The best wire stripper for auto work?
signcrafter
I have a dozen or so ideal and klein strippers for house electric but looking for the best stripper for 12V work. Either normal or an auto stripper. I used to have an older Mac or matco auto stripper and half the time it worked good and the other half it didn't. Is there a good auto stripper out now? Or stick with a good standard stripper?
FigureItOut
Bentonville AR
I've tried a bunch of them. If I could only have one, it'd be the Irwin auto stripper. I find I need others though, the second most used are my Klein Kurves in different ranges. Working on the bench I love Klein Katapults.
Sent from my SAMSUNG-SM-G930AZ using Tapatalk
mbshop
visalia ca
Yer teeth ? I just used the standard strippers. I wasn't in a race or needing to do 100s of wires in seconds.
Codejack
Chattanooga, TN
I use a Klein, and I do auto electrical work all the time. I would have to go look at which version I have, but it's just a basic stripper; I use the 14-18ga strippers and crimper, mostly.
bwringer
Indianapolis
Much as I detest Irwin for what they did to the once-proud Vice-Grip name...
Their automatic wire strippers are pretty darn great:
https://www.amazon.com/dp/B000OQ21CA/?tag=atomicindus08-20
No need to pick the correct hole or guess as to what gauge wire you're dealing with -- just get the wire in there somehow and squeeze.
I do lots of motorcycle wiring, and these things will even strip that ultra-fine gossamer wire used in LED lighting without breaking a single strand.
dnschmidt
Phoenix, AZ
TOPTUL'S wire stripper is exactly the same as the one Fedwrench mentions. I like the fact that you strip wires with the front end of the tool rather than the side. Easier access from the front in tight locations.
SweetD
Rhode Island
I just bought that Irwin auto-stripper and have used it a couple of times in the past week for 12V stuff - I love it! I've never had an auto-stripper before - works great. Seems pretty good quality as well, and the crimper works well too.
6PTsocket
For many years, I have gotten by with a simple 5" stripper that has a sliding stop in one handle that I don't bother to set. I rarely break a strand. I have several of them laying around. I have a fancy clamp and squeeze job for when the strip is critical but seldom use it. I also have a couple similar to the blue handle one shown above but I use them more for crimps and cutting screws. I find those big strippers clumsey and unable to get into tight spaces where the wire lengths are short.
Rubiman14
I do a ton of custom harnesses and aftermarket ECM installs. My electrical drawer is packed full of strippers and crimpers. I always grab my small Klein or Blue-Point strippers before anything else (ones with the slide lock). Have a small fortune in auto strippers and just can't get warmed up to them.
For wire larger than 10ga, Klein is the only way to roll!
manwithtools
Lebanon, TN
I have always liked this one. Rebadged by many.
http://www.tooltopia.com/tool-aid-19100.aspx
Agreed, we've been using the Felo version for months in our shop. We have 15 pairs of them doing as many as 400 - 600 strips per day and they are holding up well. For the price, when they dull or get cranky, I'll pitch them and buy and buy more.
https://www.kctoolco.com/felo-62681-felo-automatic-wire-stripper/
Rubiman14
Really? I've only been using them as crimpers lol. That's about the best thing they do. My pair will not properly strip a wire unless I **** them at an angle. If I have a straight angle of attack (perpendicular to the wire) they will not cut unless I go down in size...then they'll cut a few strands.
zmotorsports
Northern Utah
I have a pair of the ones shown above as well but unfortunately don't care for them as much as I thought I would. I was excited to have both the crimpers and strippers in one but ultimately don't reach for them nearly as often as I originally anticipated. OK crimper but the stripper isn't as "tight" as the Blue Point ones listed below.
These Blue Point ones are my "go to" strippers.
https://store.snapon.com/Strippers-...r-Cutter-AWG-10-20-6-Blue-Point--P630546.aspx
For insulated crimpers these are what I reach for. I also have the same thing in the Thomas & Betts flavor.
https://store.snapon.com/Crimpers-Pliers-Terminal-Crimping-Cutter-9-3-8--P885609.aspx
For non-insulated terminals I grab these.
https://store.snapon.com/Crimpers-Blue-Point-174--Tool-Crimping-Blue-Point--P636986.aspx
Brownsfan
Cleveland Ohio
Depends on what you are doing. Tapping into a existing wire in a car without cutting it I use these. These work the best for stripping wire that you need to tap into https://www.walmart.com/ip/Gs-394-A...4491&wl11=online&wl12=148459487&wl13=&veh=sem
Now just stripping wire ends for termination. Connecting two wires together putting on spare terminals etc. I use these. These can strip multiple wires at a time. And auto adjust. Now. Neither of these work well on solid wires in the house. Only stranded
https://www.opentip.com/search.php?...fJ6_a4TmkPAEK58H0gUljB9OXTcaPfiRoCmQIQAvD_BwE
pstemari
Seattle
]... just stripping wire ends for termination. Connecting two wires together putting on spare terminals etc. I use these. These can strip multiple wires at a time. And auto adjust. ...
I've got a pair of those orange and blue ones from Fry's and they're fantastic. Not good for anything 16ga or over, but they do a great job on the small wires and don't require you to have a grip on the wire. They grab the wire and pull off the insulation by themselves without tugging on the wire.
Sent from my Pixel XL using Tapatalk
notlob
norcal
AngryBeaver
Lake Milton Ohio
I'd exchange them. I use them daily as an unlicensed electrician/generator and diesel mechanic. now have three pairs... work truck, shop, and home shop.
notlob
norcal
The problem with these types of stripper is they damage the wire which can lead to a point of failure.
I have never seen that they damage wires, and I have used them at times with magnifying lens to assure cleans cuts and perfect crimps on 26 awg wires.
If they cause damage to your wires, I would characterize that as "user error."
cheechi
Triad, NC
far as stranded wire, the felo and similar are the auto strippers I prefer. For solid wires any listed will do.
signcrafter
I bought a pair of the Klein Katapult today from home depot. Looked nice and seem to work alright except when the two jaws don't always line up. Not sure if the machining is off or what but it seems like every so often the jaws don't line up perfect when you clamp down on them. I'll use them a little bit more and see what happens before I email Klein to see if there is an issue.
http://www.homedepot.com/p/Klein-Tools-Katapult-Wire-Stripper-Cutter-11063W/204660476
fordcragar
Yakima Wa.
I seem to have more than my share of strippers too.
I'm not a big fan of Harbor Freight stuff, but will buy some of stuff if it is reasonably priced, with the idea if it doesn't work it goes right back to the store. If it works for a while and then breaks, I'll buy a better brand.
All of that said, HF does have a stripper similar to one of the ones mentioned that I picked up for $8 today. I took it out to the garage and tried it on several different gage wires and it did a nice job.
https://t.harborfreight.com/heavy-duty-self-adjusting-wire-stripper-36810.html
Rick B.
East Tampa
I saw this post a couple of hours ago, watched a couple of videos of them in use then jumped in the truck and went to Lowes to buy a pair! Thanks for the info.
Olafur
Iceland
Nothing I have tried beats this guy, or the Knipex version. Single tool cuts and strips - and does both very well (and fast) with small practice.
I seem to be the only one on G.J to use this tool, so for your toolaholics, here is something to try for the collection. :evil:
Very popular over here.
skruft
For wires 10 and smaller, I use all the same kinds of strippers, of one quality brand or another, that I would use for non-auto work, often a "T stripper." I do not think it makes much difference if you practice and get the technique.
When I started I used some semi-automatic strippers that my father had used wiring ships in WW2. You would select the gauge and length, then squeeze and they would do the rest.
mrborohachi
Berdoo Route 66
+1 Felo
Bought it because the wire cutter is on the top of the tool (this is a newer design). I have an old IDEAL auto stripper which like some Knipex the cutter is on the bottom. You have to twist your hand in order to see when you want an exact cut. I was wiring electrical panels for conveyor belts (tortilla making machine) and that wire cutter on the top made such a difference.
https://www.amazon.com/Felo-0715762681-Automatic-Wire-Stripper/dp/B00QWYNPGY/ref=sr_1_1?ie=UTF8&qid=1506487997&sr=8-1&keywords=felo+wire+strippers
