Dave-H
Hi all -
Last fall I had my garage floor done with a polyspartic coating. It looks great, with a nice granite appearance. The problem is, we have an odor problem and after quite a bit of testing it appears that the VOCs (mostly Xylene) are coming from the floor.
A few bits of info:
- No, it's not possible to know for sure that it's the floor causing the off-gassing. The only way is to remove the floor and see if it mitigates the odor.
- Yes, I've had professional air testing and consultation and they suspect the floor is causing the odor. Their recommendation is to remove the floor.
Now I'm trying to figure out the best way to remove the floor. The contractor has offered to come out and simply grind it off. I really worry about this because it could distribute dust/debris all over the place, and I also worry that it could somehow get the off-gassing substances pushed further into the concrete, etc.
Does anyone have any experience with removing polyspartic coatings, with solvents/strippers/grinding/blasting, etc? I have a call in to the manufacturer but haven't heard back yet.
thanks!
A few bits of info:
thanks!
