Steps are code. Township is **** about things like this.
What I do not like is the discoloration/stain on the steps. They have been power washed twice already.
We close on the house tomorrow and will ask for compensation, just needed some ideas and hopefully cost on what we should ask for.
Ah, the OP is back...good.
1. STAIRS ARE TO CODE. So that isnt an issue
2. NO railing is needed, there is simply not enough rise for it to be an issue. (Im a risk taker- give me a deck under 24" and I will NOT put a railing on it to ruing the aesthetics)
3. I wonder if a blast will change the look, make it more uniform?
4. You cannot 'resurface' this without major issues: you would need to do, the whole porch, each step, the landing out to 36 inches, then taper to the walkway. As I recall the tolerances are 1/4" so even thin tile will render a 'code compliant' set of steps to be out of compliance unless EVERY step surface is re-surfaced.
Id ask for $500 to repour. See what they say- settle for 250. They will, or course, tell you that there is a guarantee, and they WILL fix it. And IF you agree, it will be a year and they will ultimately say 'it is fine, within our standards'. Only way you should accept is if they put in writing 'steps will be cleaned or replaced so as to match the porch slab in color and uniformity of appearance'. Something like that
