pan-fry
I got my slo-speed converter set up on my band saw and it worked for about.. maybe 30 seconds before the wider belt disintegrated. Didn't seem like a big deal but turns out it's an oddball timing belt and I'm not having any luck finding a replacement.
Curious if anyone has ever successfully sourced one of these or ideas on how to work around it. BRECOflex has one that is pretty close – just a little too long.
I've attached a few photos of the unit with an intact belt as well as the specs that I've come up with.
• Belt is labeled BR-3000 with no branding or size codes.
• Pitch is approx .25" (yes unfortunate)
• There are 56 teeth on the belt
• It's the old trapezoidal teeth
• Width is 1"
• it's too wasted to measure the length but wrapping a tape around the pulleys reads 13.625" (350 mm)
any help is much appreciated...
• Width is 1"
