Best slide hammer? Or is there one?
Bennylava
Cleburne, TX
I'm needing to get a good slide hammer. I'd like to be able to use it for different types of work, if possible. Is there a "best" slide hammer? Are there ones (or brands) to stay away from? My knowledge of slide hammers is quite lacking.
2ndGearRubber
Pittsburgh
Standard OTC style kit, like $90 bucks.
Then buy the 10lb hammer attachment. Under $200 all in, and there isn't much you can't move.
Ole Slewfoot
Freedom, CA
Morgan Tuff Girl
mlum6969
old coworker had a massive snap on one. that ones quite nice to use but also pretty pricey. the slugger is also a nice one. the otc one is ok if you're working on small cars.
shockwave
Marietta,ga
I like the snap on rear axle slide hammer the best very high leverage compared to others
The otc is best with there attachments like the vise grip threads on but not as beefy as the snap on
Finky198
North East
S&G tool or snap on rebranded (alc keysco) if you want a big one 10 or 12 pound
The OTC is the go to for anything lighter in my experience.
I have the snappy 12 lbs a few no name 5 lbs'ers and a tool box full of puller attachments for both. It covers most thing I've come across. The 12 pounder is very useful for all sort as above... and for hubs, dents, etc.... The smaller one is great for bearings, key ways, nails, cotter pins, light body work.
xjfish
I have the OTC version/kit (I think) with a Mac Tools logo on the box. I think I paid about $300 off the truck years ago but is available for less than $100 online. I prefer the older/heavier Snap-On I've had access to at a couple shops!
Ole Slewfoot
Freedom, CA
9 1/2 lbs(maybe others, not sure)and a nicer grip than most. They are sometimes found ebay or swap meet. I'm sure the Snap On ones are good, but Ive never seen one of these that failed.
doogdoog
Snap On, OTC, Proto, are the ones that I have and they are good but you will have to think about the size you will be using. The one's with the 5/8" shaft are the normally used ones and it is best to buy it as a set instead of purchasing individual accessories because of the cost. This Snap On needs a little muscle.
Mahalo,
doogdoog
jubilee
Colorado
Got any scrap iron laying around? I made all of mine. Think I have four from about 1/2 lb. to 15 lb. Very easy to make if you have access to scrap, a way to cut and weld it.
nh_yota
Seacoast New Hampshire
I don't know which one is the best, but I'll tell you that you should look out for the design of the wheel hub adapter. I picked up a loaner slide hammer from O'Reilly two years ago to replace the front wheel bearings on my Tacoma, and the hub adapter wouldn't clear the hub so I could attach it with lug nuts. The bolt pattern fit but the recessed middle part of the hub adapter wasn't wide enough to clear the wheel hub on my Tacoma and my wheel studs weren't long enough to make it work. Everything in my truck was from the factory at that time so it's not like I had extra large hubs or extra small studs.
APEowner
Sunny, New Mexico
I don't have a specific unit to recommend or to avoid but I suggest that you actually hold it and make sure that your had comfortably fits on both the slide and the handle without hanging off. I have a cheap one that I picked up somewhere and if I['m not careful I can get my hand in between the slide and the handle or, if I adjust my grip to avoid that in between the slide and the slide shaft. Both of which hurt like a son of a gun.
Bennylava
Cleburne, TX
Well how about a good "bang for the buck" slide hammer? When I started this thread, I didn't think that slide hammers would be all that expensive. Should have known better.
quantummechanic
Mahalo,
doogdoog
Hey you wouldn't happen to know the serial number off that. Try to find one to buy
ecotec
Morgan Tuff Girl
This is the coolest slide hammer. I would be very happy to just find a Morgan Tuff Girl weight.
I have so many slide hammers that I could never justify one. I would love to find one cheap at an estate sale.
AEAdam
SE PA
When you say "slide hammer" people think about the bar and the hammer head that slides on it. FORGET THOSE PARTS.
Slide hammers are all about the ends. Make your own, find a used one (how do you ruin a slide hammer?), then buy the ends directly from Snap On with full warranty. That is unless you have a custom end/purpose. Then get the cheapest POS you can find (which might be on eBay).
The Snap On model I have is obviously carefully heat treated so that the threads don't insta ****** or strip. The end is the important part, both the threads and the stuff you thread onto them. My slide hammer has saved my *** many times. This is a tool that can literally pay for itself if you do enough work. I'd say that about pullers in general.
mikey03
I could have used a slide hammer taking apart some metal shelving the kind with the friction plastic half cylinder that wraps around the tubular uprights. It was assembled in a tight closet and couldn’t get any leverage to knock the shelves up to dislodge and used a deadblow hammer
which was fine except the bottom shelf that was 4 inches off the floor I couldn’t get and swing on the hammer. Wound up wasting 2 hours and cutting the exposed part of the plastic clips it was a mess
a slide hammer might have worked but never needed one for cars yet. Not gonna lie kind of want one now
any other non car handyman homeowner kinda uses?
mikedodge
For the simplicity of them and minimal use a slide hammer is a slide hammer. How good they are is in the attachments so you only have to make sure whatever slide hammer you're looking at doesn't have some stupid oddball thread size.
Mine's an old OTC one.
Steve_P
OTC is the "standard", but I'm sure dozens sell the same. Whatever you buy, make sure it has the standard 5/8-18 thread. My ancient HF had a metric thread and I eventually replaced it because of that.
mikey03
Oh nice so I can get a cheap one and then as I need for car stuff just buy the attachments later?
XJSuperman
Central Iowa
Harbor Freight has a couple they offer. I've had one on my list for a bit now waiting for the excuse to buy. Anyone have experience with them?
Beerhippie
Far NE Oregon
I've been in the exact same situation taking down a Euro Rack that was set up where it had to be taken down to move it. I used a loop of baler twine and a 3 lb hammer. Put the loop over the rack on the top side, hammer handle inside the loop near the head and swing away! One pop usually does the trick.
It's the Hippie slide hammer.
Baler twine has little or no stretch so it works very well for this. For heavier use--or someone without access to baler twine (I can't imagine what life would be like), make up a loop of wire rope or cable.
mikedodge
If you're going to do that make sure you get one that has decent reviews and has the standard size thread for the automotive type attachments.
Steve_P
The 5 lb HF is only $25 cheaper than the OTC, so .... As I said, just make sure it has a 5/8-18 thread. I'm sure that HF has caught on by now, but.... Yeah, it's probably the same as the OTC if the thread is a 5/8-18.
The small HF slide hammer set that's a copy of the Snap On is absolutely ****. Yeah, it's a slide hammer, but the jaws break on anything that requires more force than you can pull out with two fingers. I gave up welding up the jaws after a few times; they're probably cast iron and not forged steel.
mikey03
I was looking at the proto catalog and looks like they sell separate the weights and the shafts. They got a 2.5 pound and a 5 pound weight and they got two length shafts. I assume they are same diameter.
looked on zoro and was pretty cheap to get the two weights and two shafts separate
AEAdam
SE PA
5lbs sounds too heavy. Could be unwieldy. I’ve used my slide hammer in all sorts of angles. I have the Snap On 2lb model. I’d start there and go bigger only for a specific application. Maybe if you are using it to pull out dents, 5lb would make sense.
tak1313
I think most are at least OK enough depending on how often/hard you want to use it. My only caution is that when I was shopping around, as others have stated, the cheap (and not so cheap) import ones have metric threads and the vast majority of accessories have 5/8 inch threads.
I don't know what your uses are/will be, but when I was shopping, I also looked for a 10lb weight because yanking a rusted bearing assembly out of a knuckle can be slow/painful with a 5 lb weight (I even used the towel trick). So I bought a 10lb unit because I already had a 5 lb weight from a cheap HF unit years ago that had a large enough bore to fit the standard 5/8 inch shaft. So now I have a GOOD standard shaft that I can use either 10 or 5 lb weight with as needed.
