded that would make quick work of replacing whole sections of the box
Bob
exmaxima1
Midwest
I understand completely. I still have a Remline chest that I bought new in the 80's, and it works fine without ball bearings. I also have a number of vintage Waterloo-made CM cabinets, and when you get over 25 lbs in them, the drawers are a struggle. My small 1996 Matco Anniversary box (bearings) has no problem even when filled with ****. I guess my point was that if I were willing to invest the effort into a vintage tool box, I would start with something that will truly perform as well or better than what's currently available, but I appreciate that you simply like the "vibe" of the old CM chests. Good Luck.:beer:
WWShop
MN
If you can pull this off this would be the most impressive restoration i have seen on GJ. I see a lot of potential in old rusted tools, but i must admit I would not have even attempted trying to restore this box. Looking forward to more pics!
Z
Zeeman
I don't know about that WWShop, but it will at least impress me a little. Here are some more pictures. I changed my mind on trying to piece in the top tray by overlapping some thin metal, so I cut out the funky angled piece over the center drawers, and split it along the top bracket of the drawers. This will be much cleaner fit, and easier to weld.
The part where the left drawer locking mechanism goes is now gone, and I'll just bend some 90 degree angles on my sheet metal and weld them to the sides and back.
Here is the front part where I plan to **** join the two pieces of sheet metal for the bottom. I've cut out the part to the left in the pictures, and now it's one semi-straight boo boo from the front to the back.
The screwdriver is pointing to where the **** joint will go.
Z
Zeeman
Oh yeah, that made one nice big rectangle. I'll have to recreate the opening for the drawer locking mechanism to go through, but it shouldn't be too bad.
Man, this is getting ugly, but it's gotta go.
Z
Zeeman
Hopefully tomorrow I'll be able to media blast the whole thing at a friend's house, and maybe get some metal formed up for the bottom. More to come.
Z
Zeeman
I would do the same just because i like the lid. Nice work!
I think the lid is cool too. I guess when you like something, you just like it. I like anything old though, and fixing stuff up keeps me out of trouble. When I stay out of trouble, I get the nice things I want from my wife.
Z
Zeeman
I'll see how bad it looks after blasting, but I'll probably skim it with some body filler. As much as I don't like working with that stuff, I'd be unhappy with the end result if I just primed and painted it with the pits. That would be the pits!
